Question about Electrolux 23 in. ESI602 Free-standing Dishwasher
ESI 602 dishwasher trips out the mains trip switch after a couple of seconds after turning on any solutions please.
  • 822 Answers
Needs looking at.........bad earth can cause trip
also the rear element or stats wire can short against the machine casing.......
cheers
Posted on Mar 27, 2011
Fisher paykel dd603 - both drawer units just come on and won't turn off - turn off power several times at breaker - tried reset - turns off briefly then comes back on -
There is water collected at the base of the dishwasher which is tripping flood switch. Will need to disconnect power and take the bottom drawer out and dry out the base. Need to find source of the leak. Most likely the lid seal or hoses.
Oct 17, 2013 | Fisher and Paykel 24 in. DD-602 Built-in...
Hi I have an ADG 7540 dishwasher Yesterday, our kitchen sink was blocked, so the Mrs poured some sink unbloker into the sink and left it for 2 hours to soak through At somepoint - not sure if it was...
Hi Kris,
It certainly sounds like you have the diagnosis about right. Clearly there are still internal components that are wet and they are causing various short circuits that will cause trips and strange behaviour.One of a couple of things will have happened here:
Either the machine will dry out and return to normal operation (you would be surprised at what a soaking electrical equipment can take and still work once dried out) or the soaking has blown a controller board and the machine will need diagnosis and repair.
My first step would be to pull the machine out and leave it in a warm and well ventilated place for about a week (A conservatory is a great place for drying if you have one). After a week, try the machine and you will quickly learn if it has dried out and survived or not. If it is still dead, then call for a repairer.
A couple of things to note here:
Firstly: Be patient and wait the whole week. Every time you turn the machine on and it fails because a component is still wet, you run the risk of killing a component that had managed to survive the initial problem.
Secondly: If the machine is worth the repair, it is probably best to call out someone qualified. This kind of problem is a DIY nightmare and you can find yourself buying components that dont fix the problem, or worse, that you blow up, because the problem was somewhere else and all you did was put a new component in place for the fault to destroy. Better to call out someone who knows what they are doing, has test equipment and who will blow up their own components that they paid ffor rather than yours!
Sep 16, 2011 | Whirlpool 24 in. ADG7540 Built-in...
My crown 602 xls tripped a breaker, I reset breaker regained power to receptacle , I lost power to the amp no led's come on front when i pushed the small reset button on the back I still did not regain...
They use a breaker instead of a fuse.
http://www.retrevo.com/support/Crown-XLS-602-Amps-manual/id/19050ci763/t/2/
CONDITION: No
power to the amplifier.
POSSIBLE REASON:
• The amplifier's Power switch is off.
• The amplifier is not plugged into the power receptacle.
• The amplifier's high-voltage power supply circuit breaker has tripped. Verify that the AC mains
voltage is correct, then press the Circuit Breaker button on the back panel.
Take it to the ER.
Jan 12, 2011 | Crown XLS 602 2-Channel Amplifier
Code f1
Flood switch at the base of the housing has tripped.
Could be due to leaky door seal or foam in detergent.
Get the drawer out (turn off the mains power).
Dry base with towels and hairdryer.
Put everything back and try again.
Need to check the source of leak.
Please rate the solution if you found it useful.
Aug 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
Dec 09, 2009 | KitchenAid KUDR01TJ Dishwasher
Electrolux ESI 602 will not fill with water
The float better be inside the tub, at the bottom, it usually only travels a couple of inches up and down... you may have a protective cover in the way of it.
Jul 26, 2009 | Electrolux 23 in. ESI602X Built-in...
Trips mains fuse when switching on
Disconnect the heating element,remove lower panel and take the 2 wires off the heater and tape.Reset the breaker and turn it on,if it's ok you know the heaters bad if not let me know.
Apr 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
DISWASHER KEEPS BLOWING THE MAINS TRIP
FOUND SOLUTION...THE LITTLE CAPACITOR THING THAT SMOOTHS OUT THE FLOW OF ELECTRICITY TO MACHINE WAS BROKE. COST £5.00 FOR GENUINE HOOVER PART. FIXED EASILY TAKES ABOUT 3 MINS.....SORTED
Mar 25, 2008 | Hoover 24 in. HD83M Free-standing...
Zannussi de4744
Aquastop on water inlet tripped. Turn off and slightly undo main inlet hose. find water inlet valve and remove thin pipe from nipple. Turn m/c on for a few seconds, turn off and replace all pipes m/c will now fill and continue
Dec 05, 2006 | Zanussi 18 in. DE4744 Free-standing...
Electrolux 23 in. ESI602 Free-standing Dishwasher Logo
344 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
