Question about Microwave Ovens
I need an manual in English for my Becken Ceramic Hob 4vctcs60 & Oven AAE40001
2 Suggested Answers
dcramer531
  • 1654 Answers
SOURCE: I have a cata ceramic
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Posted on Feb 04, 2011
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
Ge microwave ceramic element
The service manual is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You can download GE owner's manuals and installation instructions here.
Dec 27, 2013 | GE Microwave Ovens
I have a problem with both my kuppersbusch ceramic gas hob GKE9851.OM 5 burner which has one burner that only lights on high and will not be turned down and my oven is one of those opthelmic or whatever...
unfortunately the oven is like a non stick fry pan
It still needs you to wipe over the surface after use
make a habit of using oven bags for cooking fatty foods as that saves the cleaning
as for the hob problem , get in a technician to fix the fault
Feb 06, 2018 | Microwave Ovens
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
the hob switchs off
Feb 04, 2011 | Microwave Ovens
I need an english manual for a corbero oven and hob set
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 31, 2010 | Electrolux Microwave Ovens
Replacement ceramic hob element C00228943 for Creda EDCW60 has 4 connections on thermostat in place of 2 on old unit. Do you have circuit diagram for this replacement element please?
Sounds like it is the wrong element. I wouldn't like to advise further without seing it. Contact your supplier and ask for an explanation.
Dec 24, 2010 | Panasonic NN-P794SF Microwave Oven
Hi, got old Eurolec Gas oven/hob. Hob lights up fine. Was cooking in oven all morning, no probs. Tried to light oven for evening meal & gas will not stay lit, goes out once ignitor & temp' dial...
Hi, your thermocouple is faulty, it is the little probe like thingy that sticks up into the pilot flame. It is there for safety purposes, detects flame and holds a valve open magnetically to allow the gas to pass through. Try giving it a clean with a scourer, sometimes works, or your pilot flame is not big enough, could be low on gas or unit needs a service Kristian KJ Tech
Sep 15, 2010 | Microwave Ovens
We require BECKEN microwave instructions in english
SOLD IN SPAIN/ PORTUGAL BY WORTEN, THEY WILL SUPPLY TRANSLATION BUTYOU MUST PUSH THEM, ALTERNATE TRANSLATE YOURSELF AT BABEL FISH TRANLATION .COM
Feb 03, 2010 | Microwave Ovens
Need users manual
I need a user manual & parts list for a Quasar microwave, Model # MQ9968W built in 1991. Is this manual available in a pdf format or in hardcopy?
Nov 26, 2008 | Goldstar MA-1112 Microwave Oven
Microwave Ovens Logo
442 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
