Question about Honeywell Eclipse MS5145 RS232 Kit Black with Power Supply Auto Trigger Codegate Software Handheld Barcode Scanner
Scanenr not functioning - Honeywell Eclipse MS5145 RS232 Kit Black with Power Supply Auto Trigger Codegate Software Handheld Barcode Scanner
How do I access the functions above the keys?
Depending on the calculator, some are colour coded, so to get the function you want, you hit the associated colour function key and then the key with the function. Some calculators have two different colours, so each key has three functions assigned to it, one without a function key, one with colour key 1, and one with colour key 2.
Good luck,
Paul
Jan 23, 2016 | Office Equipment & Supplies
My printer scanner , it will not scan the size of the paper scanned
This is common, there are two possible things going on. Under print preferences try to set the margins to zero. If you are looking for an exact size copy then you need a copy button on the "all in one printer." If you are just looking for a size you can use without reduction then the second thing to do is to try and define the scan aria. Many HP scanners will do a pre scan, you can then move the dotted lines around to define the text aria and then scan to PDF or some other way to save it and then print.
If the scanner is not recognized try restarting it or varifing that you are on the same network.
Mar 24, 2014 | HP Office Equipment & Supplies
How to update older ti-84 plus
The function keys originally have twp functions: One function accessed by pressing a function key directly, the other by first pressing the 2nd key then the function key.
With the newer operating systems, there is a third function associated with the function keys F1.F2,F3 and F4, but not F5 nor F6. This third function is revealed after you press the ALPHA key.
Jul 25, 2012 | Texas Instruments TI-84 Plus Calculator
Need codes for ht3916 to chage remotes
Description=Durabrand Home Theater System (HT-3916)
Remote.name=URC-6131nwB00 PVR Remote 2K
Remote.signature=PVR0PVR0
DeviceType=Amp
DeviceIndex=3
SetupCode=1568
Protocol=00 5a
Protocol.name=NEC2
ProtocolParms=24 null null
FixedData=01 e7 e7
Function.0.name=Power
Function.0.hex=c7
Function.1.name=Mute
Function.1.hex=e7
Function.2.name=Source
Function.2.hex=d7
Function.3.name=Channels
Function.3.hex=67
Function.4.name=Reset
Function.4.hex=cf
Function.5.name=Front (-)
Function.5.hex=6f
Function.6.name=Front (+)
Function.6.hex=5f
Function.7.name=Center (-)
Function.7.hex=57
Function.8.name=Center (+)
Function.8.hex=df
Function.9.name=Rear (-)
Function.9.hex=47
Function.10.name=Rear (+)
Function.10.hex=ef
Function.11.name=Subwoofer (-)
Function.11.hex=77
Function.12.name=Subwoofer (+)
Function.12.hex=ff
Function.13.name=Master Volume Down
Function.13.hex=4f
Function.14.name=Master Volume Up
Function.14.hex=f7
Button.8=Mute'null'null
Button.3=Power'null'null
Jul 23, 2011 | Durabrand HT-3915 System
What is the function of 1st,2nd,3rd,4th,5th gear?
the function of the gears are to transfer and convert energy created by the engine into momentum
Feb 12, 2010 | 2003 Toyota Corolla
Multimedia keyboard on function keys. Functions work with a key "Function" How to change "Multimedia keys first" on "Function keys first" ???
You can change the settings by going to BIOS. To go to BIOS, restart the system and as soon as you restart, start tapping the <F2> key located on the keyboard. This will take you to BIOS.
You can use the Function Key Behavior setting in the System Setup (BIOS) utility to configure the media control keys. The options in the Function Key Behaviour setting are:
Multimedia Key First - This is the default option. Press any multimedia key directly. For function key, press <Fn> + the required function key.
Function Key First - Press any function key directly. For multimedia key, press <Fn> + the required multimedia key.
Nov 01, 2009 | Dell Inspiron 1545 Notebook
Florescent light died on my scanner, glows a
The bulb is blown, it may function once in a while, but repairing may be too costly.
Your scanner has a 1200dpi resolution. There are similar, yet better scanenrs for less than $50.
You might consider an EPSON scanner/printer for under $50. Some EPSSON printers can also print CD labels, directly printing onto the CD!
Sep 28, 2009 | Plustek OpticBook 3600 Plus Flatbed...
Graphing inverse equations
In parametric mode you are not drawing one function, but two functions X1(T) and Y1(T). If you use the DrawInv( command either on X1(T) or Y1(T) you get a syntax error.
However if you are drawing functions in Funct mode you can draw the inverse of the function that has been graphed.
Here is how you do it.
[2nd][Draw][8: DrawInv] [ENTER]
The command appears on the home screen, and you need to tell it the function it will act on. To do so press
[VARS] --> Y-Vars [1:Function]
and select the function you want, say Y1, if Y1 has already been defined.
DrawInv Y1 [ENTER]
Both Y1 and its inverse will be drawn.
Hope it helps.
Sep 02, 2009 | Texas Instruments TI-84 Plus Silver...
I have mx310 copier/printer/fax/scanenr. i can copy and print but it will not scan. any suggestions?
I have a Canon Pixma MP470 and my scan control option is in the solution menu with the import option.
Try this: click start, click all programs, choose Canon utilities, choose solution menu, slide right and click on solution menu, your screen should show scan/import option, click on scan/import and chhose scan. I hope this is helpful, Good Luck.
Aug 26, 2009 | Canon PIXMA MX310 All-In-One Printer
Plz answer, thanks!!
Click the Office Button in the upper left corner. Click "Save As"
Click "Tools" and select "General Options"
function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); } function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); }
There you can set a password to open the file or a password to modify the file.
function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); } function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); } function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); }
Jun 25, 2008 | Microsoft Office Professional 2007 Full...
Honeywell Eclipse MS5145 RS232 Kit Black with Power Supply Auto Trigger Codegate Software Handheld Barcode Scanner Logo
19 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
