Question about Sharp Televison & Video
I have a Sharp LC-32SB220U tv, I downloaded the update file from Internet and save it in a pen drive and then I pluged in it to my tv trying to update, after this my tv didn't turn on if my pen drive it wasn't plug in, and now even with my pen drive plug in it my tv just turn on for a few seconds and then turn off by it self, what I have to do? Is it a fixable problem??
  • 71 Answers
SOURCE: Sharp LCD TV LC-37GP1U flashing green power light
Unplug the unit for 1 minute, replug and try again. If it doesn't work the power supply is faulted and it needs professional service.
Posted on Sep 22, 2008
SOURCE: Turns itself off
My sharp LC-AV134U Had the turn itself off symptom. I tried freezing and heating the board but I could not pin point the bad component. After a few cycles I could no longer replicate the problem and the set was working. This lasted about 2 weeks at that point suddenly the set was dead with a slight ticking sound. I found D631 was shorted I replaced it with an NTE 506. It has been running for 3 weeks now no problems. I suggest that everyone try a new D631.
Posted on Oct 21, 2008
SOURCE: Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Posted on Nov 10, 2008
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
  • 16 Answers
SOURCE: I downloaded on my USB the firmware update for my
yes
Posted on Nov 02, 2009
I need to update my TV Sharp LC-37LE320
Just download the update via sharps website then upload to a flash drive and plug the flash drive into the usb port on the tv. Then go to the tvs menu to update from usb.
Jul 23, 2016 | Sharp Televison & Video
Is the audio amp on the main board of a sharp lcd tv
A manual for a measure of the voltage line thats goes to the audioboard and there can be used a fuseresistor a resistor to protect the audioboard if .......
SHARP LC 32M44L LC 32SBB21U LC 32SB23U LC 32SB220U SUPP Service Manual...
Suc6
Oct 25, 2015 | Sharp LC-32SB23U 32 in. LCD TV
No sound on my tv
check the connector on the speaker might get loose, if ok re soldered cold soldered component parts in the amplifier section of the main board.
Aug 15, 2012 | Sharp Televison & Video
I have a Sharp LCD TV Model # LC 32SB220U. When you turn the power on, within a minute or two, it clicks off. I have tried everything in the instructions to troubleshoot the problem. I also reset to...
Check the high voltage circuit on the board that has the 120 volts input. The high voltage should be close to 400 volts - nothing less than 390 volts. The capacitor is failing to hold the voltage and needs to be replaced.
Oct 29, 2017 | Sharp LC Televison & Video
Need user manual for 42"sharp aquos lcd tv
Hi Rebecca,
Please click this LINK to download the Pdf file format of Sharp LC-42D65U User Manual.
Click "Download Document", enter your email add, enter the confirmation no., and then click "Download". It is a safe website, I used it personally.
Hope I helped you.
Thanks for using Fixya.
Jdvillanueva
Jul 09, 2011 | Sharp Televison & Video
HELLO,JUST I NEED TO THE FIRMWARE FOR MY TV SHARP LC-32D44U.HOW I CAN GET IT THE FIRMWARE? THANK YOU.
Here ya go:
  1. Download the latest firmware HERE
  2. Format a USB memory stick to FAT16
  3. Copy the contentse of the firmware zip file to the root of the USB memory stick (Root is the first view you see when you open the drive)
  4. Plug the drive into the TV
  5. Go through the TV menu and find the update firmware option
  6. Pray the power doesnt go out
May 09, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp tv wont recognize pen drive
how to operate the pen drive on television sharp??
Nov 26, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Sir, i want to install Windows XP Service pack 3 through the help of Pendrive. So please help me to solve the problem
If you have the SP3 installed on the pen drive and you are trying to install it then you should have internet connetion because when you click on the exe in your pen drive it will start the installation using the internet connection.
( Note:- Remember the .Exe file does not have the complete software in case of the service pack installation. You have to have an internet connection. )
If you are trying to download it from the internet then follow the steps below :-
click on the link below and then click on the download button on the screen you see after that..
http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en
when the prompt comes up to run or save Save it on your pen drive and click ok and save the exe on your pend drive. now when you run this exe on any computer the windows SP 3 installation will start automatically.
Make sure your pen drive should be connected. When you are saving the SP3 exe
Make sure the path should be correct and it should be to the pen drive and not on the hard drive.
Let me know if it works ..!
May 12, 2010 | E-Machines eMachines Desktop PC
How to update sharp aquos lc32d64u firmware. won't read from usb device to update S0803271 to S0909081. firmware name is "SAL2A217.UVP"
I was able to successfully update my Sharp's firmware by using a USB drive that was:1) formatted in (fat, not fat32)2) had only the one update file (.uvp) and3) a small USB drive (4gb - other posts said 2gb or less)
Feb 08, 2010 | Sharp LC-32D64U LCD TV
Sound doesnt come out of tv when hookedup to cable box sharp tv
You must use the video and audio with their own separate cables. The sound is separate.
If you are following proper procedure, then you should contact the tech support for your set to find out if there is a defect somewhere.
Jerry G.
Nov 14, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Televison & Video Logo
137 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
