Question about Espressione Cafe Chic 1377
I have a cafe chic machine and lost the users instructions - can I download same and from where?
User manual
Contact the manufacturer, that's the only place youll get a users guide short of buying a new machine. Or maybe just fiddle around with it and learn on the fly.
Feb 04, 2014 | Ariete Cafe Retro Espresso Machine
Sansui chic special 300 suitable remote
I lost my sansui tv chic special 300 remote, can u tell me which num remote can suit for my sansui chic special 300
Oct 05, 2012 | Sansui 27" TV
I have lost the instructions for my cafe tosca machine. Is there anywhere I can download this?
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Oct 14, 2011 | De Dietrich LZ9619 Front Load Washer /...
Hi, I have a Cafe Chic coffee/expresso/cappiccinno maker that has not been working properly. When I try to make coffee, the water that is suppose to travel through the filter and coffee grains ends up...
obviously you have leaking steam valve, use my recipe for rearing it:
you should take out the knob first, than you try to disassemble the SHAFT of valve from the valve body, in this types(small espresso coffee machines) usually producer use conical valve, without seals she close metal to metal, when you get out the SHAFT you will see one line on the conical end. for repairing it will be enough to visit one metal workshop where they will take a small amount of brass from end and polish it. then you put it back and work again with your machine. During assembling valve change 2 o rings and put one fitting 1/4'' to block the shaft coming out.
PS: notice you only polish the SHAFT , don't let them to short the more than 0.5 mm
Mar 03, 2011 | Espressione Cafe Chic 1377
On/Off switch for pump on Cafe Chic not working. Can I replace it myself and if so where can I get it?
Depending on the switch yes you can and most likely place to find a replacement is radioshak.
Sep 14, 2009 | Coffee Makers & Espresso Machines
Need in structions
send your email and I will send the user guide to you. trishg37@verizon.net
May 10, 2009 | DeLonghi CAFE DUO Dual Drip Coffee Maker
I lost my installation CD
Amanda, You can download the Groove application software which contains the driver from the manufacturers UK site: http://www.perstel.co.uk/downloads/GrooveInstall.exe Let us know how it goes and please don?t forget to rate the posting.
Jan 07, 2007 | Perstel Chic MP-10MP3 Player
Espressione Cafe Chic 1377 Logo
46 people viewed this question
Top Espressione Coffee Makers & Espresso Machines Experts
Douglas Dinnebeil
Douglas Dinnebeil
Tom Chichester
Are you an Espressione Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
