Question about Systemax Venture PC Desktop
Does this computer allow me to use a floppy disc?
  • Systemax Master
  • 11,800 Answers
Yes, it allows you, just that you will have to install the floppy unit yourself since they didn't installed it at the factory. Pick one
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=287&name=Floppy%20Disk%20Drives
Posted on Mar 28, 2011
Windows xp boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
1. Place diskette in the computer.
2. Open My Computer, right-click the A: drive and click Format.
3. In the Format window, check Create an MS-DOS startup disk.
4. Click Start
Create Windows XP Setup diskettes
Microsoft is beginning to phase out bootable floppy diskettes in favor of bootable CD discs and has not included a method of easily creating a bootable floppy diskette in Windows XP or from the CD. However, Microsoft has downloads available for users who still need to create bootable diskettes to install (not upgrade) Windows XP. These downloads can be found through KB310994.
hope this helps
Sep 24, 2012 | Computers & Internet
I want to transfer data from a floppy disc to a cd
Your computer must have a floppy disk drive in order to read data. You have to buy one or borrow computer (from your friend maybe).
Oct 18, 2011 | Samsung CLP-600N Laser Printer
Where is the insert for the floppy disc
The floppy disk may or may not be installed in section 5. They started eliminating floppy drives some years ago, when USB flash started to become popular.
5
FlexBay drive panel
Can contain an optional floppy drive or optional Media Card Reader. For information on using the Media Card Reader, see Using a Media Card Reader (Optional).
If your question was more basic than this, and you have a floppy drive, then you just insert the floppy into the slot. It doesn't open. Look for the arrow on the floppy disk, if it doesn't go in one way, turn it over.
Sep 13, 2009 | Dell Inspiron 531s Desktop Computer
Memorex external usb floppy disk-drive does not appear or functio
As I understand it the computer recognizes the floppy drive.
Can you read other discs, write to them etc? If not drive is bad
If you can read other discs then your floppy disk is bad
Jan 23, 2009 | Memorex Computers & Internet
F1 floopy diskette faliure seek faliure
Make sure it is not disabled in the boot order, there is also an option for the drive itself (Diskette Drive) that must be disabled
Jan 05, 2009 | Dell Dimension E310 PC Desktop
I need to make a system restart disc or recovery disc
i can help you with this but need to know what windows you are using
Oct 27, 2008 | Computers & Internet
Extracting old files from computer discs.
I am not sure if I understand, but in the second statement you said that you have another large computer with large and small disc drives. Can you still open up the 5.25 inch foppy discs, and save it to that computer, and later extract it off using 3 inch floppy?
Oct 02, 2008 | Computers & Internet
Nexxtech External Floppy Driver Problem
Normally windows will install any driver for a usb floppy drive automatically. If it needs one. I'm surprised that it hasn't just worked by plugging it in as there cheap floppy drives over purchased have all just worked without the need to install drivers on win xp and higher. Remember you won't see the drive appear under my computer until it has a disc inserted in it though.
Jul 17, 2017 | NexxTech USB External Floppy Drive (NEFD2)...
Metal sleeve
3.5" FLOPPY DISKETTE
Below we have represented a picture of the now commonly used 3.5" floppy diskettes. The below representation is what the back of a floppy diskette looks like. As you can see there are four main visible parts:
floppyd.gif First, the top left of the back of the floppy there is a small tab. This tab enables the floppy disk to be switched from write protected and un-write protected. Move the tab to the top position, creating a hole, makes the disk write protected. This means that nothing can be written, erased or deleted from the diskette. Moving the tab to the bottom position allows the disk to be un-write protected, which means the diskette can be written too, erased, and or have information deleted from the diskette. Some diskettes, which are generally cheaper diskettes, will be missing this tab. To write information to the diskette you will have to place a piece of scotch tape over the hole.
Second, the top right hand of the back of the floppy you will notice a small hole. This tells the computer if the diskette within the computer is a High Density diskette.
Third, you will notice the circular metal disk in the middle of the floppy diskette. This is used to rotate the magnetic medium within the floppy disk casing.
Fourth, you will see a metal door which can be moved left and then will snap back to its original position. This door is used to allow the read/write head within the floppy drive to have the capability of accessing the magnetic medium within the casing. Once the diskette is removed, this door will snap back into position, helping to prevent anything from getting on the magnetic medium and destroying it.
5 1/4" FLOPPY DISKETTE
Below is a representation of a 5 1/4" floppy commonly used in 1980's and is generally no longer used today. The 5 1/4" floppy diskette was really floppy (flimsy) when compared to the 3.5" floppy diskette.
floppyd3.gif As you can notice in the above illustration, the 5 1/4" floppy does not have many involved components. First, you will notice the Write protection tab which would be present if the diskette allowed information to be written to it. Placing a piece of tape over the hole or if the hole was not present would make the diskette write protected.
Second, you should notice the large hole in the center of the floppy diskette. This hole allowed the platter within the floppy to be rotated allowing the information to be read from the write access hole.
Third, you should notice the Index hole, this hole was the computer's way of knowing where the starting point of the sector was on the diskette by physically having a hole punched in the film disc within the plastic casing.
Finally, you should notice the write access hole. This is the location which information would be read from as the disc within would rotate. However, because there was no protection like that found on the 3.5" floppy diskette, the 5 1/4" floppy diskette was generally protected by placing it within a protective sleeve.
Hope this helps ya/Let us know ,ok Thank you for using fixya.com.Please dont for get to Vote.
Jul 20, 2008 | Dell Inspiron 6400 Notebook
Systemax Venture PC Desktop Logo
16 people viewed this question
Top Systemax Computers & Internet Experts
pankaj rautela
pankaj rautela
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
