Question about Samsung SyncMaster 920NW Monitor
How do I open a samsung syncmaster 920nw to get to the power supply
  • 11,361 Answers
You lift up the front bezel, just go around the bezel but do not completely remove it, just on three side, then lay it face down and snap up the back cover. Be real careful with the cable attached to the front bezel.
http://s807.photobucket.com/albums/yy352/budm/Samsung%20920NW/http://s807.photobucket.com/albums/yy352/budm/Samsung%20920NW/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 27, 2011
4 Suggested Answers
  • 32 Answers
SOURCE: Hi I Got a Samsung SyncMaster 920NW the display
If you are saying that it powers off in a few seconds you most probably have a bad (internal) power supply.
Posted on Jul 12, 2010
  • 406 Answers
SOURCE: Samsung SyncMaster 920nw suddenly went black now squeaks/flickers
This is the problem in the backlight (Lamps).
Kindly approach Authorised service center because this monitor is covered under warranty.
Posted on Nov 29, 2009
budmrtn
  • 11361 Answers
SOURCE: Samsung SyncMaster 920nw Comes on for about 5
Check the DC filter caps in the power supply-inverter section first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Posted on Sep 15, 2010
Samsung syncmaster 920nw 19 goes black after 2 seconds and power led is on
Its due to bad power supply. open your Led and remove old bad capaster and replace with new with same value. hare is link you can follow. http://www.youtube.com/watch?v=y1VbrAYc-d8
Jun 15, 2012 | Samsung 920NW Monitor
Power supply burnt
If the power supply burnt replace the ff. componets
Pico fuse, Bridge type diode and check all shorted and open componets of primary power supply before turn it on.
Sep 20, 2010 | Samsung SyncMaster 920NW Monitor
Samsung SyncMaster 920nw Comes on for about 5 seconds then goes black, power light stays lit
Sep 14, 2010 | Samsung SyncMaster 920NW Monitor
Jul 12, 2010 | Samsung SyncMaster 920NW Monitor
My monitor syncmaster 920nw hissing with power and diod not shine
I will suggest not to plug this monitor into the AC outlet until you open it up and inspect the inside before more damages are done.
First palce to look will be he capacitors in the power supply, look for bad caps with bulging top/seal or leaking, burnt parts, loose connection, etc.
See example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 30, 2010 | Samsung SyncMaster 920NW Monitor
My monitor syncmaster 920nw hissing when is power on and diod not shine
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Flashing power button on Samsung SyncMaster 920NW
Yes, More than likely the problem with the unit is blown capacitors on the power supply board, the flashing power light is a good indicator of this type of failure. Here is a link to a repair guide with pictures and videos showing how to open the unit and what to look for and replace to get it back going again.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
I hope this helps, if so please rate my solution.
BuddyMc
Feb 12, 2010 | Samsung SyncMaster 920NW Monitor
Samsung 920nw when it warms display disappears & a few
Most common cause of the failed monitors are bad caps in the power supply, if it is about two years old, I would open it up and look for bad caps first, then look for any burnt parts, post back so we can guide you further, see failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 28, 2010 | Samsung SyncMaster 920NW Monitor
Dark screen samsung syncmaster 920 N strange noise behind it
The clicking sound you hear is the power supply board trying to start up, this indicates the board has failed. This is a common problem with all LCD monitors after a few years of use. Parts called capacitors on the power supply board fail and they will keep the power supply from starting up correctly. If you can solder then you can repair the board yourself. Here is a link to a repair guide with pictures and videos showing how to dis-assemble the unit and then what to look for and replace to rebuild the board and get the unit back running.
BuddyMc
Dec 19, 2009 | Samsung SyncMaster 920NW Monitor
The 920nw did have a 3 year warranty on the unit but they will be out of warranty now. The flickering power light is an indication of a failure in the power supply board. When the board fails it can't start up correctly and the power shuts down over and over so you get the blinking light and no display. This is a very common failure point on all LCD monitors after a few years of use. There are parts called capacitors on the power supply board and they filter the output power. When they fail the power is not properly regulated and the power supply shuts down and tried to restart so you get the flashing. Here is a link to a repair guide that will show you how to dis-assemble the unit and then what to look for and replace to get it back up and running again.
The repair guide has pictures and videos to guide you through the repair.
BuddyMc
Nov 14, 2009 | Samsung SyncMaster 920NW Monitor
Samsung SyncMaster 920NW Monitor Logo
551 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
