Question about Frigidaire Washing Machines
I have a Ffigidaire Gallery Model GL TF1240AS0. How to take out the Automatic Dispenser so I can clean it properly?
  • 822 Answers
Shud be a small doofer that you press down when draw is extended out...........
cheers
Posted on Mar 27, 2011
I have a 16 year old Frigidaire Gallery Side by Side FRS20ZSH fridge/Freezer. We get water to the filter but not to the door dispenser or the automatic ice maker. Help please?
this could be one or two problems :
fridge door that dispenser is in is not shutting all the way any longer and the safety switch is not allowing anything to come out of dispenser , or the valves in the bottom of fridge are bad (16 years it's time to go too) these valves are not expensive and not hard to replace , just remember to turn water supply off 1st see your local or internet parts supplier to obtain them
Oct 28, 2015 | Frigidaire Refrigerators
Ice aker ks, but does not dispense ice. fgidaire gallery, sde by side
Good Afternoon friend, thanks for your inquiry!
I understand that your icemaker is not dispensing ice in your Frigidaire refrigerator. I would recommend checking the dispenser chute, if there is a blockage of ice within the chute it would not dispense. When you press on the dispenser do you hear a noise? If you do that could be the auger trying to push the ice out, if you do not hear a noise it sounds like it be a potential problem with the dispenser or control panel. I would seek assistance from a technician to come out and properly diagnose your refrigerator. I hope this helps. -Matt
Sep 26, 2014 | Frigidaire Gallery GLHS38EGSB Side by Side...
The panel on the freezer side of my frigidaire gallery refrigerator Model No. DGUS2645LF3 shows "5b". What does this mean and how can I fix it. Nothing works on my refrigerator at the moment.
Thank you for your post, friend!
I understand that you are seeing a brown liquid come from under your dispenser area. I would recommend you having a professional come out to your appliance to check and assure the water lines are connected properly and not developing any moisture problems to form from under your dispenser. I hope this is helpful. -Matt
Sep 02, 2014 | Frigidaire Refrigerators
How do i fix the light socket to my Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range
Hi michell51238 - From what you are describing it sounds like the range may possibly have a faulty light switch or wiring failure that only a professional can repair. I personally recommend consulting a certified technician for a proper diagnosis and to move forward accurately.
Feb 22, 2013 | Frigidaire Gallery 30" Self-Cleaning...
How do you clean automatic soap dispenser?
Hello Sherri Ortwerth - I located the manual on the Frigidaire website. Here is the manufacturer link and it provides step by steps instructions in how to clean the soap dispenser drawer. If you have difficulties pulling up the requested information, I recommend taking off the last letter of the model number so you can pull up the data.
Feb 15, 2013 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire gallery front load washing machine that I purchased about 4-6 years ago. The softner will not dispense. I have taken the entire dispense unit out and have run hot water over it to try...
Add white vinegar to the dispenser and run a load. If that does not solve the problem take the dispenser out and soak it in a 50:50 white vinegar and water mixture for an hour
Sep 24, 2017 | Frigidaire Gallery Supreme GSTR1670DS 3.1...
The self cleaning instructions for my Frigidaire Gallery Pro Series Model FEB798WCCH do not inform how long to set timer. Any instructions would be helpful as I've never operated a self cleaning oven...
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
Mar 19, 2010 | Frigidaire 30 in. Electric Gallery Series...
What tuneup should I do at 65000
no tune up needed until 100000 miles. run a couple of fillups of Shell or Chevron premium gas thru it to clean out fuel system and clean engine. Walmart fuel station also have gas additive you can buy with your gas.
Mar 05, 2010 | 2003 Ford E150
Bleach dispenser
RU SURE ITS NOT WATER NOT BLEACH ,,THERE WILL ALWAYS HAVE WATER IN THAT DISPENSER
Nov 25, 2008 | Washing Machines
Water dispenser
limed up at end of spout/ clean lime out with small screw driver or somthing small to get in end of spout/ once lime is clean water will come out normal
Aug 05, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
