Question about Mantis Tiller 4 Cycle Engine Handy Item Kit #3777 00 02
4 stroke engine has oil in cylinder - Mantis Tiller 4 Cycle Engine Handy Item Kit #3777 00 02
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly,
If this is the LNU25 style engine it has an oil capacity of .08 Liters of oil which if not very much. If someone tipped the engine for cleaning or installation of an accessory you can get oil in the cylinder. with the ignition OFF, clear the oil by squirting either carb cleaner or fuel into the cylinder. Make sure to pull the engine through rapidly with the spark plug removed to clear out cleaning agent. Then clean the spark plug, reinstall the spark plug and re-service the engine oil level. Start the engine and let run until warm. When finished using the tiller and the engine is once again cold inpsect the oil level and the cylinder for oil once again. I think you have a one time incident at the moment. If the symptom happens again prior to your next use just respond here and I will help you.
Thanks for choosing FixYa,
Kelly
Posted on Mar 27, 2011
Testimonial: "thank you will try "
    New Friend:
Hello Kelly,
When we first bought the tiller, the 2nd time we used it, the piston was locked because of oil in cylinder. Took it back to dealer and he accused us of laying the tiller down. We did not. It still doing the same thing and it is sitting up. It has never been turned over. Oil is getting in cylinder from crank case. It is almost new. It has probably only been used 2 or 3 times because of this problem.
Any help will be greatly appreciated.
Brenda
bellfas@blomand.net
Posted on Jun 16, 2013
Ratio for 2 stroke mi
if you are asking the oil /fuel ratio for a 2 stroke small engine. not being told the size, make or model makes an answer impossible
however Stihl have a special 2 stroke oil that is mixed at the ratio of 50:1 and that will cover all ratios from 20:1 to 50:1
Saves having different cans for all of the engines that can be a workshop
Mixed correctly it works well and if you want just the one fuel can that includes 4 stroke engines
the 50:1 ratio makes for good upper cylinder lubricant in those engines as well and you will not even see it smoke
Apr 21, 2018 | Garden
Is my 2005 qiangiang gmi 108 a 2 stroke or a 4 stroke
Hi, David engine design is very easy to identify:
TWO STROKE
1. Two strokes red line around 12,000-16,000 RPM.
2. A reed valve is in between the carburetor and cylinder head.
3. The exhaust has an expansion chamber.
4. The muffler has a small diameter tail pipe.
5. The exhaust has a high pitched Bap Bap sound.
6. Small scooters and small dirt bikes are generally 2 Stroke.
7. Older models had adjustable throttle actuated oil injection.
8. Older models had a premix ratio of 2 stroke oil and gas.
FOUR STROKE
1. Four strokes red line around 6,000-8,000 RPM.
2. Four strokes have camshafts and valves.
3. Mufflers have large diameter outlets.
4. The exhaust has low pitch deep rumble sound.
5. 350cc and larger engines are usually 4 strokes.
6. Four strokes have separate oil tanks that feed an oil pump.
For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
2005 GMI Motor Sports GMI 108 Scooters
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Qianjiang Scooter Parts Racing Planet USA
Full size Scooter Parts
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Aug 02, 2017 | Motorcycles
I have a 1993 Honda 125cc was told to mix gas but these oil in crankcase do I need to mix?
You would never mix any fuel and oil for the crankcase. If it is a 2-stroke engine, the fuel and 2-stroke oil will need to be mixed before entering the cylinder. Some engines have an automatic mixing setup - those have a separate oil reservoir for 2-stroke oil, but it will usually be a plastic tank, located nowhere near the crankcase. On a "4matic" engine, it fires like a 4 stroke, but there is no crank case, and the fuel needs to be mixed like a 2 stroke. What is the vehicle you are referencing? A dirt bike or street bike? It seems the CR125 and NR125 are both 2 stroke engines, so somehow the fuel needs to be mixed with 2-stroke oil. Can you take a picture of the crankcase oil cap?
Feb 04, 2015 | Honda Motorcycles
What oil (4 or 2 stroke) oil for 50 cc CPI scooter
Model: CPI Oliver 50
Displacement: 50.00 ccm (3.05 cubic inches)
Engine type: Single cylinder, two-stroke
Power: 4.40 HP (3.2 kW))
You have to use 2 stroke engine oil.
Hope it helps.
Jul 20, 2011 | 2005 Cpi Oliver 50
Cant find mix fuel/oil for stihl ms 181
Model MS 181 Engine single-cylinder two-stroke Capacity 31.8cc, 1.94cu.in Bore 38mm, 1.6in Stroke 28mm, 1.1in Ignition Electronic (Breakerless) magneto Spark Plug NGK CMR6H Electrode Gap 0.5mm, 0.02in Carburetor All position diaphragm type with built-in fuel pump Fuel Tank 0.27litre Fuel mixture 50:1 with Stihl two-stroke air-cooled engine oil Catalytic Converter No Chain lubrication Automatic oil pump Oil tank 0.265 litre Weight
(dry, no bar, no chain)
4.3kg (9.5lb)
Jun 22, 2011 | Garden
250 2cycle. What is the proper lube for the bottom end?
all you need on a 2 stroke engine is the oil mixed with the fuel. the oil/fuel mixture lubricates your bottom end and your cylinder which is all that moves in a 2-stroke. if it is oil injected then use a 2 stroke oil rated for 50:1 mix. if you gotta mix it manually then just read the jug. hope that answers your question
Feb 25, 2011 | Yamaha FZR 250 Motorcycles
I just bought my 50cc Yamaha scooter 3 months ago. Top speed was normal around 45km. It runs great .But recently it lost a lot of speed maxing out around 30km.I just got it check out .The spark plugs are...
You don't " get a cylinder cleaned ". Who ever says that doesn't know what he is talking about. I assume the engine is a two stroke. The gas/oil mixture should be 32 to1. That means 4 ounces of two stroke engine oil to one gallon of gas. If the scooter has an automatic oil pump be sure there is oil in the oil tank. It should automaticly pump the engine oil at the proper rate. If this is an older scooter, you could remove the cylinder head and de-carbon it and then check the exhaust port to be sure the port has not been made smaller due to carbon build up. The port should be about 1/2" tall and 1" wide. Also check and clean the air filter. If it is a new scooter is it still under warranty?
Aug 13, 2010 | Yamaha YZ 125 Motorcycles
I bought a 2006 Tomos A3550 used. Is it a 2 or 4 cycle engine?
almost certainly a 2 stroke but easy to confim, check to see if there are valves on the cylinder head, 2 strokes dont have any, check for an oil dipstick on the engine bottom casing again 2 strokes dont have an oil sump so no dipstick!
Jul 04, 2010 | Motorcycles
My 81 yamaha enduro is smoking badly
Same happended to me with exactly the same motorcycle... I solved the provblem by replacing the crankshaft oil seal on the rightside of the crankcase. It solved the problem immediatly!
Jun 04, 2009 | 1974 Yamaha DT 360
Do i have to mix 2 stroke oil on the gas for the 4 stroke bikes or just add regular gas on the tank? if is what is the scale for the mix?
DO NOT mix oil in the gas on your four stroke engine. You will foul the spark plug(s), build up deposits on the valves and head, and make a smokey, smelly mess. A two stroke engine uses the fuel/oil mix to lubricate the engine before being used as fuel. A four stroke engine has a separate lubrication system and does not normally burn any oil. As the name implies, a two stroke engine works in two strokes. The first stroke is downward, where the fuel/oil mix and air are drawn into the cylinder. The momentum from the crankshaft counterbalance or force from the other cylinder(s) drive the piston back up compressing the mix, and the spark plug sparks at or slightly before the top of the stroke. The rapid combustion of the fuel/oil/air mix drives the piston down, which is the power stroke, and then the cycle starts all over again. A four stroke engine has an intake stroke down taking in the fuel/air mix, a compression stroke up, a power stroke down as the fuel/air mix is ignited at or before the top of the stroke, and a exhaust stroke up before starting all over again. A four stroke is much cleaner and more reliable than a two stroke, but it is heavier and has less torque. A two stroke engine is much lighter and has more torque, but takes more maintenance.
Feb 28, 2009 | 2003 Yamaha YZ 250 F
Mantis Tiller 4 Cycle Engine Handy Item Kit  #3777 00 02 Logo
180 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
