Question about Mitsubishi HS-U510 VHS VCR
HS-U510(c) Recently the tape is not rewinding. When ejecting, tape not rewound from heads and gets caught in mechanism. Defenitely seems to be some rewinding problem as noise of gears grinding and slipping. Thanks!
    Problem Solver:
  • 10 Answers
Quite often it is a cassette problem. The two winding reels run on plastic bases which often becomes very dry and the two reels do not run smoothly. Remove the outer casing and take the two tape reels and the tape out. Then apply a small amount of powdered graphite to the rubbing surfaces of the bottom casing. Reinstall the two reels, making sure to put the tapes in the correct positions around the tape posts, and then replace the outer casing. This often resolves the problem.
Posted on Jul 02, 2015
  • 6,771 Answers
The problem is in the idler assembly that runs the tape and reels it in on eject, the drive belt will probably need replacing that is attached to the assembly.
Posted on Mar 27, 2011
Eject cassette
sounds like already rewound or tape is caught open and have a look!!
May 15, 2010 | Canon DM-XM2 Mini DV Digital Camcorder
Tape ejecting automatically
I found the spring on the tape carriage was off on one side. I reinstalled it and it fixed the problem
Dec 19, 2008 | Mitsubishi HS-U510 VHS VCR
Canon elura 90: won't load tapes
Make sure the power is on this unit and you are pluged into a good source of power. The disk tray needs power to lower. A lot of tapes get loose in there case and need to be fast forwarded and then rewound completely in order to help spool them properly in their case. And what you are experiencing sounds a lot like this. It is also possible that you need to buy a head cleaning unit for your elura and run it in the camera for 10 secs and then try again. (Did you try this with a New tape? or just used ones?) We bought a small tape rewinding unit for around 39 dollars that helps us to rewind the mini DV tapes without adding wear and tear on our camera and it seems to help with the issue of loose tapes in the camera getting rejected as they won't wrap around the tape head as nice.
Dec 14, 2008 | Canon Elura 90 Mini DV Digital Camcorder
VCR won't rewind HS-U447
A VCR is still useful and it is still the best method of archiving something you want to keep due to the fact it is possible to edit or repair the tape when something goes wrong but that is quite impossible with digital discs and other digital archiving methods.
I don't know much about how they work because so far I have only needed to clean the heads periodically to keep them working. They do contain a number of belts, rubber wheels and clutches andit is possible something made of rubber has deteriorated and stopped doing what it is supposed to do.
You will probably find loads of useful video content on youtube about that.
I have many VCRs due to the fact when the fashion passed folk were giving them away, putting them out for the garbade or simply leaving them in the street - that was just after I had bought a new one because it was much cheaper than getting an estimate from a repair shop.
I suggest you ask on the neighbourhood grapevine if anyone that still has a VCR would pass it on to you or enquire on freecycle, preloved or gumtree. Check at your local recycling centre or even haunt the discount stores until you find a new one - it will be cheaper than a repair unless you want to try and repair it yourself.
Apr 01, 2017 | Mitsubishi HS-U447 VHS VCR
Camcorder wont playback recording
Dear Lauren,
You didnt write camera model and make. any how, you need Head Cleaning Cassette for your camera to clean its video heads. Video heads are dirty/ clogged so camera doesnt show picture in playback. Please dont touch video heads physicaly because it may broken easily. always use video head cleaning cassette.
Apr 20, 2008 | Sony Handycam DCR-TRV250E Digital...
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
AG-1330
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Another possibility is that the tape is caught aroung the spindle guides that pull the tape around the video head. If the tape is caught in the spindles, this will affect playback performance. The heads could be dirty too. Another possibility for poor playback is a slipping idler wheel. The idler wheel is a rubber tire that pivits between the tape sending and pickup reels. It's a key part during playback, fast forward & rewind. The idler tire can also be treated with a re-grip solution or be replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor.
Jan 09, 2008 | Panasonic AG-1330 VHS VCR
Toshiba M-752 Video Casette Recorder
Take the top cover off, and see if there is an obvious reason for the no-eject, as in tape spooled out and wrapped around something. Next, is the tape drawn back into the tape housing? Under normal operation this is done before eject. A defect in the tape itself, or in the VCR mechanicals can cause a no "pull in" condition. Otherwise, you could carefully try to assist an eject- push eject, lift lightly on the tape. Sometimes the entire carriage mechanism can be removed with tape in place, but often, screws holding this in place are obscured by the tape, and, if carriage is gear driven, proper gear alignment must be reestablished. This can be a tricky problem, getting tape out without damaging anything, especially since late VCRs are made rather fragile to start with.
Aug 14, 2007 | Toshiba W522 VHS VCR
Televison & Video Logo
271 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
