Question about Kenwood Car Audio & Video
How to line in used - Kenwood Car Audio & Video
  • 391 Answers
Hello there can you be a little more precise i will help you if i can
Posted on Mar 27, 2011
Where can I get a diagram showing the brake line bends for my 1996 geo prizm.
Usually we take the OLD line off and use it as a pattern for the new one .
Sep 28, 2015 | Geo Cars & Trucks
Feature codes
Does the two-line display say "Line in use" when you try select the line, or is the indicator next to the line button lit (so to speak), or both? First, try Feature * 0 then press each line key to see if they really are assigned to lines 2 and 3... they could be other functions or multiple appearances of another line.
Jul 07, 2014 | NorStar T7316E Corded Phone
WILL NOT CALL OUT SAYS TO CHECK ISDN LINE WE ARE NOT USING ISDN LINES WE USE THE INTERNETWhat's your problem?
When you use the internet you are using a connection to your ISP (Internet Service Provider) over some kind of line whether it is a phone line using a modem or a cable for a cable modem. ISDN is just another way that you connect to the internet. ISDN stands for Integrated Services Digital Network. ISDN is a digital phone connection system and is often used to give you higher and more reliable service. So, what they mean is to call your phone company and ask them to check your line, that is all they mean. Remember, the Internet itself is just a huge set of connections using an unbelievable number of types of connectivity from phone lines to space based relays and how you get there is through whatever line you have set up between you and your ISP. Does that help?
May 23, 2012 | Polycom Viewstation Pvs-14xx & More...
Get "Connection Error" when making a call and the display shows a weird "2" below the baterry tower
hi....
There are 2 line which can be used in NOKIA 3230.This is used only when SIM card supports two subscriber numbers,that is 2 phone lines.
normally you can use only LINE 1 for normal use. You cannot make calls if you select LINE 2. You get 'connection error',This is because you have mistakenly choosen Line 2 for normal use .
please select line 1 so that you can make calls.
To Select the line please follow the steps
Menu---->Settings----->Line in use and select the line 1
thanx
Jun 20, 2010 | Nokia 3230
Where can i find a manual on how to replace the brake line on a 02 chevy s10 xtreme?
I'm not aware of a particular Manual that specifically addresses Brake Line for your Specific Vehicle.
However I have replaced several "complete" and "partial" Brake Lines in my years of experience.
Specific/Pre-Contured Brake Lines for your Truck are available at most auto parts stores. Calt them for availability and prices.
However these are somewhat expensive. YOU CAN 'MAKE' YOUR OWN LINES!
Also available at these auto parts stores are two (2) tools you can buy.
1) A Brake Line Bending/Shaping Tool.
2) A Brake Line Cutting/Flaring Tool.
These tools are very easy (and fun) to use.
The auto parts stores carry "Straight" "Bulk" Brake Lines in different sizes (lenght and diameter). They also carry Brake Line "male" and "female" Brake Line Connectors. Make sure you purchase the correct diameter size Brake Line and the correct Connectors to fit these Brake Lines.
If the original Brake Line that you are replacing has viable (usable) sections and/or connectors you can use, then use them.
Take the old Brake Line off using a flare wrench.
Check your Brake Line Connectors to see if they will properly connect to your remain system.
Measure this piece with a material measuring tape (don't tell momma!). Measure the straight Brake Line and using the Brake Line Cutting Tool, cut the straight bulk Brake Line. Using the old Brake Line as a reference: use the Brake Line Bending Tool to shape the straight bulk Brake Line into the desired shape, matching as close as possible to the original Brake Line.
BEFORE USING THE BRAKE LINE FLARING TOOL:
Place the proper "male" or "female" connectors onto the line, FACING the proper directions.
Using the Brake Line Flaring Tool: Flare the ends of the Brake Line.
Connect the "new" Brake Line using the flare wrench.
Make sure you Bleed the entire Brake System.
Let me know if this helped, or if you have any additional information or questions. Feel free to contact me at FixYa.com!
ps: Make sure you clean, roll-up and put away that material measuring tape!!
Feb 12, 2010 | Chevrolet S 10 Cars & Trucks
New vtech phone model cs6229-3 headset keeps saying line in use
These phones look at the voltage on the line to determine if the line is in use.
Do you have any devices on the line that get power from the phone line? If so, they may be loading down the phone line causing this issue. If you have these types of devices on your line, try disconnecting those devices and see if the problem goes away.
Otherwise, your phone line may be defective. You may need to contact your phone company to get the problem resolved.
Sep 13, 2009 | Vtech Cordless 6041 Phone
Second line not working
The phone will show that "line in use" message when it's not connected correctly.
If your two phone lines come in to one jack, make sure you are using a 4-wire line cord connected to the "line 1 and line 2" jack on the phone. You may be using a 2-wire cord so the second line isn't reaching the phone.
If the two lines are on separate jacks you need to connect line 2 to the separate "line 2" jack.
If you know for a fact that both lines are properly connected to the phone and it still doesn't see the second line, then it's time for a new phone.
Dec 10, 2008 | AT&T E2562 Cordless Phone
GE 29488
Note: Intercom features are NOT compatible when DSL is installed on line 1.You may need to reconfigure it for dsl internet if it is installed on line 1
May 27, 2008 | GE 29488GE2 Corded Phone
Car Audio & Video Logo
20 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
