Question about Numark NUVJ - Video Mixing Software Controller and Interface
I have a Numark Arkaos NuVJ Video Mixer that I got without the two disks and the two original cables, but I found a cable and downloaded the updated version of the program on the Numark website. When I finally did connect everything, the program would not respond to the controller being connected. I've unplugged the controller from my computer several times, but still no results. I hope some one can help me Thank you, DJ Muel
  • 13433 Answers
SOURCE: Cue LE/ virtual DJ and icue controller
hey, I don't know what happened last night, the chat window just disappeared from my screen.
Lets see if I can get you a replacement skin file.
Posted on Jun 29, 2008
SOURCE: dj io with Traktor PRO
gvjccçznvcncbdfjcvnmcmxnfbfjgkksdfsd
Posted on Jul 01, 2009
SOURCE: Since I started using the Numark DJ i0 soundcard I
get the lastest download from www.numark.com and then go to your startup menu and go to numark folder and change your audio latency setup to the next level and repeat it unitl works
Posted on Jul 29, 2009
SOURCE: MAC Computer wont recognize Numark HDX when connected via USB.
Did you format your hard drives thru the menu on the deck? If not you may need to format the hard drives first and then plug them in. *NOTE DO NOT FORMAT DRIVES THRU YOUR COMPUTER* format the drives thru the decks in the utility menu.
Posted on Aug 24, 2009
SOURCE: My Numark iDJ2 won't update it's firmware!
I've tried it with a PC, I've tried it with a Mac, I've tried it with two different memory drives, and nothing will get it to update. Numark has a quality problem they need to address soon.
Posted on Sep 27, 2009
I HAVE A NUMARKKMX01 MIXER WHEN I PLUG THE RED RCA JACK IN TO THE MIXER I GET A LOUND HUM
What is plugged into your Numark mixer when this happens? Try disconnecting ALL audio inputs to your mixer, turn mixer volumes to zero and see if the hum is still present. Adjust the volume and check if the hum you mentioned returns. If it is still heard, try new cables between the mixer and amp...if not then start reconnecting inputs until the hum is heard again. It's a process of elimination but not that difficult to find the source of your problem.
Oct 31, 2012 | Numark Industries Numark DM 1200 Mixer
The software "Nuvj" always crash
Hi With Adobe Flash Player 10,0,45,2 installed everything will work ok. Cheers
Nov 25, 2010 | Numark Nuvj DJ Video Mixer
Im trying to hook up two sets of passive speaker, one pair is connected to a QSC amp and the other pair is connected to a Kenwood amp. Is this possible without using another mixer like a mackie 1402.
you should be fine, you can get splitters, little adapters to split the input cables into 2, so that you can use one ouytput to run 2 channels. just hook up the output cables to the output on the numark, and use the splitter adapter to split the sound between the 2 amps.
Oct 05, 2010 | Numark CD Mix2
What lube can i use to clean numark nuvj crossfader. i'm gettin a leak while using the fader.
Usually a "leak" from one side to the other is an indication of a cracked resistance element. The fader would have to be replaced.
I lube the faders on my mixers using CRC226 availablle in the electrical dept at Home Depot. Use sparingly.
Aug 12, 2010 | Numark Nuvj DJ Video Mixer
Software doesnt open
The first place to start is drivers.
Jun 18, 2017 | Numark Nuvj DJ Video Mixer
Connections
nuvj connects to your comp you have to supply connections from your comp to a projector
Sep 18, 2009 | Numark Nuvj DJ Video Mixer
Numark
You need a new adaptor...the wires have lost their connection in the cable or plug which isnt user servicable
KK
Aug 29, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Numark NUVJ - Video Mixing Software Controller and Interface Logo
151 people viewed this question
Top Numark Computers & Internet Experts
Mike
aravind shet
aravind shet
Wes-Tex Audio...
Wes-Tex Audio...
Level 1 Expert
Are you a Numark Computer and Internet Expert? Answer questions, earn points and help others
