Question about Hotpoint Aquarius WF215 Front Load Washer
Door lock light not coming on - Hotpoint Aquarius WF215 Front Load Washer
  • 822 Answers
If the door doesnt lock....then the interlock needs replacing.........
easy fix...........
cheers
Posted on Mar 27, 2011
Is a fuse blown when my power door lock doesn't work, along with the interior light coming on!
If the interior light is coming on I'm guessing you have a bad door switch. The door lock sees the door open so won't lock.
Feb 13, 2018 | Cars & Trucks
Frigidaire gallery washing machine door lock light doesn't come on
normally the door catch on washing machines have a switch attached to it ,if the door is not closed properly then the switch is not operated ,stopping the door lock light coming on
try slamming the door shut or check door catch for damage or hold /push and (hold )door shut to see if lock light comes on, if it does then the problem is door catch, adjustment or replacement only suggestions .good luck
Sep 27, 2016 | Frigidaire Washing Machines
How do I fix my interior light problem?
Hi.your interior light switches is in your door locks so it can be that your drivers door lock is faulty or the wires in the door is broken the wires runs in a rubber like tube there where your door hinge is you have to open the tube and check wires if its ok the chances is good you are going to replace the lock.hope this helps
Jan 09, 2016 | 1999 Audi A6
Load,close door,push start,door locked lights,start lights,wash light comes on yet it never starts.
Make sure the machine is able to fill. Check the taps are on. Check the machine on a spin only cycle. If it works , great, if not, it could be a dud door switch. Does the door actually lock when the "lock" light comes on?
Mar 10, 2015 | Bosch Washing Machines
Hotpoint WD640 Door Lock Light not coming on
check the door peg is not loose or it is the door lock
Apr 22, 2014 | Hotpoint Aquarius WD640 Front Load...
Self Clean won't start
Sounds like a control board problem
Nov 10, 2017 | DCS RGU-486GD-L Range 48", 6 Burner,...
03 gmc 2500hd 6.0 gas. truck is going crazy
Check door switch connection and operation.
If the door switch is part of the door lock mechanism, within the door itself, then remove door panel, disconnect the mechanism's electrical connector and re-check that the interior light no longer comes on with that door ajar. If it doesn't, then you likely have a faulty door lock mechanism, which you will have to replace.
This faulty switch will also have the affect on your random central locking function.
This is not likely connected to the engine performance issue.
Nov 03, 2012 | GMC Cars & Trucks
I have a 94 Cadillac Sedan DeVille and I'm trying to locate a switch or sensor for auto-lights and door locks. The doors would lock and the lights would come on when i put the car in drive. Can somebody...
On some model cars this normal I own a Dodge truck that does the same thing .When I open my doors the interior lights come on then when I start moving my doors lock.On some vehicles the doors will lock and the daytime running lights come on automatically.Some vehicles also have an automatic setting on the light switch.Like I stated on some cars this is normal.
Feb 10, 2011 | 1994 Cadillac DeVille
Maytag neptune washer
Doesn't your unit have a lock light in addition to an on light? On mine when you start the machine a red light comes on, then after a minute or two the lock light above it comes on. Once the lock light lights, the machine shouldn't stop. If only the initial light comes on, the door isn't locking. As a result, as the drum moves the clothes and they push against the unlocked door, it turns the machine off. You might need to check/tighten the door latch. Also check the door wax motor/door lock assembly.
Dec 10, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Hotpoint Aquarius WF215 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
