Question about Wolfgang Puck BTOBR0040 Toaster Oven with Convection Cooking
Need to check fuse or change out elements - Wolfgang Puck BTOBR0040 Toaster Oven with Convection Cooking
  • Wolfgang Puck Expert
  • 684 Answers
Disconnect first the unit from power supply. pull out the fuse and check for the continuity of the terminals with an ohm meter, if there is no continuity,, replace the fuse. for heater, remove one heater terminal connection and check for the resistance reading.if no resistance read, replace the heater. ALWAYS DISCONNECT THE UNIT FROM POWER SOURCE BEFORE DOING THESE.
Posted on Mar 31, 2011
Oven works but is not heating up what can I do or check for to restore heat
Check for correct power at the heating elements, if its there, the elements are burned or shorted.
Mar 07, 2015 | Lincoln 1301/1346 50" Electric Impinger...
Unit power on light is illuminated but no heat from heating element,
The thermostat may have failed. It could be adjustable mechanically but not electrically.
Nov 06, 2013 | Anvil SAA8003 Stainless Steel 3000 Watts...
Top heating bars stopped working
Dear Tang_Tuong,
I would check all of the fuses, the internal fuses and wiring for any signs of damage and that particularly from heat. Also multimeter the connectors of the wiring to the element and see if you are getting a voltage reading, if you get a reading from the wiring and the element is not heating up, then you need to replace that element, do these checks for all of the internal components and you will find the one at fault.
I do hope this is the fixya for you and look forward to hearing how you get on.
Yours sincerely
Ouszen
Feb 07, 2012 | Euro-Pro Toaster Ovens
ELECTRONICS SEEM TO WORK (ON/OFF; TIMER; CLOCK; OPERATION SELECTIONS [TOAST, BAKE, ETC]) BUT ELEMENTS DO NOT LIGHT UP
check the resistance of the plug by turning the timer and temperature switch, if there's no resistance, open your unit and check the resistance of thermal fuse which is connected to line wire. it is look like resistor..if the thermal fuse is ok then check the resistance of heating element..
Sep 30, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
The upper element in my Sanyo SK-VF7S no longer works
Since it is unlikely that each element has a separate fuse, the element has probably failed.
To verify this and check the element for continuity, you would need a meter capable of measuring resistance, a common feature on even the cheapest meter.
You can buy one of these in auto parts stores, electronic supply stores, on eBay, or, if you have one close to you, at Harbor Freight cheaper than other local stores.
The most basic can measure AC, DC, DC current, continuity and resistance and digital meters have pretty much replaced the standard analog meter; you will be reading from a numerical LCD display. They are useful to have at home or for your car for checking many things. Instructions are simple, even understandable if you can correct the butchered English typically found in the manual.
Observe sensible safety by pulling the plug on items measured for continuity or resistance.
If you do want to measure the element, you will find very low resistance if the element is intact; somewhere between 2-3 Ohms and not likely more than 10 Ohms. You will need to disconnect one end of the element and then measure from end-to-end with the meter.
Aug 27, 2010 | Sanyo SK-VF7S 1350 Watts Toaster Oven with...
Convection Oven blows fuse. Replaced element. Still blows fuse.
could be anything
get in an electrician to trace the fault
Nov 03, 2017 | Toaster Ovens
The broil element and bake element both come on set for Bake.
You are correct in your diagnosis. The selection switch has 2 sets of contacts that should only make one when on bake. The contacts internal to that fuse are most likely fused together, the other thing that could be going on is a short circuit in the wires to the selection switch causing the same problem. Typically a repair unless under warranty would be costly unless you are up for the challenge of replacing the switch and checking the wiring yourself.
Apr 20, 2010 | DeLonghi XU1837 Trilogy Bake 'N' Broil...
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Wolfgang Puck BTOBR0040 Toaster Oven with Convection Cooking Logo
230 people viewed this question
Top Wolfgang Puck Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Are you a Wolfgang Puck Toaster Oven Expert? Answer questions, earn points and help others
