Question about Whirlpool AWZ410 Front Load Washer/Dryer
What to do if whirlpool awz 50e washing machine is showing water closed tap indicator although tap is not closed
    Brigadier General:
  • 6,277 Answers
Providing that the tap is turned fully on and the hoses are not kinked or squashed at the back, this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Good luck,
John C
Posted on Mar 27, 2011
I want to Know how to use each button?
Try Googling (whirlpool)(AWZ 410 - 1000)(manual) without parens.
Dec 25, 2017 | Washing Machines
Hi, I am not able to open the door of my Whirlpool washer dryer AWZ 5140 E after it finishes the cycle. It shows up E13 with ticking noise. There is no water left at this stage and I am able to open the...
E13 is a dispenser error the appliance diagnostic believes the appliance is full of water so won't release the lock first thing to try is the drain filter bottom right hand corner at the front unscrew it clean and refit just be prepared it's likely u will get some water out it when u remove it.
Dec 08, 2013 | Washing Machines
The water is cold on the 40 degree wash (programme 4). It gets hot on the 60 and 90 degree washes, so the hot fill valve is working (changed it for a new one). I can't find a service manual for...
Whirlpool AWZ 410 Service Manual
The manual is not redundant. In other words it shows the cold info and not the hot. However if you look at the entire manual it shows both functions and starting on page 10 shows the hot wash sequence of events.
Nov 20, 2017 | Whirlpool AWZ410 Front Load Washer/Dryer
My Whirlpool Washing Machine 6th Sense 10kg Dreamspace has stopped washing mid-cycle and has a F09 warning flashing
my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
Mar 15, 2010 | Whirlpool Washing Machines
Red light showing water tap closed how do i rectify please
This usually indicates a problem with the water supply to the washer.
Check the tap/s are fully turned on, check that there is no restrictio orr kinks in the hose/s.
Make sure you have good water pressure.
Jan 27, 2010 | Whirlpool Washing Machines
The machine keeps indicating a closed water tap! very little water entering the drum.
chek ur whater temp on ur sicle and then if dont work just turn the taps fuul power
Nov 19, 2009 | Whirlpool LHW0050PQ Front Load Washer
Where to find quick guide of whirlpool AWZ 475
I have moved into an apartment with a whirlpool AWZ475 washing machine with no instructions. Is there somewhere I can get an operators instructions on line ?
Mar 04, 2009 | Whirlpool Washing Machines
Washing cycle starts and takes hours even for short cycle.
Try checking for good water supply.
Pull out detergent tray and check for good water supply during filling.
if poor filling-
Try checking the hoses.
Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
Oct 05, 2008 | Whirlpool AWM6120 Front Load Washer
Whirlpool washer problem
it sounds like you cold inlet need replaced its a easy job
Jan 10, 2008 | Whirlpool AWM6100 Front Load Washer
Whirlpool AWZ410 Front Load Washer/Dryer Logo
635 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
