Question about GE WCVH6260FWW
GE washer WCVH6260FWW. I thought I had a leaky boot seal, but as I took things apart I found that the outer plastic drum housing was being eaten away by the inner metal drum housing either due to uneven loads or the bearing for the inner drum may be shot? I guess my first question is "how do I remove the lower support springs?". It looks like they twist to remove, but I don't want to break them in the process. The next question is (once I get inside that drum) is "can I replace just the front portion of the outer plastic drum, or is this only replaceable as an assembly?" I can take and send pictures if needed. Thanks!
  • 1 more comment
  • jimhausch Mar 27, 2011
    I will give that a try and get back to you. Thanks.
    You called it. That "spider" was broken into 3 pieces (and looking pretty gnarly, too). There is a little wear on the back plastic tub. Time to shopping for parts. . . . any recommendations?
    I have been shopping for parts and can't find that "spider" on any of the exploded drawings. I am guessing it is only available as part of the metal tub? If you know where I can buy just that part, please let me know. My email is my user name "at gmail dot com".
    President:
  • 2,468 Answers
Your problem is more than likely the inner drum spider that holds the inner drum onto the shaft thru the bearings to the rear to the drive pulley,you need to remove the rear access panel, the drum pulley then remove the nut and c clip,then pull drum out the front,the spiders on these are pot metal and when they corrode from water/soap/detergent and break this will let the inner drum erode the outer plastic drum,you can more than likely move the drum side to side and up and down,get this checked out as if it come loose it can fly apart in spin cycle,as for the springs,there are pins there and need to be depressed on the pin side and removed,this is the fourth G.E. washer I have found with this problem in this model
Posted on Mar 27, 2011
  • danny Hendrickson Mar 29, 2011
    you will need to purchase the entire tub as the spider is not available separately,i believe you can get it at "www.appliancepartsp[ros.com" or 1-877-477-7278,i looked it up and it is #512 in the drawing #4 called the basket asm. and the spider in this drawing isnt visible,heres the clincher though $512.00 plus S&H
WCVH6260FWW drum sticking
you have an item in between the inner and outer drums if you take the heater unit out you should now be able to see it remove it
Jan 10, 2014 | GE WCVH6260FWW
Our LG washer is 4-5 years old. All of a sudden there is a slight scraping noise when the drum is turned. I can feel no resistance when turned by hand. It sounds like something may be between the stainless...
My LG WM-2277HW Front Load Washer had the same problem, I took it apart and it turned out to be heavy corrosion on the drum. just sand it back and it will be as good as new
May 03, 2011 | LG WM-2277HW Front Load Washer
Front seal not supporting drum, drum flops violently, doesn,t leak. seal wont stay on drum.
it sounds like you may have tub bearing issues or your suspension springs or shocks may be missing or broken. The front seal is just there for sealing, thats its sole purpose.
Basically there is two parts, the inner stainless steel drum and the outer plastic tub housing. Reach inside and see if you can move the inner stainless drum up and down any significant amount? If so the bearings are most likely shot. If its pretty solid but the outer plastic tub moves, its most likely a suspension issue. You can take off the top to get a much better view of the components.
Oct 24, 2010 | Frigidaire ATF6000ES Front Load Washer
Door gasket leaking
My GE washer model wcvh6400j0ww was leaking too. The repair person thought the same thing the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 20, 2010 | GE WBVH6240F Front Load Washer
Smell from water remaining in grey seal
My GE washer model wcvh6400j0ww was leaking. May be standing water under your machine. The repair person thought the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 13, 2010 | GE Energy Star WCVH6260F Front Load Washer
Removal of rubber seal
I take off the top cover unplug machine 1st ..Safety...Then take offretaining ring on inner drum /also ring on outer drum remove boot seal..Check utube video, explains in good detail...
Oct 07, 2009 | GE WBVH6240F Front Load Washer
Front loader making loud noise with spin cycle
It may be something that was in the wash and fell thru the holes in the inner drum. Check all the plastic agitators and make sure they are all secure and an attach bolt has not backed out of one and rubbing the outer tub. It will wear a hole in it fast if it is.
Usually when the bearings go bad, it gets very loud on the spin cycle, like a loud roar and sometimes clothes will have rust or grease stains on them.
I just replaced my tub bearings on my Frigidare and spent about $60. They are all pretty much the same. On mine they only list the complete rear outer tub assembly with bearings, but you can knock the old bearings and seal out and match them up at a bearing supply house or you can buy online. Online seems much cheaper. If you buy bearings, make sure you get ones with a -2rs on the end of the part number. ex. 6308-2rs. They are sealed and hold up much better in water environment.
I would give it a try, the junk man doesn't care if it comes in pieces or one big piece.
There are a couple online articles that can probably help you. Do a google search for 'washer rear tub bearings"
Jan 29, 2009 | GE WPXH214A Front Load Washer
I am considering purchasing a front load GE washing machine. I am curious if the inner drum and the outer drum are both metal? I am comparing the advantages of the GE front load with the Miele and the...
I can't speak for all, but my GE front loader has a stainless inner and a plastic outer tub. I don't know what the benefit of a all metal would be. The plastic outer tub seems to hold up fine, The only problems I have expereinced with the washer tubs were the bearing going bad after the seal failed, but its 10 years old. I consider that normal wear.
Jan 08, 2009 | Washing Machines
GE Front Loader rubber boot completely out of shape
You can replace the rubber door seal yourself if you are logically minded and are handy with tools. Isolate the washer from the mains supply. Remove the top fixing screws at the back of the washer. Slide the top of the washer to the rear of the washer and remove. Now you will be able to see the outer drum and the securing band to the drum. This needs loosening and moving clear of the outer drum so you can disconnect the seal from the drum. When you open the door, you will find see that the door seal connects to the washer outer body. You should see a holding catch probably made of plastic. This has to be removed and take care not to break anything. When re fitting the seal,you will find on the front inner edge a small hole, this must be in the 6 o'clock position. Working from the door access, feed the new seal on the outer drum and secure it with the retaining band that you removed earlier, at this stage do not fully tighten as you may need to readjust the seal later on. Now working at the door, feed on the door seal and position the small hole at 6 o'clock. If you find that the seal is twisting, then you will have to readjust the the seal on the inner outer drum. When everything is lined up, tighten the inner securing band then the outer retaining band by the door. Recheck that the small hole on the door inner lip is at 6 o'clock and both the door an outer drum securing bands are tight. This done, check for leaks by part filling the washer and then putting the washer on an emptying cycle. If all is well, then isolate the power to the washer and refit the the top of the washer and secure with the screws you removed earlier. On no account put your hands or tools inside the washer when it is on and connected to the power supply.
I have not yet replaced a door seal on your model of washer, but I have done quite a few and the process is the same. I hope you can follow these instructions and if you come across a snag, think about it and i am sure you will find the solution. You can always get to me at FixYa.
Oct 27, 2008 | GE Energy Star WCVH6260F Front Load Washer
Kenmore model417.41142000
I just went through kinda the same problem and when I took it completely apart I found the spindle hub was broken on 2 of the 3 supporting arms. they where just eaten up bad/corroded. I had to buy the tub/spin assembly which is the techincal name if you happen to need this part.once you pull tub house out of washer you need to split the tub and then you can see if this is the same problem I had
Oct 19, 2007 | GE WSXH208A Front Load Washer
GE WCVH6260FWW Logo
472 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
