Question about Kirby Vacuums
I have a kirby 2000 g limited edition, and I am looking for a hose that will fit it. Do you know the part number by any chance or another Kirby hose that is interchangeable? Any help will be appereciated. Thank You, Lori
SOURCE: kirby diamond edition - shampooer
1. Raise the vacuum head all of the way up. 2. Remove the vacuum head by removing the belt and releasing it. 3. Place the shampooer head on the vacuum by securing the clamp and them put the belt on 4. Take the bag off of the vacuum by twisting at the base just slightly outward and lifting upwards and unclamp it from the handle 5. Put water and cleaner into the water resevoir. 6. Put the reservoir on to the kirby where the bag was by holding it parallel to the vacuum then using both hands, twist it outward slowly until it goes down onto the unit then twist back to parallel position. 7. Put the coil looking piece on the shampooer head on top where the hole is...it will only fit one way successfully. 8. Put the other end on the under side of the water reservoir. 9. Lower the shampooer head all of the way down on the carpet just like you would the vacuum head 10. Turn on the vacuum and reach down and turn the knob at the top of the reservoir, this will begin putting cleaner (tons of foam) onto the carpet. Just work in 3' x 3' sections, turning off the foam intermitently until you are finished. I hope this helps.
Posted on Sep 03, 2007
SOURCE: need instructions
I used the information to help me get the belt back to where it needed to be. My daughter forgot to move the handle to belt off before removing the head. So now we are back and vaccuming up the Christmas tree needles. Thanks
Karen B
Posted on Jan 07, 2008
  • 112 Answers
SOURCE: dont know how to put the shampoo system together on my kirby g6..
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Copy and paste the above link to the address window of your browser for the Kirby Shampooer instructions.
Hope this helps :)
And thank you for using Fixya!!!
Posted on May 23, 2009
  • 430 Answers
SOURCE: How do I change the belt on my Kirby G 2000
Lift the head two pedal clicks off the carpet.
Lift the headlight and you will find a silver thumb dial to remove the carpet head. At the front of the head there is a square dial which you must rotate to release the belt if not broken. Rotate the square dial , then release the silver thumb dial under the light housing and the head will detach.
Flip it upside down to expose the brush and open the grate covering the brush. Note on either end there are colored leveling blocks for the brush. Reinstall with same colors showing.
Clean any hair and thread from the brush roll and insert new genuine belt. reinstall in opposite order, Be sure to turn the square dial backward to align the belt in a twist pattern before reinstalling the head onto the vac.Then lower onto carpet with pedal.
Posted on Sep 14, 2009
VacuumRepair
  • 438 Answers
SOURCE: how to change belt on the kirby ultimate g series
Hi There,
Here's a very helpful video that we've shot showing you exactly how to replace the belt on a Kirby Generation series, including your Ultimate G. The video also shows you how to perform basic maintenance on your roller brush to prolong the life of the belt as long as possible. If you haven't already purchased a belt, and need to buy a new one, here's a link to the exact belt that's used on your repair:
Kirby Generation Belt:
http://www.govacuum.com/kir184.html
Here's the video:
If you have any follow up questions, please feel free to use the comment section on this repair page, I'm always happy to answer follow up questions.
If this video helped you, please be so kind and rate my repair, or leave feedback for me. This is greatly appreciated.
Chris Jones
GoVacuum.com
Posted on May 01, 2010
Wgere would you find the serial # on the 2001 limited edition kirby .. THanks
The serial number is stamped into the upper motor shell just above where the bag assembly attaches.
Jul 13, 2011 | Kirby G6 Bagged Upright Vacuum
I have torn my file cabinet apart, and cannot locate my manual for my Kirby 2001 Limited Edition. I am trying to replace the belt, and need the manual in order to do so.
Kirby models are all very similar. The only manual I've been able to locate is for the G6. You can download or print it from the below link.
http://ubermanuals.com/search/contentsearch/kirby
Or check the belt change video at the following site. I recommend making this site a favorite for easy access to these videos.
http://www.kirby.com/Portals/0/videos.html
Mar 13, 2011 | Kirby G4 Bagged Upright Vacuum
My kirby shampooer doesnt seem to be placing foam on the floor like it should and it's not picking up any at all
Mine did that once and we were missing the filter part on the end of the shampoo hose attachment.fits on the end of the hose. Bought a new one at the Kirby store for cheap. It looks like a filter screen and without it just seems to soak the carpet without foaming up or cleaning it very well.
Oct 02, 2010 | Kirby Ultimate G Bagged Upright Vacuum
How do I change a balt on a kirby G 2000 Limited Edition vacuum cleaner
Here is a link to a video showing how to change the belt on a Kirby http://www.totalvac.com/videos/kirby-vacuum-cleaners-videos.htm
Sep 08, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Dont know how to put the shampoo system together on my kirby g6..
Hope this helps :)
May 02, 2009 | Kirby G6 Bagged Upright Vacuum
Need Manual for Kirby Vacuum
Printed, video and online manuals HERE.
Rocky
Apr 19, 2009 | Kirby G6 Bagged Upright Vacuum
Belt for kirby 2000 g limited edtion
I have troble resetting the belt on my Kirby 2000 vacuum cleaner
Aug 22, 2008 | Kirby Vacuums
Unclogging drains?
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic cup with two hooks on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier. Now, turn your massage cup (in your basic set of attachments inside out and hold it on the drain hole. If there is an overflow hole in the sink, you may want to cover it so that you won't be splattered with gunk. lol Now, turn the Kirby on and it will attempt to blow the clog on through the pipe. Sometimes it works...sometimes it doesn't. :0) Hope this helps...
Marci
Jul 19, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby Ultimate Diamond Edition G Series, upright. Problem: I lost my manual. How do I use my vacuum on hard wood floors? How do I use attachments, where do they attach?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=576029
Generic problem for all Vacuums
Posted by jlutsi on May 06, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can cal the Kirby factory to request a new owner’s manual and they will describe how to use the vacuum on hardwood floors. There is a felt piece as wide as the brushroll area that will clip on to the bottom of the revolving brush area so that you hard wood floors don’t get scratched. The Kirby head will dial off and the Kirby head will come off and the attachment hose will connect to the front of the Kirby and that is how you use the attachments. Also contact your local Kirby vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Don – The Vac Man
Go Ahead. Use Us.
May 06, 2008 | Vacuums
Vacuums Logo
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
