KitchenAid KGRT607 Gas Kitchen Range Logo
Posted on Mar 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
KitchenAid Gas Range Model KGRT: Oven temp won't go past 260 degrees. When a higher temp is typed into keypad, it gives me an "err" mesage.
  • Johnny Direct
    Johnny Direct Nov 26, 2019
    On a KitchenAid KGRT607,open door, then press and HOLD broil. The manual Says press cancel then 1,2,3 then broil. doesn't say "hold broil". The manual is wrong on my oven. all I have to do is Open door and hold broil. Here is the link to the manual. Go to Page 19:http://pdfstream.manualsonline.com/e/e26...
Anonymous
Level 3:
President:
  • Master 2,468 Answers
  • Posted on Mar 27, 2011
Anonymous
Master
Level 3:
President:
Answers
2468
Questions
0
Helped
707541
Points
7484
Replace the oven safety sensor located in the upper left corner of the oven cavity,its merely a thermocouple and cycles the temp in the oven and is easily replaceable,its a whirlpool part # AP3083985 available from most appliance parts stores that handle whirlpool parts,as this unit is produced by whirlpool corp. for kitchenaid corp.
  • Johnny Direct
    Not the correct answer. I posted the correct above.
Manual for kitchenaid model kgrt 500
ManualsLib has the use and operation manual for the Kitchenaid KGRT500 free-standing gas range here: https://www.manualslib.com/products/Kitchenaid-Kgrt500-263024.html .
I hope this helps.
Oven gives err message when set above 275 degrees
Your range has been reset to celsius from fahrenheit. It must be reset to fahrenheit.
Press bake and broil pads simultaneous for approximately 3 to 4 seconds.
When SF comes on, press the broil pad.
You should see the Letter C.
Press again and the letter F will come on.
Press start.
Your range shouldproperly set the temprature now!
Oven temp is lower then display
kitchen aids website has the manuals available for download. page 33 has the procedure. opent eh dorr and hold "bake" pad for 5 seconds until you hear the beeb then press "bake" again for each 5 degrees you want it adjusted. If the oven is not hot enough add 5 if it is too hod make it a -5. the range is 35def farenheit either way.
I entered the "quick" option for self-cleaning my
It has a safety that will not allow the door to open while the temperature is high in the oven. oven temps can reach 700 degrees during the self clean cycle. allow the unit to cool completely and see if it works then. if not, let us know.
2helpful
Gas over not lighting
It is likely that the ignitor needs to be replaced. If the range does not sense the proper amount of resistance in the ignitor, it will not turn on the gas valve for the lower burner. If the broiler is still working, it would further this thinking, as it has a separate ignitor.
59helpful
5answers
Kitchenaid Superba Gas Range - Oven temperature problem
The problem is: the temp seems to be 'stuck' at 260 and will not allow any higher settings.
Calling KitchenAid proved to be unuseful. The manual did not have this item in the troubleshooting pages. Resetting the power does not help.
The SOLUTION:
There is really no problem besides that the temp display setting has been somehow set to be celsius (metric system) rather than farhenheit (english system). Changing this setting somehow can be easily touched off without knowing, thus the "I didn't do anything and yesterday it was working fine..." comment from family members.
The FIX:
Reset the temp display back to farhenheit (F). This is done by opening the oven door, then hold down the 'Broil' button until you hear a beep from the control panel. The same method may be used to change from Farhenheit back to Celsius.
Prevention:
I speculate the inavertent change of the temp setting is done while cleaning the flat control panel. So the best thing to do is to always 'LOCK' the control panel when cleaning the controls. This is done by holding down the keypad "3/lock" for a few seconds until the display shows LOCK.
(The solution was already posted when I arrived at this page. I just organized it a bit by adding some details and a preventative comment. Many thanks to those who posted earlier, solving my issue as well. I hope my writing presents a clearer and quicker read to the next person)
Can't set control panel to correct temp
its possible that the unit is set for Celsius degrees rather then Fahrenheit. althoug i didnt get full model number heres a link to a booklet explasining how to switch if needed, if this isnt for your model either check your owners guide or supply me with the entire model and ill lokk up for you. page 11 is where the F/C is explained
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209754287.pdf
Top KitchenAid Kitchen Ranges Experts
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
