Question about phil & teds Vibe Stroller
How to take off rear wheels? - phil & teds Vibe Stroller
  • 17,970 Answers
There is a little push button on the metal bar that runs the length of the stroller.
I heard about bearings have gone bad on phil and teds and they (customer support) told me that need had to replace the entire wheel at 40 dollars a pop.
Hope helps.
Posted on Mar 27, 2011
I have a jazzy 1107 power wheel chair the back wheels are leaned outward i dont think the back wheels should be leaned outward i think this is what is causing me not be able to be able to turn properly....
Have some one check out that the section has not become loose or broken. IF the wheel rubbers are damaged then you will have trouble regardless of what you do. I consider it paramount that the chair is in top condition for your needs. Have the manufacturer's service agent fix it for you.
Sep 22, 2013 | Health & Beauty
Action tractive, abs--trk won't go
Your best bet ,take it to a qualified repair shop ! P0351, ignition coil A primary/secondary circuit-------what does this operate
The electrical circuit for the coil for cylinder # 1 , could be the wiring , coil or the driver (transistor)inside the PCM - engine computer . Replacing the PCM would need to be programmed , DEALER ONLY . Just replacing parts isn't going to fix this . Doing the diagnostic's for the code . Codes don't tell you a part is bad or needs to be replaced . All codes have a diagnostic test procedure that has to be followed to find the cause of the code setting . Don't know where you came up with B0050 & B0455 Has nothing to do with traction control . These codes would start with C . tune up right? No .
trk won't go ??????? C0445 This has to do with the rear wheel steering system !
The steering wheel position sensor (SWPS) provides one analog signal and 3 digital signals. The digital signals, Phase A, Phase B and marker pulse, are direct inputs to the rear wheel steering control module. The analog signal is input to the BCM and is sent via a class 2 message to the rear wheel steering control module. Battery voltage is supplied to the sensor from the cruise fuse to operate the digital portion of the sensor.
A 12-volt reference is provided by the rear wheel steering control module to the Phase A, Phase B, and marker pulse circuits of the SWPS. The module monitors each circuit as it is either remains high or is pulled low by the SWPS.
The scan tool displays the Phase A and Phase B data parameters as either HIGH or LOW when the steering wheel is being rotated. Each change from HIGH to LOW, or LOW to HIGH, represents one degree of steering wheel rotation. When observing the Phase A and Phase B data with the scan tool, the parameters will not always display the same value at the same time.
The marker pulse is a digital pulse signal that is displayed as HIGH by the scan tool with the steering wheel angle between +10 degrees and -10 degrees. At greater than 10 degrees steering wheel angle in either direction, the marker pulse data will be displayed as LOW.
The BCM provides the 5-volt reference and low reference for the analog portion of the SWPS. The BCM reads the SWPS analog signal in voltage, which is typically 2.5-volt with the steering wheel on center. The voltage ranges from 0.25-volt at approximately 1 full turn left to 4.75-volt at approximately 1 full turn right. The voltage will then remain at that level for the remainder of steering wheel travel. This voltage can be monitored in BCM data display.
The rear wheel steering control module receives the analog signal via a class 2 message from the BCM. When monitoring the rear wheel steering data, this information is displayed in the Steering Wheel Angle (TBC) Data parameter, and is shown in degrees. The range of the display is +/- 225 degrees, with negative numbers representing steering input to the left, and positive numbers representing input to the right.
This does not mean the sensor is bad !!!!!!!!!! Take it to a qualified repair shop before you make it non fixable .
Quadrasteer™ is a 4-wheel steering system that dramatically enhances low speed maneuverability, high speed stability, and towing capability. The system is an electrically powered rear wheel steering system comprised of the following components:
You have no idea what your messing with .
Rear Wheel Steering Control Module: The rear wheel steering control module controls all functions of the rear wheel steering system . The module has a dedicated power feed line from the under hood fuse holder. The fuse is a 125 amp mega fuse . The wiring is routed to the rear of the vehicle. The rear wheel steering control module is located above the rear mounted spare tire. The rear wheel steering control module uses the inputs listed above to determine when and how far to turn the rear wheels. The rear wheel steering control module also uses the hall switches in the steering gear motor , shorting relay , and motor control relay to monitor and control the direction and speed the motor operates. The rear wheel control module also controls the duty cycle of the phase leads to the motor . The motor control relay is part of the rear wheel steering control module and is not serviceable . The rear wheel steering control module uses both a class 2 and a discrete vehicle speed sensor signal . The system will not function without a discrete vehicle speed sensor signal . The rear wheel steering control module uses the 2 vehicle speed sensor signals for comparison purposes . The TBC sends a class 2 message for the analog portion of the signals from the steering wheel position sensor. The rear wheel steering control module uses inputs from the steering wheel position sensor to determine steering wheel position and rate of change. The rear wheel position sensor signals provide the rear wheel steering control module with rear wheel position data. The rear wheel steering control module will send out a class 2 message to the IPC to turn on and off the amber Service 4-Wheel Steering System Indicator. The rear wheel steering control module controls the indicators in the mode switch on the dash .
Oct 15, 2017 | 2003 GMC Yukon Denali
Lawnmower wheels jamming/sticking rear wheel drive
Unless you want to replace these gears You can make this mower into a push mower by taking the wheels off and disconnecting the gear drives. One time I took wheels off the front and put on the rear and rear off the back and put on front. In order for this to work all four wheels have to be the same size.
Dec 23, 2017 | Garden
Procedure for replacing rear whl brgs on a 2003 escape awd
4-Wheel Drive
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Rear wheel
    • Rear brake shoes
    • Rear halfshaft nut and loosen the halfshaft from the hub
    • Wheel hub and place it in a vise
    • Inner wheel bearing race from the hub
    • Antilock Brake System (ABS) sensor bracket and move the sensor aside, if equipped
    • Parking brake cable from the steering knuckle
    • Brake line from the wheel cylinder and support the knuckle
    • Lower shock absorber nut
    • Lower ball joint by holding the ball joint stud
    • Upper ball joint
    • Coil spring while noting the location of the insulator
    • Steering knuckle cam
    • Steering knuckle
    • Snapring and press out the outer wheel bearing race from the knuckle
      Rear hub and bearing
      Click to Enlarge
To install:
  1. Install or connect the following:
    • New wheel bearing into the steering knuckle
    • Snapring to the knuckle
    • Wheel hub
    • Steering knuckle cam and hand tighten the bolt
    • Coil spring
    • Shock absorber lower nut. Torque the nut to 85 ft. lbs. (115 Nm) for 2002-04 models; 129 ft. lbs. (175 Nm).
    • Upper ball joint. Torque the nut to 76 ft. lbs. (103 Nm).
    • Lower ball joint. Torque the nut to 76 ft. lbs. (103 Nm). Align the steering knuckle cam and torque the bolt to 85 ft. lbs. (115 Nm).
    • Brake line to the wheel cylinder. Torque the brake line bracket bolt to 15 ft. lbs. (20 Nm) and the brake line fastener to 11 ft. lbs. (15 Nm).
    • Parking brake cable to the backing plate. Torque the bolt to 16 ft. lbs. (22 Nm).
    • ABS sensor bracket. Torque the bolt to 80 inch lbs. (9 Nm), if equipped
    • Halfshaft nut. Torque the nut to 214 ft. lbs. (290 Nm).
    • Brake shoes
    • Rear wheel
  2. Fill and bleed the brake system.
  3. Check and adjust the wheel alignment as needed.
2-Wheel Drive
    • Rear wheel
    • Rear brake drum
    • Wheel hub nut
    • Wheel hub
    • Snapring
    • Wheel bearing outer race from the knuckle
      Rear hub removal
      Inner wheel bearing removal-rear hub/bearing
      Rear wheel bearing removal-2wd
      Rear wheel bearing removal-4wd
To install:
  • Wheel bearing in to the knuckle
  • Snapring
  • Wheel hub into the wheel bearing
  • Wheel hub nut. Torque the nut to 214 ft. lbs. (290 Nm).
  • Brake drum
  • Rear wheel
    Rear wheel bearing installation
    hope this helps if so send testimonial comment or even any other questions you have
Jan 16, 2011 | Ford Escape Cars & Trucks
How do I determine if the car is front wheel drive or rear wheel drive?
Generally, trucks, vans and large cars with big engines will have rear-wheel drive. Smaller, economy and compact cars are most often front-wheel drive. But you don't have to guess which one you have - find out for yourself.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Instructions
  1. Understand that front-wheel drive means the power from the engine and the transmission goes to the front wheels; rear-wheel drive means the power goes to the rear wheels. Four-wheel, or all-wheel, drive means all four wheels are powered.
  2. Open the hood.
  3. Find the front of the engine. The front of the engine is always where the belts are located.
  4. Look to see if the front of the engine is by the fender (side of the car). If so, then you have front-wheel drive.
  5. Check to see if the front of the engine is by the radiator and the grill (front of the car). If so, then you have rear-wheel drive.
  6. Look under the car near each front wheel. If you see an axle with a rubber boot (called the CV boot) on either end going into the wheel, then you have front- wheel drive.
  7. Look under the car between the rear wheels. If you see a large, metal, pumpkin- shaped thing (it's called the differential) with two axles coming out either side, then you have rear-wheel drive.
  8. Check both under the hood for the position of the engine and under the car for the axles to be sure, because not every car follows the rules for engine position and front- or rear-wheel drive (see Tips below for examples of cars with variations on this rule).
Good Luck
Nov 08, 2010 | Chevrolet Impala Cars & Trucks
EXPLAIN THE DIFERENCE BETWEEN THE FRONT WHEEL DRIVE AND THE REAR WHEEL DRIVE
FRONT WHEEL DRIVE IS THAT THE FRONT WHEELS ARE WHAT DRIVES THE CAR AND THE TRANSMISSION IS IN THE FRONT REAR WHEEL DRIVE MEANS THAT THE REAR WHEEL DRIVE THE CAR ALLWHEEL MEANS THE THE FRONT AND REAR WHEELS DRIVES THE CAR FOUR WHEEL DRIVE MEANS THAT YOU CAN HAVE ONLY TWO WHEELS DRIVE THE CAR OR AL FOUR WHATEVER YOU PUT IT IN
Oct 19, 2010 | 2002 Toyota Celica
Rear cluch not working
Depends on what model and components you have:
ENGINE TORQUE DISTRIBUTION – DIRECTING THE FLOW OF POWER
In an all-wheel-drive vehicle, engine power can be directed to all four wheels. Subaru Symmetrical AWD differs slightly from model to model in how it directs power to the wheels, depending on its transmission.
MODELS WITH FIVE-SPEED MANUAL TRANSMISSION – CONTINUOUS ALL-WHEEL DRIVE: A viscous-type locking center differential and limited-slip rear differential help distribute torque – normally configured at a 50/50 split front to rear. If wheel speed differs between front and rear axles, the center and/or rear differentials lock up to help distribute power to the wheels with the most traction.
MODELS WITH FOUR-SPEED AUTOMATIC TRANSMISSIONS – ACTIVE ALL-WHEEL DRIVE: An electronically controlled variable transfer clutch and limited-slip rear differential distribute power to where traction is needed. Sensors monitor parameters such as wheel slippage, throttle position, and braking to help determine torque distribution and direct it to the wheels with optimum traction.
MODELS WITH FIVE-SPEED AUTOMATIC TRANSMISSION – VARIABLE TORQUE DISTRIBUTION ALL-WHEEL DRIVE: As with Active All-Wheel Drive, an electronically controlled variable transfer clutch distributes power, but through a planetary-type center differential and a viscous-type limited-slip rear differential. Torque distribution is normally configured at a performance-oriented rear-wheel-biased 45/55 split front to rear. Sensors monitor the same parameters as for Active All-Wheel Drive.
WRX STI, WITH SIX-SPEED MANUAL TRANSMISSION – DRIVER CONTROLLED CENTER DIFFERENTIAL (DCCD) ALL-WHEEL DRIVE: The STI uses an electronically managed multi-plate transfer clutch and a mechanical limited-slip differential in conjunction with a planetary-gear-type center differential to control power distribution between the front and rear wheels. Featuring manual and three automatic modes, DCCD is normally configured at a 41/59 split front to rear. Sensors monitor parameters such as wheel slippage, steering angle, throttle position, and braking to help determine torque distribution and direct it to the wheels with optimum traction. DCCD also features a limited-slip helical front and Torsen® rear differential. ... }
And what are the symptoms? How do you know the coupling to the rear is not working?
Jun 05, 2010 | 1995 Subaru Legacy
2003 X-Type: 2003 jaguar x type - what is correct tire pressure...
For Normal driving Jaguar approved tyres:
2.0L 16" Wheel front 35lbf rear 32lbf
17" Wheel front 36lbf rear 34lbf
2.5L 16" Wheel front 38lbf rear 35lbf
17" Wheel front 38lbf rear 35lbf
3.0L 16" Wheel front 38lbf rear 35lbf
May 18, 2010 | 2003 Jaguar X-Type
How to removal the shaft from the rear end to
In order to remove the rear wheel, it is not necessary to remove the drive shaft. The first step is to get your rear wheel off the ground. The easiest way to do this is to put your bike on its center stand. However, not all bikes have center stands. If your bike does not have a center stand, you may want to buy a motorcycle lift (available from Pep-boys, or Harbor Freight). Once the rear wheel is off the ground, you can disconnect the brake linkage, and then remove the rear axle.
At this point there is nothing holding your rear wheel to the bike except for some meshing gears. Now you must lift and maneuver the rear wheel back and forth a little and eventually the final drive will work free. You will be able to slide the wheel toward the right side of the bike and then lower it to the ground.
In theory removing the rear wheel is that simple. In practice, the gears in the final drive can sometimes hold on quite tightly. This is particularly true if the rear wheel has not been removed for a long time or if your final drive is very worn. Usually being patient and persistent will pay off and you will be able to remove the rear wheel.
Sometimes it may prove easier to remove the entire wheel / final drive / drive shaft assembly first, and then separate them. In this case, the order of operations is different. Once you have the rear wheel off the ground, you can disconnect the rear brake linkage just as before. Next you can remove the four bolts that hold the drive shaft housing to the back of your crank case. Finally you can remove the rear axle and slide the wheel backwards the unmesh the drive shaft.
Regardless of which way you remove the rear wheel, it will be easier to put it back together by first attaching the drive shaft and final drive to the crank case, and then reinstall the wheel as described in the first method above.
Good Luck,
-Josh
Mar 27, 2010 | 1985 Yamaha XJ 700 X Maxim
MOT Test
a) Sitting on machine check:1. All controls switches and horn 2. Front suspension forks handlebars and head bearings. b) At the front of the machine check: 1. Front lights and indicators 2. Front brake master cylinder (if fitted) c) Place the machine on its stand and raise front wheel check: 1. Steering, front forks and head bearings 2. Front brake and wheel bearings 3. Wheel and tyre condition. d) Lower front wheel and go to right side of vehicle and check: 1. Frame, VIN, seat and foot rest 2. Exhaust system 3. Final drive (if fitted to RHS of machine) 4. Rear wheel, tyre and brake e) Raise the rear wheel and check: 1. Rear wheel, rear brake/components and tyre condition. 2. Rear suspension and final drive f) At the rear check: 1. Rear position lamp(s)/stop lamp(s)/reflectors and indicators. 2. Rear suspension. 3. Registration Plate g) On the left of the machine check: 1. Frame and foot rest 2. Exhaust system 3. Final drive (if fitted to LHS of machine) 4. Rear wheel, tyre and brake. h) At the front of the machine check: 1. Wheel alignment 2. Headlamp aim 3. Brake performance,,,
Nov 10, 2008 | 2003 Hyosung GT 600 Comet
phil & teds Vibe Stroller Logo
106 people viewed this question
Top Phil & Teds Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Phil & Teds Baby Gear Expert? Answer questions, earn points and help others
