Can I wall mount this tv if so what type of mount do you recommend and where can I find one?
  • Sid Schmidt Mar 27, 2011
    You need to be more specific on what type and size of tv you have.
  • 822 Answers
Any flat screen tv can be wall mounted..........try ebay for bracket........
cheers
Posted on Mar 27, 2011
Does sharp model come with wall mount
No wall mounts for TV's are optional.
May 24, 2018 | Sharp Televison & Video
How do I install a tv on my wall
First of all find out what size mount is on the TV. On the back of the TV you should see 4 screw holes to take the bolts of the stand. You can measure the space between the holes. Then you can search for a mount that will take that size. If the TV is big you will need a very strong wall mount.
When you get the mount it should have instructions for mounting it. But make certain the wall you are fixing it to can take the weight and is stable. Fix the mount to the wall, make certain that you use the correct screws and plugs for the screws. You should be able to tell if the mount is secure enough. If you have any doubts, get somebody in to do it. The mount will come with the correct fixing screws for the TV. You will need two people at least to fix a smaller TV to the wall and two people to hold a big TV while a third screws the mount to the TV.
Feb 10, 2017 | Televison & Video
What type of wall mount bracket will I need
Depending on what you want, Just make sure it is made to hold at least a 32 inch LCD TV . If you would like to tilt it, buy a tilt mount. It needs to be mounted to the studs in the wall for best support. I recommend you pre wire the cables before hanging the TV,since they will be hard to get to after the set is mounted.
Aug 07, 2014 | iSymphony 32" LC32iH62 LCD Widescreen...
Mounting tv on wall
You would need to get a flat panel wall mount. Since you are unsure on how to do this, I would strongly recommend hiring a professional or handy man with experience installing the mounts. Not installing the wall mount properly could cause the TV to fall and damage the set(warranty will not cover the damage) or cause bodily harm to somewhere.
Sep 03, 2012 | Scott LCT37SHA TV
How does the tv mount?
1- remove the wall plate from the arm.
2- fix the front plate to the back of your television.
3- mark the position of the holes and drill
4- put wall plugs into holes.
5- secure the wall plate to the wall
6-attach the arm to the wall plate.
7-hang the screen on the arm (i recommend having someone help) and secure it in place
Mar 05, 2011 | OmniMount "OmniMount 23" to 42" 4in1 Flat...
Is there a specific wall mount for this TV to swival in all directions
Acquiring wall mounts for television are according to preferences. For example, wall mounts that provide the TV dynamic directions to suit operators requirements would have separe requirements. The multidirectional wall mount provides the TV capability to swirl around several angles. Howeever, acquiring wall mounts as requirement to encamp the TV also placement on safe areas from which the device is observable is an alternative considerations. TV wall mounts provide multi purpose functionalities. For example, TV wall mounts that provide both encampment housing placement hinging to an area, and finallly capable of multidirectional functionalities available for acquisition at retails. Also possible are acquisition of customisable wall mounts to suit the type of placement area required on TV sets either suitable at various locations. For example, TV wall mounts are customsiable to house sets that require functionalities with complimentary devices like decoders, modems, DVD players, VCR recorders, or cable wiring. The process of acquiirng wall mounts is achieving interhrety of the TV set, housing available devices requiredm and achievifn viewer egonormics. Consult room device area estimate expert before acquirng wall mount to ascertain the appropiate conditions capable of providing egonomic experiences. Goodluck
Jan 08, 2011 | Televison & Video
Can i mount my tv on the wall it is model cwf32l6
Yes you can.
there are many types of wall mounts you can buy. Ensure the load / weight rating of the wall mount exceeds that of your TV, and mount it exactly as per the manufacturers instructions.
Most audio visual shops sell all types of wall mounts.
You can also check out ebay.
Feb 28, 2010 | Symphonic ST419E TV
Can thris protron tv be mounted on a wall?
it can be mounted, they sell a universal hanging kit, you will see 4 holes in the back of the tv, thats where you put the screws for the mount
Jan 11, 2009 | Protron PLTV-4250 42 in. LCD Television
Attaching to wall mount
The 4 screws that are commnly used are short because they are ususally wide in diameter. Besides if they are too long then they might damage the boards on the TV.
Apr 13, 2007 | Akai LCT2716 27 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
