Adwww.searspartsdirect.com/Kenmore-Partsrating for searspartsdirect.com
Shop Today at Sears PartsDirect™. The Largest Appliance Parts Seller. Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
Check the door switches if one is bad it may think the door is being opened and stop the unit from running. If it is from a bad connection it will get worse as it gets hotter while running.
Just had this happen - the repair guy says it is the inverter. And they have stopped making the part so it cannot be fixed!!! When did you buy your unit?
The F-9 error code indicates a defective control board, inverter or line voltage too high .
WARNING : A microwave is capable to give you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
Look at the owner's manual of similar Kenmore models there does not seem to be a setting that allows you to turn off the turntable. However if your microwave (sorry but I couldn't find your exact model number online) has the time of carousel that has a lift out glass plate with a notch (hub) in the center of the bottom side then you effectively turn of the carousel my removing this glass plate. (see pg 4 of the manual - above link) You can place a normal microwave safe plate in the microwave in it's place. Make sure to leave the rollers in place...just remove the turntable.
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Generally the F9 code indicates a problem with the door latch (usually upper) or with the control board.
You can do a Google search for my text file "doorsw.txt" to help you diagnose and repair door switch trouble.
BUT - since it always stops at 53 seconds, that leads me to think you have trouble with the control unit (circuit board / controller assembly).
Once you read and digest the info on door switches, please feel free to do an updated post and I'll be happy to help you further.
It may be corrupted ROM in the control unit. But let us know what you find out.
- online they call me "William E. Miller, AS-EET"
