Question about Casio BabyG GM Cool and Tough #MSG300C7B1 Watch for Women
How do you set or change the time? - Casio BabyG GM Cool and Tough #MSG300C7B1 Watch for Women
How do i change the time on T5K801 Marathon watch
To set time and date:
1) With time and date showing,
press SET and hold for 2 seconds.
2) Seconds flash. Press START/STOP to set seconds
to zero.
3) Press MODE
Hour flashes.
Press START/STOP
to change hour, including AM (no symbol) and PM.
4) Press MODE
Minutes flash.
Press START/STOP to change
minutes; hold button to scan values.
5) Press MODE. Year flashes.
Press START/STOP to change year.
6) Press MODE
Month flashes.
Press START/STOP
to change month.
7) Press MODE
Date flashes.
Press START/STOP
to change date.
8) Press SET
, at any step, to exit and save settings.
With time and date showing, press SET
to switch between 12- or 24- hour time format.
Date (day of month) appears in upper part of display in Time
mode. Press and hold START/STOP
to see month, date, and year in large digits
Or go to:
http://assets.timex.com/user_guides/Marathon/W292-Marathon-AllLanguages.pdf
Jul 31, 2017 | The Watches
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
HOW TO CHANGE THE TIME ON MY DIGITAL WATCH IT HAS 4 BUTTONS ON THE TOP LEFT IS "LIGHT" ON THE LEFT "MODE" ON THE TOP RIGHT "START" AND ON THE RIGHT IS "RESET" THE...
Press "mode" until the hour is flashing,
Now press "start" to change the hour. When hour is correct, press "reset" and minutes should start flashing.
Press "start" to change minutes" then press "mode" again.
Oct 29, 2010 | Watches
Changing the hand time only w/o changing the digital time
For Casio Waveceptor:
--- A
( ) Button Reference
--- B
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
Good luck,
Techjoel
May 10, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Cannot change from 24 hour to 12 hour also did not change to daylight savings time
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
Rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
Jan 03, 2009 | Watches
Armitron WR165 watch - changing time
When you're in the regular time mode press "set". The secons should blink. Pressing "mode" brings you to the hour spot (hour should blink). Press "adj" to change the hour. To set the min., press "mode" again and the min. spot should blink press "adj" to change. Keep pressing "mode" then "adj" until all necessary time components are set correctly. Press "set" to get to regular time mode.
Aug 15, 2008 | Watches
Casio BabyG GM Cool and Tough #MSG300C7B1 Watch for Women Logo
107 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
