Hi there the main drive belt came off, i put it back on but now the machine is making a noise, should i replace this belt, thanx
    Genius:
  • 1,044 Answers
Yes, replace this belt. Make sure while fixing a new belt it is tight enough.
Posted on Mar 27, 2011
Blows breaker and groweling noise
It sounds like the motor is bogging down due to bad bearings or something is making the shaft too hard to spin. Make sure all the spindles are free. If its happening under load, make sure the lathe gets up to speed before trying to make any cuts.
Oct 18, 2012 | Ammco Combination Disc/Drum Brake Lathe
Hotpoint WF541 very loud on final spin. I have just replaced the door handle and the lock on the above machine, which went fine, however now when the cycle is on the final spin it is much louder than...
Hi. Check if the seal is properly installed back and glass centred. Loud noise is usually related to main bearing going bad. Check for belt tension.
Apr 27, 2017 | Washing Machines
Hi i have a simpson top loader washing machine it fills up fine but the motor does not start but when i take the main belt off it runs good but when i put the belt back on it makes a terrible hummmming...
If you are convinced that the agitator movement is free and also that the motor TORQUE is low then the motor is faulty. If this is one with a capacitor drive, then it can be weak and so a similar value can be looped in parallel to test. If not replace the motor even when tested on bench supply it does not have torque.
check for spares:
http://www.espares.co.uk/advice/washing-machines/a/7
Sep 23, 2011 | Kitchen Ranges
Washing machine makes terrible noise please advise
where the noise came from during the spinning time? if is spinning time,check the foot of your unit if is unbalance and adjust it,if is ok but the noise still in der the belt of the unit is wort out check the belt is is loose,remove cover the the back to check,if is belt is ok,the bearing have big problem and need to replace the new one,but you need an technician to remove it coz very difficult to remove this,need to dismantle the hole unit to remove the bearing and replace it that why the technician can do that
Dec 24, 2010 | Zanussi WJS1265W Front Load Washer/Dryer
Maytag Neptue frontloading washing machine model MAH5500BWW stopped spinning (machine is about 15 years old). I opened up the back and saw the drive belt was thrown. Reinstalled it (perhaps badly) and...
i would say you have a warped main pulley, run the machine in spin,watch it early to detect any wobling in the belt should be no sideway movement. also check main pulley is tight with no lateral wobling.
Dec 21, 2010 | Washing Machines
Hi there i have an 18hp 42'cut power kraft deck probleme
Hi ! I have the same mower. It is an older machine and possibly the belt that drives the mower is worn. The belt drive is spring loaded and when you engage the mower by lowering the lever, aspring pulls the deck backwards against the blade. If the belt hasn't been replaced in a while, I would start with that first.
Apr 08, 2010 | Mtd LAWN MOWER PART # 791-180705 Assembly,...
Hi,i have a hotpoint aquarius wf340.which makes a very loud banging noise every time it spins,it works fine otherwise!
I had the same issue with a similar machine. Need to replace the spindle assembly (or otherwise make sure) that the belt is tight. Try replacing belt first.
Make sure machine is level. test it by putting some stuffed sockes in the machine, let them get thrown around. Listen for the banging noise, apart from the soft socks hitting the tumbler.
Aug 08, 2009 | Hotpoint Washing Machines
Washin Machine Spinning Problem
The main tub bearing is stuffed, thus the noise. The spindle becomes loose and the belt rides off. Bearings can be replaced.
Hope that helps.
Sep 07, 2008 | Hoover AL130 Front Load Washer
Rattling
Level the drier, check the drum for foreing objects, check your belt and replace if need to. Check your rear drum seal, and your drier idler pulley, and replace if need to.
Jul 05, 2008 | Kenmore 98702 Stacked Washer/Dryer
HP 1050C , GRAINDING NOISE.
main pca in electronics module is defective.
must replace
May 08, 2008 | HP DesignJet 1050c InkJet Printer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
