Question about Maytag Dishwasher
I have a Maytag model MDB5000AWW dishwasher that we have been using approx 8 yrs. and it recently started to leak slightly. I have checked the levelness of the machine @ the top of the door and the inside front and there is a significant difference. I was wondering which spot is the proper one to set the machine level by. Any help would be greatly appreciated.
futureloginn
  • 734 Answers
SOURCE: Brand new dishwasher installed and water leaks out bottom of door
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Posted on Dec 12, 2008
futureloginn
  • 734 Answers
SOURCE: leaking dishwasher
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
subarufamily
  • 6 Answers
SOURCE: MDB7600AW water level
I'm not sure if it is suppose to fill above the heating element. The heating element may just be there to dry the dishes instead of heating the water. Try using a pitcher to fill the unit manually to above the heating element. If water drips out from below the kick plate then you know the water is not suppose to go that high.
Let’s say the unit is indeed under filling.
Check for a deformed shaft on the water level float. Remove the kick plate and look for where the shaft of the float touches a micro switch. Often the shaft is bent sideways and only engaging the micro switch indirectly. Straighten by hand for a temporary fix or reinforce the shaft with aluminum tape and sewing needle. Keep the retrofit light weight to avoid problems with water overflow.
Posted on Jan 27, 2009
whytfang
  • 170 Answers
SOURCE: I have a maytag mdb7100Aww. Dishwasher leaks at bottom of door
You definitely have to have a clean......float clean from all debris...it is very typical for the float to cause leaking problems ..as it is an overflow switch....also drying agents...that are used...especially if any is spilled inside will foam up and cause an overflow as well as liquid detergents that are not specified by the maker of your DW....these foam also....(if to much is used)...but the float will not push down on the switch if it is completely free from gunk.
I hope this helps.....good luck...thanks for rating my effort....the Fang.
Posted on Mar 29, 2009
  • 423 Answers
SOURCE: MAYTAG DISHWASHER LEAKS WATER AROUND THE TOP OF THE MOTOR
There is a sump gasket that has almost certainly worn out and will need replacing. This is not a simple task. Good Luck!
How old is maytag dishwasher model number mdb5000aww
Feb 19, 2010 was end date of that model you need the serial number for date of manufature
Oct 18, 2014 | Dishwashers
Hello! I have an issue with my maytag dishwasher model number MDB6100AWQ. It is running, and it goes to drain, and slowly starts leaking onto my kitchen floor! We took it out about a year ago and...
check the door gasket. check that it is draining. disconnect drain line from under sink ad put into a bucket. most likely it isn't draining ad is overflowing.
Sep 22, 2011 | Maytag Dishwasher
Works fine, cleans properly, last couple of times has big puddle of water over floor, seems to be coming from underneath machine. checked filters, hoses etc and all ok. machine is approx. 8 yrs old..
one some models such as kenmore or hotpoint, the door seals go bad (the black rubber things in the corner at the base of the door)
On others such as tappan and frigidaire
the little corner diverters come away from the base (they are semi clear plastic and
attach to the bottom of the dishwasher in each corner near the door).
Also if you have done a lot of dishes by hand the soap may accumulate in the sump of the dishwasher and cause it to oversuds causing soapy water to leak out the front.
If you use regular dish detergent instead of dishwasher detergent, this will occur as well.
Last thing to look at, especially on hotpoint, ge or kenmore is the shaft that enters the
side of the pump which is attached to a triangle shaped piece of plastic. The seal often
fails there and will require pump replacement as it is molded into the case of the unit.
Sep 19, 2011 | Dishwashers
My bosch dishwasher started to leak. Why? It is about 8 yrs. old.
it depends on the location of the leak.check the seal, check to make sure the unit is draining,check to make sure the drain hose doesnt have a pin hole in it.
Mar 11, 2010 | Bosch SHU9915UC Dishwasher
We have a MDB6000AWW model d/w. It is leaking
Yes what happens is it gets past the rubber seal somewhere higher during the cycle and gravity pulls the water down to where you see it leaking. 11 years is a good lifespan of a door seal. Plus they are easy to pull out and replace. Just yank it out and push the new one in. Hope this helps.
Jan 25, 2010 | Maytag MDB6000 Dishwasher
Water Leak at vent area in door...
On this model the vent is open and shut by a wax motor. The vent should be closed tight during the entire wash cycle and the first 6 minutes of the drying cycle. Check the operation, make sure there is not a bunch of gunk restricting it. If you are handy with a meter check the resistance of the motor. It should read approx. 2100ohms. Another reason for leaking at the base is oversudzing. Also check the upper spray arm for cracks or splits shooting water into the vent area. Catriver...post back.
Oct 23, 2006 | Maytag 24 in. MDB4000 Built-in Dishwasher
Maytag Dishwasher Logo
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
