Question about Dryers
How do you take the heating coil out to replace it?
  • 822 Answers
Depends on make and model..............
cheers
Posted on Mar 27, 2011
Heating coil
No matter if u not findout the inside or outside coil then u can check by multimeter its positive or -ve points
Jun 09, 2013 | Hotpoint Aftermarket Clothes Dryer Heater...
The dryer is running fine but is not heating at all. does the heating element need replacing
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Sep 10, 2010 | Frigidaire FER641FS Electric Dryer
Heating element. How about just replacing the coil?
you can get a re-string kit if its the open type heating element round pan style and re-string it yourself for about $30-$40
May 27, 2010 | Dryers
TUMBLE DRYER NOT HEATING UP
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil. You should read continuity across the terminals, if not you will need to replace the coil as it is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine. I will include these two websites for parts and further help:
Dec 04, 2009 | Dryers
Hotpoint tdc 32 not heating up , replaced the two thermostats , worked for a couple of weeks now no heat again , thermostats are ok
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Oct 26, 2009 | Hotpoint Dryers
Kenmore dryer,timer replaced 3 yrs ago,motor rebuilt one year, does not heat
Good Luck,
Hope this helps
Oct 22, 2009 | Kenmore Dryers
No heat
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 16, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer isn't heating up
Good Luck,
Hope this helps
Oct 14, 2009 | Kenmore Dryers
WONT HEAT, DRYER WILL TURN BUT WONT HEAT UP.
Good Luck,
Hope this helps
Oct 13, 2009 | Maytag PYE2300AY Electric Dryer
Coils don't heat
The control knb are being worn need to replace it the terminals are rusty conductance may not flow./not heating the coil.
Dec 24, 2007 | Jenn-Air Expressions AC110 Electric...
Dryers Logo
Top Dryers Experts
Marvin
Marvin
