Question about General Electric Profile PFSS2MIXSS Stainless Steel Bottom Freezer French Door Refrigerator
I am continually getting a frozen sheet of ice beneath the deli drawer
    Scholar:
  • 116 Answers
Hi this is your water tank leaking due to it freezing from too low of temperatures, this particular model, had problems with damper assembly leaking, you will need to change out the water tank, but before you do that you need to fix the temperature problem, which requires adjusting or replacing the damper assembly in the back of the refrigerator at the bottom, You can install a bigger gasket or the new damper comes with one. If you need futher assistance let me know.
Sean
Posted on Mar 27, 2011
Deli drawer is stuck. Off-track. How to fix without breaking?
The Drawer might be frozen in the unit
Take out your food from the freezer and let it defrost for an hour or two then you might be able to get the drawer back on track with just a little tug.
Jun 04, 2015 | GE GTS22KBP Top Freezer Refrigerator
Items in deli drawer keep freezing
is the freezer freezing too? to much ice build up? if not check ur damper vent, make sure its not stuck closed or open to far, check the thermistors, the tempeture control thermostat, defrost timer and defrost terminator
Feb 19, 2015 | Kenmore Refrigerators
My Kitchenaid refrigerator deli drawer freezes everything, how can I fix this?
Check the air flow vents for ice buildup, this happened with my whirlpool fridge. Hope it helps.
Feb 03, 2015 | KitchenAid Refrigerators
Frigidaire French door model 28 cubic ft - deli drawer freezes cold cuts and cheeses. Model FGHN2866PF1
Hello friend, thanks for your inquiry!
I understand that you have a Frigidaire refrigerator, FGHN2866PF1, and your deli drawer is freezing items. You may want to turn down the temperature within your deli drawer, when adjusting the temperature could take 24 hours for your refrigerator to stabilize. If that does not resolve your issue I would suggest removing the drawer and checking over to make sure there are no cracks where too much air may be coming in. If there is too much weight in the deli drawer that could cause the drawer to sag, which may release cold air into the deli drawer. I hope this information has been helpfu. -Matt
Oct 10, 2014 | Frigidaire Refrigerators
My bottom drawer freezer is accumulating a sheet of ice
Your defrost drain line is clogged or frozen so the defrosted water is leaking into the freezer compartment and freezing into a ice layer in the next cooling cycle. Get your defrost drain line unclogged.
Sep 16, 2014 | Whirlpool Refrigerators
Ice under the deli drawer
it could be that u have a leak.. sometimes this happens when to much water is delivered to the ice tray and it overflows a little leaking into fridge. if that is happening then u most likely have a problem with the water inlet valve at the back of fridge, u can buy the part on line at appliancepros.com. good luck
Apr 13, 2014 | GE Refrigerators
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Jul 24, 2017 | Samsung RF265AA Bottom Freezer French Door...
Ice Sheet on floor of freezer
Check nothing is holding the door ajar, and that the door seals are closing properly all the way round. The abnormal thing about abnormal ice buildup isn't the fact that it's frozen - it's the fact that the water is getting in. The only way water is going to get in without you noticing it is in the form of moist air - and the biggest, most regularly disturbed way in for moist air is the door and its seal. A.
Feb 24, 2007 | Hotpoint HSS25GFP Side by Side...
General Electric Profile PFSS2MIXSS Stainless Steel Bottom Freezer French Door Refrigerator Logo
356 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a General Refrigerator Expert? Answer questions, earn points and help others
