Question about HTC Touch P3450 Smartphone
I have problems in the screen aligmnet, when i press up right corner start again in the center of the screen
  • 90 Answers
It may be hard but you have to calibrate the screen, to do this go Start/Settings/System/Screen
Click Align Screen
this should bring up something that will allow you to readjust the screen usually with points on the screen you must touch
Posted on Mar 27, 2011
  • borrastito Mar 27, 2011
    Thanks, the problems it's that i can NOT make the screen past. I press center, upper left corner, down left corner, down right corner y the upper right corner I pressed and the back to center. I still doing that.
  • river vasquez Mar 27, 2011
    After reading through the manual i was not able to find any other way to reset the screen. I don't usually do this but i recommend in this case contacting HTC and asking if there is a way to enter the calibration during startup of the device.
Empowering Technology screen keeps popping up...can't get rid of it
Go to start,type in Msconfig and press Enter.You will see a box with a section labelled Startup.Click on that and look for Empowering Technologies in the list.Any with that description,remove the checkmark and the go to lower right corner of the box and click apply then ok,then restart your computer.That should fix your problem..good luck :)
Sep 01, 2014 | Acer T232HL 23" LED LCD Touchscreen...
Change language back to english on garmin gps
The language settings on a Nuvi 1300 series is changed from the Main Menu > Tools (tool box in the bottom right corner) > Settings (wrench in the top left corner) > Language (lips on the bottom center) > Text Language (top right button) > scroll up to American English > select and press OK.
Mar 20, 2012 | BoxWave Corporation Garmin Nuvi 1300T...
Its saying calibration problem on the screen
When the Reader device is started for the first time or is reset back to factory settings, the screen must be calibrated. The Reader device will display a calibration screen that requires you to touch the stylus to the center of an "X" at several points on the screen. This is to make sure the touch screen properly recognizes input.
The process requires you to touch the "X" in the following locations on the screen:
  • Top left
  • Bottom right
  • Top right
  • Center
If the screen is accidentally touched someplace other than the center of the "X" during calibration, the Reader device will display a message stating Calibration error detected. Please restart calibration process .
If this happens, please start again in the top left corner and touch the stylus to the center of each "X" as it is displayed, being careful not to touch any other part of the screen. After the sequence is completed the Reader device will display Touch Panel calibration completed . Click OK to continue to the next step in the setup process.
Dec 26, 2010 | Sony Reader Touch PRS-600
I have a 2001 sony 53' rear projection tv model #KP-53HS30. It seems has a wavy section on the upper left hand corner and lower right hand corner of the screen. All the bulbs are working fine but seems...
Try this. The follow was found on tv-forums dot com by Zyntar...
There is a secret service menu to converge the Sony KP53HS30.
Caution: Be careful, there are many settings that can be tampered with. Some may be hard to undo.
Procedure: (use the remote control for these steps unless noted)
1. Turn TV off with System Off (under flap on remote)
2. Press: Display, 5, Volume +, then Power. If successful, service text will appear on the screen.
3. Use 2 & 5 to select the PJE Category.
4. Press 9 to get to fine convergence adjusting.
5. Press 6 several times to get the convergence screen of choice. I like the grid.
6. Use the remote's arrow keys (joystick), move the brackets around until you have found the area to adjust. Press the center of the joystick to change the bracket from white to a color. Use the joystick to adjust the color. Press 3 to change color to adjust. When done, press center of joystick again.
Note: Try to keep the grid even and squared up.
7. Repeat steps 5 and/or 6 for all parts of the screen that need it.
8. Once done, you need to save your settings. Press: Mute, Enter. Then on the TV, press "Flash Focus"
9. Turn off power.
TV is ready to use.
Oct 20, 2010 | Sony KP-53HS30 53" Rear Projection...
When i turned on the leapfrog and asked me to log in my name it doesn't let me go in when i press it with the leapfrog pen
the screen needs to be re-calibrated. Do this: while powering on the Leapster, hold down the ? key. If it's been worn off, it's the round key on the left hand side above the t-arrow keys and it's the middle button. A new screen will come up that lists Base Info Cart 1 Info, Cart 2 Info, Cart 3 Info. In the right hand corner is a "A" that you can touch with pen beside it, it says "Touch Calib" Touch on that.It will say starting...then in the upper left hand corner there is a +. touch it with pen. it will move to bottom left hand corner. Touch it with pen. It will move to right bottom corner. touch with pen. It will move to upper right hand corner. Touch with pen. It will move to the center of the screen. Touch with pen. Repeat until you come back to the Base Info screen. You're DONE! Power off and on again and you should be all set! Good luck!!
Feb 28, 2010 | LeapFrog Leapster 2 Learning System
Unit does not turn on. There is power at plug . Slide switch left and right, no power, no screen
hook it up to the usb cable to your computer for a few hours, then try again. if that fails, press and hold the lower right corner of the screen, while pressing on the lower right corner, slide the switch to the on position for a few seconds, then follow the on screen dirrections.
bill
Oct 29, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Imate PDAL screen align problem
on align screen there will me + mark click on the center of that mark
first at the center after that left upper corner after that right upper corner
afer that bellow right and bellow left corner
dnt click any where on the screen just click on middle of the + sign
after clicking + mark will go on next place automatically
after all done of align screen u will go to next step of installation
best of luck bye tc
niketan237@yahoo.com
contact me via messenger or mail if u want more help
Sep 28, 2009 | i-mate PDAL Pocket PC
Bootmgr is compressed and press ctri+alt+del to restart
Hello ajay1 8 83
You need run SFC /SCANNOW
Read this first for more understanding http://support.microsoft.com/kb/936212/
Try booting to your Vista installation CD. Choose Repair. Select your operating system, should bethe only one. It will repair the BOOTMGR.
Jul 12, 2009 | Microsoft Windows XP Media Center Edition...
Garmin nuvi 200 frozen screen
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Mar 16, 2009 | Sony NV-U71T GPS Receiver
Enabling Bluetooth locked up
I had the exact same problem, very similar scenario. I seem to have fixed it by...
1. entering maintenance mode (press finger on upper left corner of screen during power up)
2. Press 'View Diagnostics'
3. Page to (Press 'Next' 5 times) Bluetooth Status Page
4. Press 'Updt PR'
5. Wait for 100% progress bar
6. Exit by pressing 'quit', then 'restart'
Good Luck
Feb 06, 2008 | Garmin Nuvi 660 GPS Receiver
HTC Touch P3450 Smartphone Logo
352 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
