Question about Pioneer VSX-818V-K Receiver
No picture through Pioneer VSX 818V. Hi I have connected a blueray th the hdmi input and the tv to the hdmi, I have sound but no picture or on screen display?
  • 961 Answers
Your receiver has 2 HDMI in with one HDMI out, 3 Component in and one out, and two difital optical in. If the bluray player has HDMI out this woukd be your best bet because HDMI carries the audio and video. If it has Component out, you would have to provde sound through the digital optical. Not knowing what blueray player or kind of tv you have, it's hard to advise so I may be over explaining. Anyway, we've touched on the bluray player to receiver. Out of your three HDMI slots on your receiver only one is HDMI out so make sure you're in the right one. Idaelly you have a DVD/blueray in on your receiver so on your receiver you would select "DVD" when playing. If your hook up is correct you may have to try another HDMI cable to test.
Posted on Mar 27, 2011
NO AUDIO
If it is the radio you are trying to get make sure you have an antenna that is strong enough and can receive the signal. With a digital tuner it requires a strong enough signal to capture any channels.
Sep 30, 2014 | Pioneer Vsx-520-k 5.1 Channel 3d Ready...
Pioneer vsx 519v
Are you sure the correct input is selected on BOTH the TV AND the A/V receiver?
Does the subwoofer work on other inputs? If not, is the subwoofer connected correctly? If so, is the input connected correctly?
Jan 31, 2014 | Audio Players & Recorders
Cannot get a display to appear
I imagine you can't see the set up menu to assign the proper type of video input (analog , composite , HDMI ) . On the 818 and previous series the set up menu will only appear through a Component (RCA green , blue and red ) or Composite (RCA yellow) BUT NOT THROUGH HDMI CONNECTION! That's why it will be necessary to run on of those two cable , match the input on the TV , on the Pioneer remote press Receiver then setup and the Menu should appear.
Hope i could help.
Jan 19, 2014 | Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
CaRC not working on my vsx823
With some of these elaborate setups, the receiver overrides your settings and connections to configure a default arrangement for certain functions. The rationale for this is often buried obscurely in the equipment instructions. You may have to resort to trial and error, connect and disconnect to get a satisfactory result.
Dec 01, 2013 | Pioneer Vsx-821-k Receiver
Hdmi signal keeps blinking
Check the physical conenction of the HDMI cable.
May 14, 2010 | Pioneer VSX-818V-K Receiver
Pioneer VSX 818V No Sound
First thing to check is the Speaker Select Switch. It will say, "A" "AB" or "Both" it will be displayed on the LCD screen as well. Second if that's ok, Check the "Direct" switch. If it's on, turn it off. Generally if it's on, you will see a blue light if it's on (most receiver's)
If you still have No audio, hook up your DVD to the "Direct" input and turn "Direct" on. If you have audio then. The DSP chip is probably bad and you should take it to a shop and have them bench it first to confirm. Hope this helps
Dec 04, 2009 | Pioneer VSX-818V-K Receiver
Pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Sep 08, 2009 | Pioneer VSX-818V-K Receiver
Pioneer VSX-818V-k wont work with PS3 or AT&T U-Verse
That model does not support audio via hdmi. That is the problem.
Jan 04, 2009 | Pioneer VSX-818V-K Receiver
My Pioneer Home Theater receiver model VSX-818V-K will does not produce sound out of the HDMI passthrough. I have tuend on DTS and 5.1 Dolby in my Playstation 3 settings too. Is there something I am...
You didn't say anything about assigning the HDMI to its input devices. here is al ink to the manual and you will find your answer on page 65. its easier that way then for me to type it all out. If you know how to assign inputs on your receiver already then should do it.
http://www.pioneerelectronics.ca/StaticFiles/PUSA/Files/VSX-818V%20Owners%20Manual.pdf
Enjoy HDMI is awesome,
Lee
Jun 12, 2008 | Pioneer Audio Players & Recorders
Pioneer VSX-818V-K Receiver Logo
443 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
