Question about Ovens
I have a AEG Electrolux micromat microwave oven.- I was trying to change the time, but have somehow put the oven into "SAFE" mode. Pressing any button simply shows "SAFE " on the display. Ideas on how to exit from this mode?
  • 10 Answers
SOURCE: AEG Oven
try setting the clock, it may be automatic
Posted on Mar 22, 2008
  • 139 Answers
SOURCE: AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Posted on Aug 24, 2008
barkencoa
  • 3463 Answers
SOURCE: my AEG Electrolux fan assisted oven does not heat
If the fan and light work o/k, then you need to replace the oven element.
Please rate my solution.
Thanks.
Posted on Nov 03, 2009
  • 161 Answers
SOURCE: oven does not work,no display.
the display board itself would be the culprit,the part might be under warranty,if under 5 years consult manual or manufacturer for coverage....the part is probably expensive
Posted on Mar 06, 2010
Testimonial: "It appears as though this will require a repair person with all the parts. Nothing I can do on my own. Thank you for the input."
SOURCE: electrolux EOC68000X oven Demo mode only
If that model number EOC68000X is correct then in the manuals I have for that Model there is no Demo mode setting.If you can supply the PNC number then I will investigate further.Try relogging your call with this information.
Hope this helps.
Posted on Jun 08, 2010
Eecrolux combination wall oven / microwave is in demo mode model# ew30mc65jb
Good Morning Rolf, thanks for your post!
Based off the information you have provided your Electrolux wall oven/microwave combination is stuck in demo mode. The best way to remove demo mode from your wall oven/microwave combo is to hold the oven light button and the on/off keys at the same time and you should be able to toggle in and out of demo mode. Hopefully this is helpful. -Matt
Mar 09, 2015 | Electrolux 30" Built-In Double Electric...
How do I remove the oven door from my electrolux icon oven
Good Morning Friend,
I understand you are trying to remove the door on your Electrolux Icon oven, model# E30SO75ESS. Being, that this particular model is a microwave as well as an oven, I suggest contacting your local authorized technician. They have been trained on this particular model and will be able to assist the best. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Electrolux ICON Designer E30SO75ESS Oven
F84 trouble code on electrolux icon wall oven
I am getting the same error right now for the microwave part of the microwave oven combo. The oven is working fine with no racks out of place.
Sep 10, 2012 | Electrolux ICON Designer E30SO75ESS Oven
I have a faure oven which is in safe mode . How do I get it to function.
press and hold the temperature button and simultaneously hold the 'temperature duree' knob to the + or - position until you hear a beep. This locks and un-locks the child safe mode
Jul 29, 2011 | Electrolux EOB5630 Ultrafan Electric...
Microwave electrolux Nutrition : no heat effect. microwave effect missing
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 30, 2010 | Electrolux Ovens
My oven is locked out and I cannot get it to work
Is the digital clock/timer set correctly? Sometimes after a powercut I have to reset this to get the oven controls back into manual mode. Follow this link to the user guide for your oven and have a read. Re set the timer and should be ok....hopefully! http://safemanuals.com/user-guide-instructions-owner-manual/AEG-ELECTROLUX/B1180-4-M%20UK%20R05-_E
May 08, 2010 | AEG B1180-4 Electric Single Oven
I have an AEG Electrolux oven D8800-4 double oven and have ann error code A3, what does this mean?
I hope you mean error code F3. if so then that means a software error and if you disconnect from mains supply then reconnect this should reset the fault if that does not work you may have a damaged circuit board.
Hope I helped.
May 06, 2010 | Electrolux Ovens
MY AEG OVEN IS IN SAFE MODE HOW DO I GET OUT OF THIS MODE
Just found out that the 'safe' mode on my oven is for child protection. I had to press 'p' en 'minus' (-) at the same time for a few seconds. Problem was solved immediately. My oven is an AEG-Electrolux Micromat-Combi.
Apr 23, 2010 | AEG B8139-4-M Electric Single Oven
My bottom oven is not heating up?
If it is an all electric fan assisted oven, and the fan is working o/k, then the oven element has probably failed.
This is located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Dec 09, 2009 | AEG Ovens
My AEG Electrolux fan assisted oven does not heat up. The lights and everything works just no heat.
Thanks.
Nov 02, 2009 | AEG U3100-4 Electric Double Oven
Ovens Logo
54 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
