Question about Acer Computers & Internet
I have an acer aspire 5100 and I get nothing on the screen apart from NTLR is missing Press any key to restart. I have tried using the back up disc made but it wont recognise it.
    Guru:
  • 859 Answers
Your boot.ini file is deleted. You probably did this accidentally or you were hit by a virus that does this.
You can boot using any wndows xp cd and when prompted in the status bar at the bottom press the appropriate F key to enter a repair console. Once you see the command window, type HELP
You want to locate the command that is something like fixmbr or fixboot scroll down until you are at the end of the help commands display and then type that command. It will find your windows installation and ask you to confirm it. It will then write a new boot.ini file and you can then turn off the PC, eject the CD and boot normally. After this, run a full virus scan or go to kapersky.com and run their online scanner.
Advise me of any clarification you need or questions you have before rating this and when successful, then rate this as Fixed.
Thanks,
Worldvet
Posted on Aug 04, 2008
How do I, restet the motherbroad on my acer laptop aspire 5100
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
Feb 27, 2011 | Acer Aspire 5100 Notebook
My 5100 won't go pass windows loading logo
Try to boot in safemode press f8 key on startup
When the Windows Advanced Options menu appears, use the ARROW keys to selectLast Known Good Configuration (your most recent settings that worked), and then press ENTER.
if this does not work you can try MSCONFIG (if boots)to try diagnose your problem
if worse comes to you can do factory reset at acer bios screen hold the ALT key and press F10 to start acer recovery
hope helps a little let me know if i can help further
Nov 06, 2009 | Acer Aspire 5100-5022 Notebook
Acer aspire 5100 will not run windows. It say's ''starting windows'' and then freezes. The recovery cd will not load. I'm able to load and run windows 98, but nothing newer. Thank you
ok
sir when upower up the computer press F8 key then u see safer mode if u are able enter in safe mode.
then u not need winxp recovery disk.
After enter in safe mode.
Go to satrt menyu then run then type in run "chkdsk /r" then press enter then press "y"
then restart the computer .
Also change the screeen resolution to 1024*768
some tiomes it is disaply resolution problerm.
So alos try "enable vga mode " u can see it when u power up the computer and press F8 key .
Try both my suggestion sir.
Thanks.
Apr 22, 2009 | Acer Aspire 5100 Notebook
About the Aspire 5100 notebook , Keyboard , USB port and Mouse pad not working , the problem apear when you power on , for exemple you want to go to BIOS , first power on then press an F something key on...
  1. Unplug all the device except keybord and monitor
  2. Press F2 and go to bios and you have restore the bios
  3. restart the computer, then it will be back normal.
Still have problem, just reply me
Thanks, PREM
Mar 21, 2009 | Acer Aspire 5100 Notebook
Rotation of screen acer Aspire 5100
First go to your graphics properties and make sure that screen rotation is enabled. then press ctrl+alt+(arrow key) and it will turn that direction.
Jan 17, 2009 | Acer Aspire 5100 Notebook
Hot to connect acer aspire mini laptop to digital lcd tv?
Press the Blue function key and toggle the screens. You can view, the Laptop, the Laptop and Screen, or just the screen.
Also you will need to flick through the channel button on the TV to get to the PC interface. Since you indicated you were using a VGA cable, this is likely the missing element.
Note: The VGA cable does not carry audio, you either had a separate audio interface to the TV or you were using RBG/Composite/S-Video/HDMI. So check to make sure you are using the correct cables.
Jan 07, 2009 | Acer Aspire 5100 Notebook
NTLDR is missing
You need to reinstall your xp or use the restore cds /dvds that came with the laptop to repair the windows startup problem.
Files missing / corrupt.
May 08, 2008 | Acer Aspire 5100 Notebook
Black screen acer aspire 5100
sounds like ye old mother board bit the dust, and with that sort of velocity, that's not unusual .does the video connection work for external video, by chance?
got backup for your Acer?
Feb 16, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
