check the actual door switch,, you can jumper it to see if this is the problem, Just connect the 2 wires together , if this cures the problem replace the switch
if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
is the motor humming or did you start it like this before by spinning the drum,if so you have a bad motor,also is the door switch making a clicking sound when you push it in and out,it should if it doesn't you could have a bad door switch,read it out with a meter and make sure you have power to the motor,
Push the button manually and see if the light goes off . If it does , then the problem is the thermal fuse (a white slim piece of plastic with 2 wires connected to it ) located on the blower housing beneath the drum .
Ticking sound is the timer running--so it is not the problem unless a contact has failed or a wire has come loose. Broken door switch, thermostat failed in open position, or clogged lint filter/exhaust vent/outlet would keep unit from running. If you can hear the motor running but the drum is not turning then the drum belt is broken.
Could be a broken belt if you hear motor, also can be defective door switch. you can try pushing door switch with finger and press button If motor does not make a sound and pressing door switch does nothing you will need a volt meter and test for power if you hear moter then its broken belt or jambed drum. Try and manually move drum
