Question about Dryers
Dryer turns on and runs but does not heat up or dry clothes. Dryer is Whirlpool Cabrio and only about 6 months old and still under warranty
  • hhspatsfan Apr 01, 2011
    There is no airflow out of the dryer and therefore none out of the home
  • 4,354 Answers
Check your breaker, by turning FULLY off and back on. Check for good air flow at the rear of the machine, and the same at the exit of the building.....
Posted on Mar 27, 2011
  • hhspatsfan Mar 27, 2011
    Gas dryer and gas is on all the way, air is coming out of the home from the vent. When you put wet whites in the dryer and set it to normal- is sets for 32 minutes but runs for about 10 then beeps. Open it up and feel steam but clothes do not dry at all. It takes 60-70 minutes to even get the clothes to where they are not damp.
  • Mike Mar 27, 2011
    So, what about the air flow tests? Steam certainly indicates heat is present, so then the equasion is air flow. Do those two tests and see what you find....air flow at rear of machine and air flow at exit of building (air flow volume)
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
Dryer running but no hot air and clothes are not drying? Is heating element burned out?
Good chance it is. Make sure it is getting power first. You can check with a voltage meter.
Feb 27, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Have a whirlpool cabrio gas dryer. It takes several hours to dry one load of clothes. The clothes seem to stay damp towels may take all day... what could be the problem
Have you opened the door while its running to see if its warm inside (heater working) If its getting warm and still not drying the clothes properly you likley have a air circulation concern. With the unit running check the exhaust vent outside from dryer it should have a good flow of warm air, if not you have a restriction sowher between the unit and outside. Heat alone will take forever to dry clothing,you need good air circulation to remove the moisture from the clothes otherwise all you will end up with is warm moist clothing.This generaly happens over a long period of time and then all of a sudden you realize the dryer is not working like it use to..Hope this helps you with your concern.....
Aug 09, 2010 | Whirlpool Dryers
My Roper elictric dryer is not drying clothes
If you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some tihings to check before assuming there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call. If you check everything and still have poor heating issues, please let me know. You may have an internal bias or hi-limit thermostat malfunctioning.
Jan 05, 2010 | Roper RES7646KQ Electric Dryer
Dryer runs well but will not heat up and dry
You need to clean your dryer vent and make sure there are no obstructions.
Jan 02, 2010 | Whirlpool LGB6300 Gas Dryer
Ld code goes on at spin/ drain cycle almost every time
For the original posters having a problem draining and spinning, is your problem along the lines of the washer performing a clean, and then when it drains, and begins to spin somewhat, it then stops and refills up back with water? How old are your Cabrio units?
I purchased my Cabrio set in May 2007 back when they have the original agitator plate design. If your have experienced "balling" up of your clothing after a wash load finishes, it is a result of the agitator plate which can also throw off a load balance. The fix for this was that in early 2008 Whirlpool started using a new agitator plate that is small in size which is supposed to correct the problem.
My first service call was April 2008. I didn't opt for the extended warranty through Best Buy but since the one year warranty wasn't up yet I had a service technician come out. It turned out that there were two issues that needed resolving. One was the "balling" of the clothes, which resulted in the agitator plate being replaced with the newly designed model. The second was the entire "brain" or computer if will was replaced. Both parts were ordered and installed at no charge by A&E Factory Service that performed the servicing for Best Buy and I was impressed with the repairman that came out. He said a good number of the Whirlpool units with the original agitator plate were causing this problem with clothes bunching up. The replacement of the brain/computer was needed so he took off the faceplate and unplugged everything, and installed a new revised version, again under warranty. According to his computer, there were just the two service bulletins affecting my model Cabrio washer (WTW6600). The new brain/computer was an updated version that also fixed the balancing issue.
Since the replacement of the agitator plate and the brain/computer (aka main control module), I haven't had any problems so this MAY be what is needed for your model. I decided during this first repair visit above with A&E to extend my warranty for two years on both my washer and dryer. Now 13 months have passed since that first visit and I began noticing my clothes in the matching Cabrio dryer were not drying as quickly as they used to.I made an appt. and A&E came out yesterday (6/23/09) to my house. They ran a bunch tests including a heat test and could not find any defects or problems. The only service bulletins he showed me had to do with those dryer units that have been making a large amount of noise, something mine hasn't been doing, but have noticed people posting here. He ran a heat test and it came out fine, and also checked the suction and it was fine too.
One thing he did show me inside the dryer, there are two metal grids that act as the wet clothes sensor. He said if you use dryer sheets, they can sometimes put a light coating on them, so he recomends either some Windex on a paper towel and run along the two grids to clean them every so often, OR better yet some very fine sandpaper to run along them. These metal grids act like sensors to determine if the clothes are still wet or dry. He mentioned he shoudl only have to lightly touch his fingers on them during the test mode for them to buzz, but on mine he had to push in for it to read the moisture in his fingers. After he lightly sanded them (again with very "fine" sandpaper), he then only had to lightly touch the grids for them to buzz during his diagnostic test.
During his visit, I had him go ahead and check the washer and he showed me a few open service bulletins on them, but they didn't affect my unit. He did get an error code that had to do with a stuck button, and took the cover off to verifiy what software version of the brain/computer I had inside. The version I had (which was the one replaced back in April 2008) he said was outdated and said there was a newer version they have been installing. He had one on the truck and went ahead and installed it under warranty thus providing me with the latest brain/computer for my washer. I believe the last two digits on it are "66".
Your problems could be a combination of the older original agitator plate and the computer module needs to be updated to the current version. The problem I have with Whirlpool is that I registered my pair when I bought them, and I would think they would notify customers when there is a service bulletin released. I said to the tech, "how am I as a consumer supposed to know when these bulletins or recalls are issued when they don't bother to contact me?" and he had no answer other than Whirlpool relies on the consumer contacting them with the problem and only then will they address the issue if it is affected by a service bulletin or recall. But my response to that is if someone knows they are out of warranty, they are apt to contact a repair center, in many cases, not Whirlpool directly. He agreed, that people do that and by contacting Whirlpool first, if it is something they are voluntarily covering, it can save the consumer money.
Check with Whirlpool about the issues you are having and see if the agitator plate and computer module replacement is a covered item even after warranty.
Feb 11, 2009 | Whirlpool WTW6400SW Cabrio Washer
New Whirlpool Dryer taking too long to dry
Old dryers worked on the premis, "bake them til they are done". Newer dryers are all about saving energy. Newer dryers rely far more on airflow than thier predecessors. Most likely if your clothes are taking 120 minutes to dry for a new dryer, you have a ventalation problem. Make sure (even if it was "professionally" installed) that the vent from the back of the dryer to your wall in not kinked, bent over, or other wise restricted. Also make sure when the air is venting to the outside of your house you can feel a fair amount of air pressure there. Bulid up over time or even a nest being built in your vent can cause a restriction on airflow. These can be cleaned by a professional service or many appliance and hardware sell cleaning brushes and kits. Worse case scenario, Whirlpool will pay for customer instructs for the first 6 months. So even if they have to come out and tell you it's a problem with your house vent or electrical supply, whirlpool can be billed for this. Of course if there was a manufacture defect off the production line, repairs are still covered under warranty as well.
Jun 21, 2008 | Dryers
Dryers Logo
59 people viewed this question
Top Dryers Experts
Marvin
Marvin
