First thing you must do is to get rid of the ice then if you look way back in the bottom of freezer you will see a drain trough and in the middle of it is a small drain hole. That drain hole is attached to a hose that normally takes the defrost water out and to the drain pan under the refrigerator.You have to clean out that drain hose.
Hi this is the drain, clean the ice out run bleach water through the drain make sure it, drains, you should be fine.
Sean
