Question about Honeywell Programmable Thermostat Heater
I purchased and installed a Honeywell RTH2300B programmable thermostat yesterday. My house is heated with radiant heat from a Peerless boiler. After installing it, I manually set the temp above the current temp and the heat went on no problem. I then set the time periods, etc. and I believe it went on over night accordinng to the schedule. This morning, it did not go on as scheduled (display said heat on but furnace did not go on). I then manually set the temp 8 degrees above the current temp. The t stat clicked and Heat On was displayed but the furnace did not turn on. The furnace has plenty of water and pilot is on. One last thing - I purchased the RTH2300B b/c I started to develop the same exact problem with a RTH230B after it worked fine for 6 months. Any ideas as to why I am experiencing this problem would be much appreciated.
5 Suggested Answers
  • 518 Answers
SOURCE: honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Posted on Mar 07, 2008
SOURCE: Non-deletable schedule in VisionPRO TH8000
The thermostat has a function called "Adaptive Intelligent Recovery".
This feature allows the thermostat to learn how long the furnace and air conditioner take to reach programmed temperature settings, so the temperature is reached at the time you set. For example: Set the Wake time to 6 am, and the temperature to 70°. The heat will come on before 6 am, so the temperature is 70° by the time you wake at 6.
You can turn off this function. Download the installation guide at the next link:
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH8321U1006
and look for funcion number 0530 Adaptive Intelligent Recovery. In this manual you also find the way to do a reset with the function number 0710.
I hope this solves your problem.
Posted on Jan 31, 2009
  • 148 Answers
SOURCE: honeywell air conditioner wont turn on. says following schedule
take the front face plate off wall it may have a reset button behind it
Posted on May 19, 2009
mikadot
  • 2113 Answers
SOURCE: i have a honeywell thermostat t6360.the light
Many thermostats have battery backup as well as the 24 volt ac. Have you replaced the batteries to see if it fixes all of your issues at once?
Posted on Nov 02, 2013
I have 2 wires coming from the wall, 1 white and 1 blue and want to wire a new honeywell 5-1-1 day programmable thermostat.
likely one wire to TH, the other to W if the thermostat operates on batteries. If the thermostat requires a 24 volt power source it is not compatible with your system.
Oct 09, 2017 | Honeywell Heating & Cooling
Honeywell visionpro
Um...., you changed the controller and it worked, then put the old one back and it doesn't work >> replace controller!
Oct 16, 2013 | Honeywell Electronic Programmable...
My honeywell timer for the back boiler heating is blank
need to contact the people who worked on it yesterday to come back and look at it again because it sounds like you have no power to now.
Jan 29, 2010 | Honeywell CT3600 7 Day Electronic...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Oct 05, 2009 | Honeywell Programmable Thermostat Heater
Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
Oil fired boiler
Check how all three "on/off" sequences are programmed firsrt, then all other programmable options. Make sure sliders are in the sliders are in the correct possition. If it becomes more complicated than launching a space shuttle, reset it. Unless your house is a mansion keep it simple with just day and night modes. the money you save wont even cover the cost to fix the hole you punch in the wall trying to do fancy programming ;-D
Nov 24, 2017 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Jul 25, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
134 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
