Question about Lexmark Optra T612n Laser Printer
Lexmark Optra T612
On the underside of the printer there is a shaft to which an arm is attached with the paper pickup rollers. On the shaft is a plastic moulding to which a spring is attached which keeps the paper feed rollers up when not printing. The moulding broke and the spring detached and the feed rollers dropped into the paper tray which is how we became aware of the problem. I found a way of attaching the spring however it hasnt fixed the problem. When I try to use the printer I now get a message to replace the paper tray. Is there something else which has broken or is it a matter of resetting something.
  • JamesHarmon Aug 14, 2008
    On the underside of the printer there is a shaft to which an arm is attached with the paper pickup rollers. On the shaft is a plastic moulding to which a spring is attached which keeps the paper feed rollers up when not printing. The moulding broke and the spring detached and the feed rollers dropped into the paper tray which is how we became aware of the problem. I found a way of attaching the spring however it hasnt fixed the problem. When I try to use the printer I now get a print status of Error every time. I can print the demo page from the printer control panel, but always get the error message when printing from my desktop computer. The printer cable is connected on both ends.
  • 300 Answers
The broken part is called the bell crank arm part number 56P1228 this is very common. If the printer isn't recognising your tray, remove it and check the little plastic fingers on the left side (half way down the tray) and the metal springs in the printer (left side) which the tray pushes on to.
Posted on Aug 04, 2008
HOW TO REPLACE HVPS ON OPTRA T612
Please see the attached photo for instructions on how to replace the High Voltage Power Supply for the Optra T Series.
Nov 25, 2012 | Lexmark Optra T612 Laser Printer
Optra T612 fuser replacement
Here's an article in the Lexmark website on How to Replace the Maintenance Kit Parts on an Optra T Laser Printer. Just click on this link: http://bit.ly/95cW2R. Scroll down for the instructions on how to replace the fuser unit. Hope this helps.
Jun 30, 2010 | Lexmark Optra T612 Laser Printer
Lexmark optra t612 keeps reading load mp feeder letter wont pick up paper how do I fix this
Hi there
All this is down to is taking all the rollers off and gave them a good clean in worm water or try clean then in there place and make shure they all free running.
All the best Pineworks
Apr 29, 2010 | Lexmark Optra T612 Laser Printer
Paper cringling and jamming on print. Drum looks worn.
this sounds just like a worn out fuser. pull the fuser out and inspect the rolllers if the orange roller (the pressure roller) has bad wrinkling or if the shinny sleave of the roller has slid off to one side replace hte fuser
Mar 08, 2010 | Lexmark Optra T612 Laser Printer
The paper keeps jamming
Most times is it dirty rollers that pick up paper. You can get cleaning kit for it and most times just remove the paper tray and clean all of the rollers and also open all of other doors and if there is a roller clean it too. Make sure you use cleaning kit or it will get even worse. Also make sure you unplug it and if it has fuser that is has cooled down. Hope this helps.
Jan 12, 2010 | Lexmark Optra T612 Laser Printer
What would cause a 900 RIP code on a Lexmark T612?
Go to http://support.lexmark.com/printerfirmware
Locate the appropriate authorization code for your printer model from the following list and enter it:
Optra S (4059) series printers: 4059engn.
Optra T610, Optra T612, Optra T614, Optra T616 printers: optrateng.
Lexmark T520, Lexmark T522, Lexmark T620, and Lexmark T622 printers: lextengn.
Lexmark T630, Lexmark T632, Lexmark T634 printers: e551416.
Lexmark W812: eng204
We recommend you choose to save the file within a directory on your computer's hard drive.
Once it has been saved, go ahead and run the file. The downloaded files are self-extracting ZIP files. Running this file will create a set of .PJL files and a file entitled Readme.1st. The Readme.1st file also contains directions for sending the file over through a parallel connection.
Oct 30, 2009 | Lexmark Optra T612 Laser Printer
Lexmark Optra T612 says "remove paper in standard bin". I took paper out and it still does not work. Thanks!
Don't know if you solved this alread, but take a look at the 'exit flag' located just where the paper is spit out of the printer. If the exit flag is in the "up" position, just bring it down and that should solve the problem. If the exit flag is in the up position, this makes the printer think that the bin is full. Hope this helps. Either that or http://support.lexmark.com
Sep 17, 2009 | Lexmark Optra T612 Laser Printer
How do you replace the bell crank arm on a optra t612
I'm on my way to change a bellcrank on a t420, simple answer is, you need to cut the old one off.
Be carful not lose any springs though.
Dec 18, 2008 | Lexmark Optra T612n Laser Printer
Lexmark Optra T612n Laser Printer Logo
355 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
