Question about Cell Phones
I have LG chocolate BL20v. In the phone call divert is activated some how. Now I am trying to reset call divert. I am using setings -> call -> select call divert -> voice calls -> options -> deactivate all -> ok. Then I get a message deactivated, but when I try to make calls it still says call divert enabled. This should be a simple option given to users but not sure why it is not working. To resolve such a simple things do we need to take it to service center? Does any one know who to deactivate call divert option in LG BL20v
  • Cell Phones Master
  • 4,737 Answers
You have performed the correct steps to deactivate the Call Diverts. It's possible that there's problem with your phone. Perform the Call Divert deactivation steps and switch off the phone when done, remove the Sim Card, leave it outside for few minutes and put it back. Now turn on the phone and see if that helps or not. You can also try resetting your phone to factory settings (restore factory default). Open Menu, go into Settings, locate "Restore Default" or "Reset Settings" and follow the onscreen instructions. You'll also need to default code 0000 [4 zeros] (if you've recently changed the default code, this will not work). Note that resetting or restoring your phone might wipe out all your phone's memory contents, so make sure that you backup the contacts or message before performing this. If nothing seem helpful or if the code doesn't work, then you have no choice than going to a Service Center or a Local Mobile repair shop. If it's a software issue, then you might likely need to re-flash your mobile. If it's only a minor issue with the operation, then restarting or performing the Reset will fix the issue.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Posted on Mar 27, 2011
Incomeing call going to voice mail and phone not ringing
if you diverted to voice mail send #21# to deactive all diverts if your answering machine is on turn it off setting > application setings > call > all calls > answering machine > activation > off
Aug 08, 2011 | Samsung S8300 Cell Phone
I have a LG Chocolate Touch... It had been working fine, I recently put a lock code on it... I still remember the password but now my touch screen isnt working... It hasnt been dropped nor fell in water so...
Hard reset SHOULD work:
Settings (and tools on some phones)--->Phone Settings--->Security Setting--->Master Reset (it may be called something else, but it will be clear).
Jul 05, 2011 | LG Cell Phones
Lg chocolate bl40 doesn't access music player just displays' loading' & rotating circles.It remains in this mode indefinetly, or until it switches itself off.If the cancel button is pressed the phone...
You need to master reset the phone, you can do this by Settings > Phone settings > Reset settings
if this does not work you need to update the software by visiting this link: http://uk.lgmobile.com/web/web.support.retrieveSoftwareUpdate.laf" style="color: blue; text-decoration: underline; ">http://uk.lgmobile.com/web/web.support.retrieveSoftwareUpdate.laf
Feb 03, 2011 | LG CHOCOLATE BL40 (1 GB) Cell Phone
I have a LG bl20v new chocolate. I bought a microSD kingston memory card and it worked. But after some time, when I tried to open files, it said that there was no such file. And when i restart the phone,...
see most probably your memory card's file system has got corrupted ,use a card reader to connect the card to the computer and format it in FAT32 file system then insert the card again and it will work
Dec 04, 2010 | LG KC910 Renoir Cell Phone
How to install other swf format themes in lg bl20v new chocolate mobile other than the default themes. pls give full details
First chech whether it supports.then send a swf file into ur phone via bluetooth and check wat options do you have with it
Aug 04, 2010 | Cell Phones
Reset button for lg chocolate touch
Here is the procedure to Reset
Tap -->Menu-->Settings & Tools-->Phone Settings-->Security (code is last 4 digits of your phone number(default), -->“Reset Default”
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 30, 2010 | LG Cell Phones
How to downloaded install jad games
i just reset my phone nokia 5200, After that cant add settings,
May 15, 2010 | LG KG800 Cellular Phone
My sim is showing 44'h,me error.
Apr 26, 2010 | Nokia 1600 Cellular Phone
My n95 keeps making an engaged tone and saying 'diverts active'? how do i stop it?
Its showing Active diverts because your call diverts is active. May be you have set a call diverts where if you are unreachable your calls gets transfered to voice mail. To deactivate Active diverts. Go to Tools -> Settings -> Call Diverts -> Options -> Cancel all diverts
Hope this helps.
Oct 20, 2009 | Nokia N95 Cellular Phone
How do i sreset my LG chocolate?
You can try this and I hope it will work:-
Call*228 and push 1 when they start talking and it will reset it and the code will be the last 4 digits of your number.
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 18, 2009 | LG Chocolate 3 Cell Phone
Cell Phones Logo
88 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
