Question about Linksys WRT300N Wireless Router
Power light is dim and the 4 ethernet connection lights are bright green - even without a cab. Linksys WRT300N
    Sergeant:
  • 192 Answers
First try unplugging it for about 45 seconds. Then plug it back in.
If this does not fix the problem try to reset it via the reset button on the back and see if that fixes the problem. This will make your network un-secure and you will have to add a new pass phrase.
Let me know if this solves the problem.
Posted on Mar 27, 2011
Wireless light not activated anf ethernet 1 light open without any cord connected to it
it looks like firmware fault try to update the firmware to see if that helps
Mar 07, 2011 | Linksys WRT300N Wireless Router
The circuit breaker went off the other day, and when the power came back, the router no longer had wireless. The symptoms seem similar to most problems on here, with the power light on dim, and Ethernet 1...
You must have had a serious surge. Sounds like it's fried.
Use it as a door stop and buy a new one.
Sorry...
For future, while you're shopping for router, get a powerstrip surge protector and plug PC, monitor and router through it.
Jan 09, 2011 | Linksys WRT300N Wireless Router
Power light is dim and the 4 ethernet connection lights are bright green - even without a cable plugged in to them... removing power for more than 60 seconds and even hold ing the reset button for more...
I found this somewhere else but can't find it now - my router got hit by a power surge - i held in the reset button for 60 seconds with the power connected and it sluggishly decided to come back to life. WRT300n V1.1 - your results may vary.
Nov 07, 2010 | Linksys WRT300N Wireless Router
My linksys network switch is not connecting network computer, what can i do to get it back to work?
Do you have any activity lights on the Linksys? If not your switch has no power a hardware problem. Try to power off for 5 seconds and restore power on the Linksys unit. Try to shut down (do not restart) all computers. Are all the activity lights off? If not again power off the Linksys for five seconds and restore power. Power on the computers and verify the activity lights are now green for each computer. If the computers are not networked and the activity lights are green, check your network settings on your computers, which could have incorrect TCP/IP settings or workgroup. If one activity light is not green for that Ethernet connection, check your cable connection or replace the Ethernet cable. The workgroup should all be the same name. The TCP/IP address should be the same with the exception of the last set of host digits which should be unique to each computer address.
Jul 27, 2010 | Linksys SR224 24Port Ethernet Switch
Lost power on my WRT300N router. Power came back and now the power light is weak and all 4 port lights are on.
I had the exact same indications after a utility power spike.
Quite by accident, I discovered that the power supply to the WRT300N when fully seated into the router causes the lights (and the router!) to malfunction in this manner.
I pulled the power supply connection out gradually and the power light began to flash. Pulling the power supply even farther out eventually caused the power light to shine solid.
I don't know if this is a random manufacturer problem with just my WRT300N (V1.1) or if others may have a similar defect, but it's certainly worth a try!
Good Luck!
May 18, 2010 | Linksys WRT300N Wireless Router
Ethernet lights 1-4 are lit, wireless light out
wireless light will be ON only if you have connected any wireless devices to your network... security light will be ON only if you enabled password to connect to your wireless network.... if you have changed any settings in the router recently, then delete the saved list of networks in the computer.... then search for wireless networks in range and connect to your network....
Apr 19, 2010 | Linksys WRT300N Wireless Router
The power light is very dim and all 4 ethernet port lights are on and internet light is on too, but we are not getting any connection
If hard resetting it does not let the power light lit fully , then it already a hardware problem inside your router , no getting enough power. Bu dont worry it may just be too that the Power light led is just not lighting up properly.
Apr 06, 2010 | Linksys WRT300N Wireless Router
Cannot connect in any way to router, all lights on.
access your router's web-based configuration page at http://192.168.1.1
Sep 04, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT300N Wireless Router Logo
545 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
