Question about Ironman Exercise & Fitness
I have an Ironman Envision. The TV display does not work and the screen is white. i can not watch tv, plus can not see what setting i have it on. The treadmill works great other than the display. also, no sound.
  • 31 Answers
SOURCE: Epic550 treadmill shutdown unexpectedly and display is blank.
Check the upright wiring harness on the right side. If the harness was routed incorrectly or care was not take during installation, the harness is pinched/cut/damaged when the right upright is bolted on. This is the main issue I encounter on this style treadmill when it will not work after assembly. Will require a new upright harness if damaged. If it is under warranty, call and have them replace it. It is covered
Posted on Jan 16, 2010
Testimonial: "The wiring harness was indeed pinched and the control fuse was blown. A little solder and a new fuse fixed the problem. Thank-you for the insight."
Arpi
  • 326 Answers
SOURCE: Sound but blank white screen
Hello, please contact your Philips Dealer ASAP. If you need more info please advice. Best regards, Arpi
Posted on Apr 26, 2007
wyoed1
  • 211 Answers
SOURCE: TV shut off will not stay on.
Sounds as though you have a video problem. It may be the convergence chips. The TV is shutting down do to a default in the circuit ( the set knows there is an error of somekind so it shuts down to protect itself). This is a problem that needs a pro trouble shooter since it could be in about any board. Sorry I couldn't help more
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
SOURCE: ROLLING TV SCREEN
After 2 days of problems with it, I finally fixed it by unplugging it and plugging back in! Works like new.
Posted on Apr 04, 2008
SOURCE: when powered off, TV turns on and displays white screen, then shuts off
I ended up exchanging the TV for a new one that works fine.
Posted on Sep 21, 2008
I have a 42" Envision Flat Screen. It shows the image on the TV didn't look like this yesterday. It showed shadows in magenta, yellow and white. The setting are set to the factory settings.
T'Con board fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 06, 2015 | Envision Televison & Video
My 6 year old 32inch envision tv no longer has picture or sound anymore even after its properly connected to cable
Based on the brand parts may not be available and six years is better than average life for this type of set.
Dec 12, 2012 | AOC Envision L32W461 32 in. LCD HDTV
What's your problem?lcd 32 in tv screen cracked but i can't feel the crack
This is the end of the set===screen is called a display panel and if available will cost more than a new set just for the part.
May 24, 2012 | Envision L32W761 32 in. LCD TV
Envision flat screen tv has 5 channels that don't play volume but show pic
Check the volute settigs to these channles. Check whether system set is compactable with input.
Feb 04, 2012 | AOC Envision L32W461 32 in. LCD HDTV
Screen Size on my Envision L32W761 TV is cutting off the picture.
Look on the remote for a button labelled ASPECT,P SIZE, ZOOM or FORMAT. Press it until picture is desired size.
Oct 04, 2009 | Envision L32W761 32 in. LCD TV
How can i recall multiple laps during a run?
The Timex Ironman 30 Lap also has a stopwatch that can be used to keep track of split times for racing sports like running or cycling. Press the "Mode" button until the display shows "Chrono," then press and hold the "Set/Recall" button. To start the timer, press the "Start/Split" button. It will continue to run even if you exit to another mode. Pressing the "Stop/Reset" button will stop the chronograph. To record a split time, press the "Start/Split" button again while the timer is running. To see your split times, press the "Set/Recall" button while the watch is in Chrono mode. You can then scroll through the various splits with the plus and minus keys. Press "Set/Recall" again to exit display mode and return to the timer.
Sep 17, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
When powered off, TV turns on and displays white screen, then shuts off
Sep 12, 2008 | Televison & Video
Envision remote codes
Try
10813
11365
10032
10039
10019
Feb 18, 2008 | iLO 3200 32 in. LCD Television
Exercise & Fitness Logo
195 people viewed this question
Top Ironman Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Jim Dowell
Techmotionusa.com
Techmotionusa.com
Are you an Ironman Exercise and Fitnes Expert? Answer questions, earn points and help others
