Question about Sharp R-1511 Microwave Oven
Model R 1511 over the range microwave. My wife was heating water in it when it sounded like an M80 went off. Door popped open. I unplugged unit and allowed it to cool for an hour. Plugged it in and nothing. No light, no fan, no display. Pull unit out and opened case. Using a multimeter I checked fuse, blown, and I checked cut outs. The hood fan thermal cut out is bad. The magnatron cutout and fuse are fine. Should I replace the bad fuse and hood fan cut out and try it or could something else be wrong?
  • Sharp Master
  • 9,098 Answers
The hood fan thermal cutout is probably not bad. It should read normally open, unlike the others, which would read normally closed.
What probably blew the fuse was a blown high voltage rectifier diode.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
You can order the diode from Encompass here.
Posted on Apr 05, 2011
I have a magic chef microwave that heats well but when the door is closed it hums and get really hot on top while not in use. Eventually it will stop working all together until it cools down then I can...
This one actually sounds like the unit is cooking when the door is closed without blowing the fuse as it is supposed to do. Unplug it from the wall and let it cool down, which it probably already is. Put a cup of cold water in it, close the door and plug it in for one minute. Unplug it from the wall and check the water. Did it heat up? I'd bet that it heated the water up. Sometimes the cook relay sticks closed and it stays in cook mode. This condition is supposed to blow the fuse but really rarely it doesn't. I've only seen this happen 3 or 4 times out of about 14,000 units I have looked at in my career.
It would need a new control PCB and new door switches and probably a new magnetron.
Oct 11, 2013 | Magic Chef Microwave Ovens
I have a Sharp R-1511 microwave. The door latch began to melt when I was boiling water. When it cooled, it's rock solid and cannot open the door. Is it worth fixing or should I just buy new. ...
Actually door latch head and door open button problems are pretty easy for the do it yourselfer and affordable.
We have the service manuals you need at our site and you can download them free here and here.
You can order Sharp parts from Encompass here or the Sears Parts Direct Web site.
Jun 15, 2011 | Sharp R-1511 Microwave Oven
My microwave intermittently fails to heat the food. Unit runs and lights up but does not heat up food. Microwave is 4 months old. Problem just started a few days ago. tried every combination of buttons,...
Hello there:
It sounds normal, but there's no heat When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Many over-the-range microwave ovens suffer from intermittent problems caused by excessive moisture from the range/stove entering the microwave cabinet and collecting on the circuitry. Often the problem is with one or two simple connections that may need tightening or soldering. But, to repair these components, the microwave cabinet needs to be opened. So we recommend that you seek the assistance of a qualified appliance repair technician.
Dec 28, 2010 | Microwave Ovens
I have a Sharp Carousel Microwave Model R-1511. There is power to the unit, but when I try to operate, the blower doesn't work, the carousel doesn't turn, and there's no heat (the timer does count down...
Can you remove the timer panel?? Do you see screws to do that?? Make sure the unit is unplugged first. Then once inside check the door switches and the wires to them. Look for a switch that doesn't click when you push the plunger on the top. Or a browned wire terminal to the switch. That is where your problem will be.
Oct 20, 2017 | Sharp R-1511 Microwave Oven
Whirlpool gold accuwave microwave oven lost power afer running em
Hello Davisaroundt, we are sorry to hear about your Microwave not powering on. If you would like for us to schedule service for you, then can you please email your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool Accuwave Microwave Oven
Sensor error
I had the same exact thing happen...I put in some popcorn, it wouldn't pop. The screen said "sensor error". I tried heating water, a piece of chicken...nothing would heat. I unplugged it, plugged it back in...nothing. The manual says to close the door and hit the clear/cancel button. I could have sworn I had done that, but my wife simply hit the clear button and it started working again good as new. Hope yours does the same. : ))
Jun 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Oven turns on by itself when boiling water on stove!
Sounds like a mis-aligined, or defective door switch. I would suspect defective.
Jan 22, 2008 | LG LMV1650ST Microwave Oven
Home Circuit Breaker Pops When Door Is Opened
It does sound odd for it to blow the breaker. It should blow the fuse, not the breaker. But looking at the exploded view diagram, I don't even see a fuse! Makes me wonder if this is some foreign model. *grin* In any event, you will need to replace all the door switches since they all have been stressed by the same overcurrent. Also be sure that all the switch mount and door latch parts are activating properly when you open and close the door. The switches (generic replacements) are widely available from local appliance parts stores. If you need any other parts, you can see an exploded view and parts list here: http://www.geappliances.com/shop/prts/
Dec 16, 2006 | GE JE2160 Microwave Oven
Sharp R-1511 Microwave Oven Logo
66 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
