Question about HP Photosmart C6180 All-In-One InkJet Printer
Printer keeps restarting - HP Photosmart C6180 All-In-One InkJet Printer
    Sniper:
  • 52 Answers
Perform a partial reset Perform a partial reset to restore the product settings to the default values.
1. Write down any fax numbers and country/region and language settings stored in the product memory.
CAUTION: A partial reset might remove all speed dials and other settings from the product memory.
2. Disconnect the power cord from the rear of the product.
3. Press and hold the # and 3 buttons at the same time while plugging the power cord into the rear of the product.
4. Release the buttons after 30 seconds or when Part NVM Reset displays on the control panel.
5. If the product does not turn on automatically, press the Power button ( ) to turn it on.
6. Press OK to continue the current task.
Next solution
Dowload the Firmware fix on this line. make sure it's connected over the usb cable.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=3737195#N260
Critical Update to Prevent an Error State When Connecting Your Printer to a Network
2009-07-16 , Version:1.0, 789.02k
This update will prevent your printer from entering an error state and displaying an error message on the Front Panel Display when connecting to a network.
Posted on Mar 28, 2011
  • a1224imac Jul 11, 2011
    Apparently some defective components were used in the construction of the logic board. On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers produced by HP around this time.
Won't ''delete''
you shoud connect your printer and keep power ON, they try to delete again, if still not clears, then clear from the printer side by using clear or reset button.
Even though some time you have to let the printer to Restart together with restarting computer.
Apr 29, 2015 | HP Office Equipment & Supplies
Buffer will not clear a deleted item: cannot print additional documents
Please attempt to power down the printer, first.
Wait 1 minute.
Restart your PC
Restart the Printer.
What type of printer is this?
Keep me informed as to the progress!
Jan 06, 2008 | Office Equipment & Supplies
Brother MFC-665CW All-In-One InkJet Printer keeps restarting
This could be caused by one or more of the sensors being unplugged or broken. You should get it checked out by a professional or look in the manual for Trouble shooting.
Feb 07, 2014 | Brother Multi-Function Center MFC-665CW...
My dell 725 printer prints constany when not called for.computer keeps coming up continue printing icancle it but it keeps pringing
try to restart the print spooler from services.msc
start>run>services.msc look for print spooler then restart it
see if that helps
Mar 12, 2011 | Dell 725 InkJet Printer
The unit keeps freezing up, and I have to keep restarting the unit (turning off and on). Do you know how to resolve this issue? Thank you!
HPM2727mfp - Printer Freezes or Randomly Restarts
The popular school of though is that the Formatter (CC370-60001) board causes the printer "to Freeze","Hang"or "Restart". I have repaired many of these printers, for this very problem by replacing this board. It may be possible to "bake" the board in an oven. The solder joints on these boards being the most likely cause. I do not recommend the easy bake oven repair.
It may be possible to have this printer repaired under an HP Extended Warranty Thru Mar 23, 2010
Please contact your local Hewlett Packard Repair Center.
HPPARTNERLOCATOR
Dec 07, 2010 | HP Laserjet M2727nf Multifunction Printer
Canon i9900 - have to restart every time in order to print
reinstall the printer driver and restart the printer spooler service also . make sure that c drive have more then 3GB memory to run the services .......
Oct 23, 2009 | Canon i9900 InkJet Photo Printer
Ink system failure & keeps shutting down & coming on its own.
Do the following, let me know if it clears or not:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
Keeps restarting
I do not know about the screeching part, that could be part of the problem or completely independent of the problem. When my machine kept repeating the "startup" process, it was because my bulbs went out. The printer then would never get warm enough to melt the ink to begin printing, so it would just keep restarting, and restarting the warming up process. One way to tell is to take off the side cover. Then peer into the side and see if you see a bright light - which would be your bulbs. I have no idea though what to tell you about the screeching thing.
Jun 03, 2009 | Xerox Phaser 8200 Laser Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
588 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
