Question about Dell 946 All-In-One InkJet Printer
Each time i push print i get a message back that say's printer can not communicate with computer. how can i fix it.
    Sergeant:
  • 192 Answers
First try to restart the computer.
If this does not work power the computer down then unplug your printer from the computer.
Unplug your printer from the wall and wait 1 minute then plug it back in.
Turn your computer back on and after it is finished "booting up" plug your printer back in.
Posted on Mar 27, 2011
The printer shows the error message "Turn power off and then on" but it does not get off swicted off and it continues to blick the same error message,how do I fix it?
Sounds like a lack of communication from your printer to your print port.
Try this... left click your task bar in lower bottom right corner. if you see a small icon that looks like a printer open it. Then left click it and select discontinue/cancel print job. With the printer still on restart your computer,( save all work before you do the reboot.)
This should bring your printer back up to communicating with your computer.
Hope you good luck.
Jul 03, 2015 | Office Equipment & Supplies
I loaded my Lexmark X6180 printer with the software, and the installation went fine to the finish. But I get a communications error message "cannot communicate." What shall I do to fix?
What is the operating system installed on your computer?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 24, 2011 | Lexmark X6180 Printer
My Lexmark Platinum PRO905 does ot print it gives me the message " Communication Not Available, The Printer cannot communicate with the computer"
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug your printer into the power source to reset it. When the printer turns on, reconnect the printer into the computer. Try to print again.
You may also refer to this article (for Wi-Fi connection issues): How to identify a Wireless Communication Problem and Resolution Tips
Aug 09, 2011 | Lexmark Platinum Pro905 multifunction...
My computer is'nt comunication with the printer
It could be just a slight communication issue. Try to unplug your printer from your computer. Then unplug the printer from the power source. Replug after 10 seconds. When the printer turns on, replug it into your computer. Doing this usually fixes minor communication issues. If error continues, you may refer to this article on 'Communication Not Available' Error Message and Print Job Stalls in Print Queue for troubleshooting steps. You can also contact Lexmark technical support for additional assistance. Thanks.
Jan 21, 2011 | Lexmark X2600 InkJet Printer
Computer cannot detect the printer
first check communication cable which cable you are using usb or any other? Change the cable and check once.. and observe one thing at the time of connecting printer cable to computer or at the time of powering on the printer system giving any sound or not? change communcation cable and check...
Jun 22, 2010 | Dell 926 All-In-One InkJet Printer
LexmarkX74-75 Communication Not Available
Fix this Error - use an advanced registry cleaner for Windows that allows you to safely scan, clean, and repair registry problems with a few simple mouse clicks. Problems with the Windows Registry are a common cause of Windows crashes and error messages. By using PC tune-up utilities such as registry cleaners regularly, your system will be more stable, your software will run quicker, and your operating system will boot faster.
http://www.errorfixreviews.org/
Good luck
Jun 22, 2009 | Lexmark X75 All-In-One InkJet Printer
Dell Laser MFP 1815 won't print. Message keeps coming up Jam 2 open rear and front door. Have opened and shut doors repeatedly, restarted printer, tried copying over message but it keeps being displayed....
I had same problem. If you go to rear of printer and open the back door you'll see it is attached to a blue connector. Unattached it so that the door opens fully and then unflap the inside roller assembly. Next open the fuser door and you'll notice a little spring loaded assembly on the inside of the opened fuser door. This is where my problem was. Make sure that the assembly springs back when pushed because part communicates with a sensor on the motherboard. If it doesn't spring back then the printer thinks there is a jam. Mine was stuck but after pushing it a few times it started to work freely again. This was a frustrating problem but that fixed my issue and hopefully it will fix yours.
Jun 04, 2009 | Dell 1815dn All-In-One Laser Printer
Printer not communicating with computer
(1) Try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
(2) Update the USB drivers
Jan 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
I just put new ink Cartridges but still wont print
Most of the time the "problem communicating with the printer" message pops up on Lexmark X1185 series when the driver gets corrupted. The best fix for this issue would be to uninstall the software first. Try connecting the USB to a different USB port (Please avoid using USB hubs, if any) and then reinstall the software. This should normally fix the printer communication issues!
Good Luck
Dec 12, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
I have a x5495 printer and after installing software and I try to print, I get message that no communication between printer and computer. I have checked all of the recommendations and still can get to...
The message "no communication between printer and computer". some times indicates that the cable you're using is faulty or the port selected is not the printer port you've connected your printer to.cheers.
Dec 01, 2008 | Computers & Internet
Dell 946 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
