My 347002K Robinair Machine will not Clear or Recover
    President:
  • 1,961 Answers
If the Clearing the Filter Screen will not dis appear,
then the problem is the compressor.
You can test the compressor using a vacuum gauge
and make sure of the 13" HG of suction.
Let me know how it goes..
Posted on Mar 27, 2011
I have a Robinair 347002K abnd cannot access anything under defaults. Defaults show as a menu item, but I can not see or select anything else under that heading I tried the 5454 password i saw on another...
You may did not try in the right way! The access code (5454) is 100% right for 347002K/347112K and 34700Z new series machines. If keypad has oil injection button (old series machine) press 8787 on keypad.
However you can try as following: To access the change Defaults menu press 5454 (If keypad has oil injection button old series machine press 8787) on the keypad then press ENTER/START arrow key. Now display will change to "Calibrate Scale". Press up or down key to select option you wish to access from: Set Tank Tare, Output Test, Input Test, Keypad Test. Prepare to Ship. Reset Board Memory etc...
NOTE: DO NOT CHANGE 'SET TANK TARE' OR PRESS 'PREAPARE TO SHIP' & RESET BOARD MEMORY' IF YOU ARE NOT FAMILIAR WITH THIS MACHIN!
Hope this will help you. Good luck!
Mar 31, 2011 | Robinair Cool Tech 34700Z Recovery,...
UNIDAD DE ALTA PRESION DESABILITADA ROBINAIR
This is a common problem of Robinair 34700Z / 347002k
Sep 28, 2010 | Robinair Cool Tech 34700Z Recovery,...
Machine says pressure exist unable to vacuum system down
It's not clear that you machine is doing recover or not! If the machine is doing recover theh follow the bellow steps.This is a common problem of Robinair 34700Z / 347002k
Sep 16, 2010 | Robinair Cool Tech 34700Z Recovery,...
High pressure unit disable
Aug 31, 2010 | Robinair Cool Tech 34700Z Recovery,...
Over charging won't recover scale don't work
It is not clear which model of robinair machine you have! However your machine need to re-calibrate the scale.
Aug 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
ROBINAIR 347002K WON'T INJECT OIL
I think you'v try to inject the oil from ''WRONG'' side,as you say RECOVER/VACUUM which is LOW side manifold valve. You should inject the oil from HIGH side ( Turn the high side valve to CHARGE/OIL INJECT after vacuuming & low side vulv to CLOSE possition ) with pressing F1 key. once you press it then hold the key as long as you wish to inject the oil. If you try this way & you still have problem with oil injection then you may need to check oil injection CHECK VALVE or oil injection SOLENOID ( Both located under Hidg side panel mountin valve). NOTE: UV Dye is not a problem for oil injection! I hope this will help you to solve the problem,Good luck. Don't forge to vote for my solution!
Jul 10, 2010 | Robinair Cool Tech 34700Z Recovery,...
My machine says high pressure unit disabled and will not let me advance
This is a common problrm of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant manually from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem
May 27, 2010 | Robinair Cool Tech 34700Z Recovery,...
Reads high pressure unit dissabled
Feb 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
Wont clear filter
If the clearing the filter screen will not go off then it is sure that compressor is not good.please check the compressor with vacuum gauge & make sure is has 13" HG of suction.
Aug 12, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair model 347002k has a problem with leaving a half pound in the vehicle after recovery. i have to recover again sometimes two or three times. what could be the problem. also the display says replace...
Please change your machine spin-on filter & vacuum pump oil immediately,becaus you already exceed maximum limit of filte.( NOTE:max.cap.of filter is 150 lbs ) if you keep using machine without changing filter then compressor will get damage at any time. Recovery is not compleating also because of that & do not skip clearing before any recovery.hope this will 100% solve problem.
Aug 07, 2009 | Measuring Tools & Sensors
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
