Question about Peavey Pv 2600 Power Amplifier
Peavey 2600 m series shuts off power when turning up volume after about 30 to 40 seconds of playing and takes about 2 minutes to reset
  • Peavey Master
  • 5,603 Answers
Sounds like the thermal cutout is sensing over temp. Make sure there is FREE airflow around the unit. If it is in a cabinet, install vent fan(s). This amp will throw out a lot of heat. Make sure cooling fins have airflow. Cables can block the airflow... check for that possibility. Repeated thermal cycles will eventually cause failure of components.
Posted on Mar 27, 2011
Hello good morning i have a peavey 2600 power amplifier, each time i try to turn on the amplifier the breaker switch flies what could cause that to happen
A serious power drain caused by a damaged mains transformer, short circuit power supply, shorted output transistors or a leak to earth taking the earth treip out.
Mar 22, 2018 | Peavey Music
I need to know which volume control I need for a Peavey century 120 series bass head
Man this is a tough one....I can't locate a schematic anywhere online so I suggest calling Peavey In Mississippi and talk with technical assistance. A helpful tech can pull the paperwork and give you the correct value in about 2 minutes. Good luck.
Dec 19, 2013 | Peavey Music
My peavey amp pv 2600 only plays on channel A. No output on the B side
Check the "BRIDGE" switch position, "IN" for "BRIDGE", "OUT" for "STEREO", and clean ALL back switches with a cleaning spray and then run the amp again, also check the two green lights activation at front, if they activate, then amp is certainly working, let me know further.
Jan 28, 2013 | Peavey Pv 2600 Power Amplifier
Useing a Peavey XR 800F Powered PA Mixer/Amp which develops distortion on output after around 60 minutes. Also had gear linked to all inputs at the time, three mics, 2 guitars and keyboard. Any ideas...
First of all confirm if the speaker impedance is not lower then the recommended Ohms at the back of the Mixer speaker socket.You can use an 8 Ohms speaker on a 4 Ohms amplifier but not vise versa .
Next see if the fan on the mixer works. If not the Amp is getting very hot and this will lead to unwanted distortion. You can confirm if its a heat related issue by playing the mixer at low volumes for more than an hour and see if it distorts.
Apr 26, 2011 | Peavey Pv 2600 Power Amplifier
I have 2 peavey 2600 amps with 1 pv6 mixer wanting to run subs off 1 amp and sp2s off other amp but only have 1 main output on the pv6 mixer whats my solution
you can run one amp from the main out puts and the second amp from the CTRL Room out puts. The CTRL ROOM are outputs that are linked to the same bus as the master fader. This will work fine...
Best of luck
Sep 02, 2010 | Peavey Pv 2600 Power Amplifier
How can i prevent it from over heating
Do NOT block airflow via the vents and fans. If other equipment blocks or restricts airflow, space out the items in the rack.
Some amps have vent fins at the sides and these must have free airflow.
Do not go below the load resistance rating by paralleling too many speakers.
Do NOT drive the amp into the clipping region with too high volume.
Jul 16, 2010 | Peavey Pv 2600 Power Amplifier
Peavey amp shut down
The output stage has a problem. From your description, I'd guess that the high voltage supply has failed. The low volume and distortion suggests that you are trying to power the speakers from the driver section rather than the outputs. There is a resistor that fails in some of this series. If I remember correctly it is either a 2K or 3K resistor 10 watts in size. If you have no experience with repairs, I'd seek a service shop that is familiar with these units. The part runs between $5-$10.
Dan
May 07, 2010 | Peavey Pv 2600 Power Amplifier
I have a 2600 peavey amplifier and when i turn the volum up it cuts off for about 2-3 seconds what i need to do
check that the cooling fans are working. if they are not then you are probably triggering the thermal overload protection.
Nov 08, 2009 | Peavey Pv 2600 Power Amplifier
What is DDT my system cuts out when DDT lights up
Go to http://peavey.com/support/searchmanuals/archived.cfm Their main site also has info. DDT is an active compression feature to protect the product .
Jul 04, 2009 | Peavey Pv 2600 Power Amplifier
Power supply problem
Use the series light bulb trick when trying to first power this up. Use a 150 watt bulb in series with the 120 volt power to avoid damage and blown fuses.
Jul 02, 2009 | Peavey Pv 2600 Power Amplifier
Peavey Pv 2600 Power Amplifier Logo
104 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
