Question about Simplicity Sew Precious SWSP2 Mechanical Sewing Machine
The take-up lever on my SWSP2 broke. Is the machine still usable?
  • 11,800 Answers
Yes. Not only it's a simple part that every repair shop will be able to fix or replace , but the machine itself can function without it - you will need to manually raise the pressure foot. For that a great force will be needed , but only when raising it.
Posted on Mar 27, 2011
Simplicity sew precious parts
try the manufacturers website or google sewing machine parts
May 09, 2015 | Simplicity Sew Precious SWSP2 Mechanical...
My granddaughter received her machine from a friend and the bobbin plate is missing, how can I get a replacement part?
go to the website of
a1sewingmachines.com
they have a phone number to call, ask them if they can get you one.
Aug 28, 2013 | Simplicity Sew Precious SWSP2 Mechanical...
What is the bobbin size
go to sewingpartsonline.com, look for the name of the machine & then the model
number & it will show the parts for the machine & it should have the bobbins also
Apr 12, 2012 | Simplicity Sew Precious SWSP2 Mechanical...
How do you take the casing off of a simplicity sewing machine model S05
Unless you want serious problems don not attempt it, if there is a problem inside the machine take it in for repair
Aug 26, 2011 | Simplicity Sew Precious SWSP2 Mechanical...
I have a model SWSP2 and it will not pick up the bobbin thread. I have a manual and load it as it described but it still will not pick up. How does one get it to pick up and sew. Kat
Just check that the needle is in the right way, flat shank to the back. If you've accidentially put it in backwards, this will prevent stitches from being formed.
Other possibility is that the machine timing is out (service time) but try the needle first, it is an easy mistake to make.
Jul 12, 2011 | Simplicity Sew Precious SWSP2 Mechanical...
How do you thread the machine, top and bottom, please.
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin.
NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  1. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  2. Slide bobbin cover back into position.
Upper threading:
  1. Turn the handwheel toward you to raise the take-up lever to its highest position.
  2. Lower the presser foot.
  3. Place a spool of thread and spool cap on the spool pin.
  4. Place the thread into the first thread guide at the top of the machine.
  5. Bring the thread down the right slot of the threading path, then around the tension dial. Push the thread tension release lever and pull the thread up so the thread is secure in the thread tension dial.
  6. Bring the thread up the left slot of the threading path and through the take-up lever from right to left.
  7. Bring the thread back down the left slot of the threading path and into the needle eye from front to back. (Clip the thread end with sharp scissors fro easier needle threading.)
Raising the bobbin thread
  1. Make sure the presser foot lever is raised.
  2. Hold the end of the needle thread with your left hand. Turn the hand wheel toward you with your right hand until the needle goes down once and comes back up, stopping when the needle is at its highest position.
  3. Gently pull up on the needle thread. The bobbin thread, looped around the needle thread, will be drawn up through the needle hole.
  4. Push the thread tension release lever and pull about six inches of both the upper and lower threads toward the back of the machine, placing them under the presser foot.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Dec 10, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
How to properly thread the bobbin
  2. Pull about 6 inches of thread out from the bobbin. NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  3. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  4. Slide bobbin cover back into position.
Sep 21, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
Simplicity Sew Precious SWSP2 Mechanical Sewing Machine Logo
73 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
