Question about Stairmaster 4100PT Stair Climber
Replaced return spring on Stairmaster 4100PT. Now won't turn on.
4100pt
Stairmaster 4100PT Stepper Parts SPORTSMITH net
You can use the above link to get some more information on this unit. We have several parts available as well as the manual for this model. It sounds like you could be dealing with either a faulty keypad or a bad display.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Mar 12, 2014 | Stairmaster Exercise & Fitness
Tip
Replacing a Spring Pulley on Stairmaster 4000PT Stepper
Stairmaster Stepper 4000PT Spring Pulley Replacement
  1. Remove the bottom cover.
  2. Unhook the pedal arm return spring from the spring hanger.
  3. Remove the snap ring from th pulley shaft. WARNING: To reduce the risk of eye injury, wear eye protection when removing snap rings.
  4. Slide pulley and washer off the shaft.
  5. Before reinstalling the pulley, clean the pulley shaft thoroughly with a clean, dry cloth. Apply a thin coat of multipurpose grease to the pulley shaft.
  6. Slide the pulley and washer onto the shaft. Install the snap ring.
  7. Route the spring under the spring pulley.
  8. Hook the end of the spring over the spring hanger. WARNING: Do not twist the spring during installation. It will wear excessively and reduce the life of the spring.
  9. Reinstall the cover.
How To Replace Spring Pulley on Stairmaster 4000PT
on Mar 10, 2015 | Stairmaster 4000PT Stepper
Tip
Replacing a Pedal Arm Return Spring on the Stairmaster 4000PT Stepper How To...
How To Replace a Spring on Stairmaster 4000PT
  1. Remove bottom cover.
  3. Detach the spring from the step chain by removing the master link. The spring-chain connector is in good condition if it has an hour glass shape. Replace a worn spring-chain connector.
  4. Check to ensure that the spring pulley turns freely and is not worn excessively. Refer to the "Spring Pulley" section if you have to replace the pulley.
  5. To reinstall th spring, connect it to the end of the step chain using the master link.
  6. Route the spring under the spring pulley.
  7. Hook the end of the pedal arm return spring onto the spring hanger. WARNING: Do not twist the spring during installation. It will wear excessively and reduce the life of the spring.
How to Replace Pedal Arm Return Spring on Stairmaster 4000PT
What is the power source
The following link will take you to the power supply. You can review the product and also purchase when ready.
SM 4100 Power Supply SM25726 SPORTSMITH net
Feb 24, 2014 | Stairmaster 4100PT Stair Climber
I need power supply details
This link will take you to information for the power supply on a 4100PT Stairmaster stepper.
Aug 27, 2011 | Stairmaster 4100PT Stair Climber
I changed out a chain and spring on my stairmaster 4100pt. Now the unit will not turn on. Is there a reset button somewhere?
You may consider retracing your steps to see if, while removing and then installing those components, a wire(s) didn't get bumped loose
Dec 23, 2010 | Stairmaster 4100PT Stair Climber
Stairmaster Spinnaker 3000 CE exercise bike user
http://www.sportsmith.net/images/product_support%5Cstairmaster%5CManuals%5C3000CE_3600RC%20Spinnaker%20Manual.pdf
May 02, 2009 | Stairmaster 4100PT Stair Climber
Stairmaster 4100PT Stair Climber Logo
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
