Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Smells of burning rubber - Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
My new hover floormate is running very loudly and it smells like burning rubber. it seems to be working okay otherwise.
If it's new ( as in less than 30 days ) take it back where you bought it and get it repaired or replaced. If it's over 30 days take it to your nearest Hoover warranty station. It shouldn't smell like burning rubber.
Oct 13, 2013 | Hoover Floormate H3000 Upright Wet/Dry...
Smells like burning rubber when running
Vacuum belts lose elasticity and will slip. It may spin the brush roll ok when you look at it but be so loose that when. Vacuuming carpets the belt will stop turning. The motor shaft is still spinning and will melt the rubber belt causing a burned rubber smell. Belts on almost All vacuums need. To be changed at least twice per year.
Nov 13, 2011 | Riccar 8955 Upright Vacuum
Work well but smell like a burning belt
If it smells like burning rubber, the belt is probably worn and slipping. If it's another burning smell, your motor windings are probably shorting and will burn out soon
Oct 12, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Bissell lift off bagless making high pitched noise, fan seems to run for 30 seconds after shutting off, and a burning rubber smell, is it the belt, and how easy are they to change
The burning rubber smell is usually the belt. Be careful not to use it on your carpet as the rubber belt can get hot and liquify and really mess up your carpet (if you have one). Here's a link to some instructions for replacing the belt.
http://www.ehow.com/how_4550054_replace-drive-belt-bissell-powerforce.html
Mar 15, 2010 | Vacuums
My vacuum cleaner is giving off a burning smell.
if its a rubber burning smell check the belt and the brushroll. if its an electrical burning smell then dont use it. the motor is overheating and will eventually get hot enough to catch fire.
Jan 02, 2010 | Vacuums
Our vacuum smells like burning rubber. Does it
Burning rubber smell means the brush belt need attention. Make sure the brush is turning freely and replace the belt
Jul 05, 2009 | Eureka Vacuums
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Burning rubber smell when the vacuum is on.
it sounds like the belt may be burning like the roller bar is stuck maybe or the belt is stretched and is burning itself off
Jan 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
70 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
