Question about Amana ALG643RB Gas Dryer
My Amana ALG643RAW 120V 60hz gas dryer will not turn on. What is the problem and how can I fix this?
dididsaythat
  • 291 Answers
SOURCE: grinding
Could be front slides that act like a bearing to support front of drum or rollor bears in rear of drum.. wheels that supposrt drum in back
These pics may help some
http://www.pcappliancerepair.com/model-display.php
Posted on Nov 04, 2007
exspert
  • 55 Answers
SOURCE: trying to how to remove drum rollers on Amana ALG643RAW gas dryer!
ok if you go to a appliance parts shop take youe model number
and make they will give you a repalcement roller kit
snap ring hold the roller on , just replace them
Posted on Jan 21, 2008
ButtFuzz
  • 463 Answers
SOURCE: Dryer won't turn off when in automatic cycle.
Typicall there is a moisture sensor or equivalent that tells the dryer in automatic mode to stop (and not bake your clothes). Sound to me this sensor is defective.
Posted on Feb 27, 2009
buffalonyman
  • 1865 Answers
SOURCE: I have an Amana Gas Dryer Model # ALG643raw
Sounds like the flame detector sensor may have failed, but you really need a multimeter to test the components in the circuit to make sure you replace the right partt
Posted on Aug 06, 2009
SOURCE: amana gas dryer mod #NGD5240TQ0 intermitten heat
i went to a local appliance store asked them for assistance. they were more than helpful and sold me the parts i needed. fixed the problem for under $30.00. i also didnt have to pay for their ADVICE !!!
Posted on Aug 23, 2009
Need to convert a gas dryer from 120v 60hz to 120v 50 hz
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Aug 29, 2012 | Cars & Trucks
Need to replace blower fan on amana alg643raw dryer. Fan just spins on motor shaft when shaft isnt turning.How do I get it off
there is a set screw or a pin at the blower fan side that is locked to the shaft. try to unscrew it usually using a small allen key. if it is removed then you can now pull out the fan.
Dec 31, 2010 | Dryers
ALG643RAW NO heat, does not dry
If you have a gas dryer...
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 13, 2010 | Amana Dryers
Aug 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
YST-SW215
Do you have the input voltage switch set to 120V 60hz. There is a switch that should change from 120v/60hz to 220v/50hz. In the US this should be on 120v/ 60hz
Jul 02, 2008 | Yamaha YST-SW215 Subwoofer
Alg643raw gas dryer
try unplug and plug back in first let it reset and if that dont work, check thermal fuse may be blown..the fuse located in the back next to the fan in the housing. If fuse blown unit not work, if you go to www.appliancepartspros.com choose your model and it will give diagram of location termal fuse. check fuse first make sure is blown before you order it.
Mar 31, 2008 | Amana ALG643RB Gas Dryer
Trying to how to remove drum rollers on Amana ALG643RAW gas dryer!
you have to the top off the dryer to acess this part as well as the back entire cover once you remove the top and rear panel the rest is self explanable
Jan 21, 2008 | Dryers
Grinding
Nov 03, 2007 | Amana ALG643RB Gas Dryer
Amana ALG643RB Gas Dryer Logo
53 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
