Question about Eemax EX190T2 19.0kW 240V
It an Eemax instant electric water heater, it makes a loud clicking sound when it first turns on. Sometimes it clicks for 3 seconds then stops, even when we are not running water.
3 Suggested Answers
SOURCE: trips breaker
If it trips the breaker you MUST have an Earth fault and or a short circuit to Neutral/Earth. You must get a Registered Electrician to look at it.
Posted on Feb 03, 2010
  • 7 Answers
SOURCE: wher does white wire go
It runs off 220v, meaning there are two "hots" and a ground. The 190tc uses TWO sets of 220v at 40amps each. Instead of only having one dbl throw breaker, you need 2. Having said that... the white wire "should" be the same as the black wire and can be connected which ever way you like
Posted on Apr 22, 2011
Fuse for eemax water heater 24027
http://eemaxtankless.com/wp-content/uploads/2015/10/Eemax-Lowes-Manual-FINAL.pdf You should have an electrician install breakers (3) and wire unit. the unit is113 amps max draw. This is not a homeowner istallation.
Sep 24, 2017 | Eemax Water Heaters
I have a Eemax so 35 instant water heater and it makes a buzzing noise when you turn the hot water on
Heavy current required for instant hot water may be switched via a relay or contacter which may be faling. One way to diagnose may be with cover off and careful listening and visual inspection, but a risky process for inexperienced DIY'er's ??. Pro time?
Apr 11, 2017 | Eemax Water Heaters
My house has 200 AMP Service, will this work ok with the EEMAX EX380T2T2? It requires 4 40AMP Breakers.
your water heater will take a 160 amps of you service. I would not install one if it was me. The total demand in the dead of winter with furnace, water heater and lights on will cause you to brown out.
Oct 05, 2010 | Eemax EX380T2T2 Series 4 Whole House...
The center heating element is no working. How much does a replacement element cost?
the price will vary in different localities.
you should call a plumbing wholsaler in your area. Home depot and Lowes will not carry these, neither will you local hardware store.
the replacement is faily simple. Eemax is a nice heater, although faily expensive to opperate.
Aug 20, 2010 | Eemax EX280T2T Series 3 Whole House...
Fluctuating water temp. It is hot when I start the shower,
Iam guessing your using it faster than it makes hot water. May need a larger unit or a second one,in the system
Apr 10, 2010 | Eemax ELECTRIC DE-IONIZED TANKLESS WATER...
Eemax SP3512 not works intermintently, more off than on.
you have a clogged filter turn off the water on the unit on both sides, right below the unit there are 2 caps one on each side take the cap off there is a filter in side, clean it and reistall it that should take care of the problem, you might want to flush out the system while your doing this also
May 26, 2009 | Eemax Instant Water Heater 120V SP3512
No hot water
in and out hooked up right?
May 17, 2009 | Eemax EX280T2T Series 3 Whole House...
My circuit boards keep burning out.
Sounds like you are either getting power surges to the unit or there is an excessive amount of moisture around the control board. There also and probably is a short somewhere in the unit.
Apr 07, 2009 | Eemax EX280T2T Series 3 Whole House...
Eemax EX190T2 19.0kW 240V Logo
56 people viewed this question
Top Eemax Water Heaters Experts
Tim Whalen
Thomas Aldrin Nullas
Are you an Eemax Water Heater Expert? Answer questions, earn points and help others
