Question about Acer Professional P211 21" CRT Monitor
Can't see the entire screen, so when adds appear I can not close them since I can not scroll to hit the close box
I can't figure out how to change from right hand click to left hand. Please tell me how to do it. thanks
start run control panel mouse/ buttons/ configuration
press ok............
cheers
Mar 27, 2011 | Computers & Internet
I have QuickBooks Pro 2005 and was able to easily export to Excel. That is no longer an option and I have to export to a cvs file. What happened and how do I fix it?
Open QuickBooks. At the top of your screen to the right you should see two black arrows next to your ICON's that say things like reminders, search and feedback. Do you see the arrows? Click on them. This will take you to another screen to add or subtract your ICONs or shortcuts. Click "add" and then scroll the options until you see "Export to Excel" and choose it. Then hit "ok" and close the boxes until you are back on your desktop.
Jun 17, 2010 | Intuit QuickBooks: Pro 2005 for PC
Function key bar appears on desktop screen
Start - All Programs - Toshiba - Utilities - Settings for Flash Cards
then just place a check mark in the box labeled "DisableToshiba
Flashcards"
Jan 06, 2010 | Computers & Internet
Black box appears on every channel
Hi:
This black box is the close caption box, you must of turned the feature on. Go into you menu setup screen and under CC option turn off Close Captoin, or you may have a CC button on your remote that you hit by mistake, try hitting this button until it says Close Caption off.
Dec 24, 2009 | JVC AV-32D305 32" TV
Black boxes on a few TV channels - connected to DIRECTV
Turn off closed-captioning. You'll find it's set for "text" right now, probably from hitting a button on the remote without realizing it. The set is blanking the screen for the text which doesn't show up. (In your case sometimes it does. You're the first person who's ever seen anything that I've responded to!) On channels and programs where captioning isn't being sent the box doesn't show up, so you don't know you have the trouble.
Apr 25, 2009 | Televison & Video
Black box in middle of screen
It's a text box for either closed captioning or demonstration mode. Go into the setup menu and turn off closed captioning. If you have trouble doing that, then just restore factory settings.
Mar 07, 2009 | Panasonic PV-C1322 13 in. TV/VCR Combo
Note that the large black box goes away when pushing buttons on the tv (ex: the black box will disappear to show the volume setting when changing the volume on the tv but it will cover the picture and the menu display of the dtv box).
This is caused by the closed caption setting of the television set NOT the captioning of the converter box. To fix this you must open your television's menu, find the ccd/closed caption option, and turn it off. This is a frustrating problem as when most people are told to shut off the captioning they try to do so at the box.
Normal dtv box captioning will appear as a small text box at the bottom of the screen as you would expect - not as a giant black rectangle that covers most of the screen. If you do want to shut this off too you will find that you can't do it through the usual menu options (the menu will only allow changes to font, color etc.) - there should be a ccd button on the remote that when pushed will scroll through ccd-1, ccd-2,... off.
Dec 01, 2008 | Toshiba MV13L2 13 in. TV/VCR Combo
On my TV certain shows (Craig Furgerson, Oprah, The View)on different networks,a black rectangle, about 1/3 of the picture, appears. I cannot remove it.
That box appears to be from the close caption feautre. If you have the original remote you can disable using the menu and go to audio functions and look for close caption to turn it OFF.
Do you have the user's guide for this TV?
If you do not, could you provide the model number of your TV?
Jul 24, 2008 | Sharp Televison & Video
Jvc flat screen television model AV32F713 Black box on screen.
On the reomte control (bottom) left of the sleep button is a cc button, push that until "OFF" appears on the screen. The close caption box should disappear. It worked for me, finally.
Nov 29, 2007 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Closed captioing
If you experience any of these please contact our customer care representatives via the On-Line Contact Form or call 253-2222 (Greater Portland) or 1-800-833-2253 (outside Greater Portland)..
Aug 18, 2007 | Arris DCT6200 DTV Receiver
Acer Professional P211 21" CRT Monitor Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
