Question about Maytag Dryers
Maytag PYG2000AW dryer motor is not moving I already changed bad timer I think motor is bad every thing else sensors and switches are ok.
  • 822 Answers
Check motor brushes.............
cheers
Posted on Mar 27, 2011
Why doesn't the timer count down? The dryer runs & heats but the Timer doesn't move. I replaced the Timer block but nothing changed. Is this related to a bad sensor?
go bak to 4 prong. why did u change it out? souns lik this isa 220 unit and not a 110? chk the book that came with the unit. lol.
Jul 22, 2014 | Maytag Dryers
Maytag gas dryer model SDG4606AWW timer wont rotate on any cycle, dryer just keeps running until knob is rotated manualy to off, replaced timer and new one is doing the same, took dryer compltley apart,...
I don't have a Maytag schematic handy but there should be one on or in the dryer. Trace the clock wiring back until until you get voltage. I am betting one leg of the time motor goes to the drum motor (Gray wire maybe) and the other leg to the dryness sensor module (brown wire). Check these wires against both Line and Neutral. That should tell of it's the module or the motor block.
Nov 04, 2013 | Maytag Dryers
Maytag Dryer model DE212 no heat everything else works? Checked sensors and switch block on drive motor all seem to be ok how to test timer switch?
the heater element may of burnt through, or they may be a red reset switch on the rear of the dryer.
Nov 17, 2011 | Dryers
Dryer functioning but air not getting hot. this is a Maytag gas dryer
Things that could stop a gas dryer from heating:
Glow bar igniter, thermal fuse (not all models), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
On the back of the dryer near the fan blower housing is a thermal fuse, if this opens up (no continuity) the gas burner often quits but the motor will still run. If the thermal fuse is open/bad, always clean, change, adjust the venting system and vent hood first and clean out the dryer’s air ducts. Sometimes it is a good idea to replace the operating thermostat at the same time.
Thermal fuse parts help link...on blower housing cover, cannot be re-set, must be replaced if is open (no continuity between pins).
Thank you for contacting Fixya.com
Aug 18, 2009 | Maytag Dryers
Dryer does not start I already replaced the timer
First check the dryer push button on switch; next, meter the start relay and, the centrifugal switch on the front of the motor (this switches the start motor winding on; then off as the run winding takes over
Jul 01, 2009 | Maytag Dryers
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won't start and smells like something is burning
I'm having the exact same problem verbatium! did you ever figure it out. I already replaced the motor and the belt, but it's still doing the same thing.
Feb 17, 2009 | Maytag PYE2300AY Electric Dryer
Commercial dryer model #MDE26CSACW won't start
near fan blower ,had a fuse white by pass than try if work change it than clean the vent
Nov 13, 2017 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer MDE7400
depending on model, (mechanical timer or electronic timer)
Mechanical dryer timer has a tiny motor to advance it
many times service techs forget to plug in the timer drive motor when they replace the timer switch that it is screwed to
or they replace the switch when the switch is ok, but the motor is bad
Not a solution just something to check
the timer drive motor is a 2inch diameter press formed sheet metal device 1/2 inch thick on the rear of the timer switch
if there are wires hanging off, that is the solution
if there is no hum from the timer motor when you push the start button, replace the timer drive motor
electronic, not had one break yet
Jul 15, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
55 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
